Question about Dryers
Hi, I have Kenmore electric dryer 27"wide. I was tring to clean the lint screen. I saw some lint in the hole too. so, to remove that I inserted a thin long brush, but it went inside it. I tried to pick that with the help of a knitting needle but I dropped that too. I dont know how to get them out. Please help.
  • rashmisha Jan 02, 2009
    Thanks for the solution, I pulled out both the items by the help of a catcher. So, there was no need for me to open the machine. Thanks once again
  • 242 Answers
I think I can help , I have done this many times , you will need a quarter inch nut driver or a quarter inch socket and a phillips screwdriver , the dryer must be disconnected and you have to get behind it , there are 4-8 screws holding the back lower panel on not the smaller control panel but the large back panel , after removing that you will see the rectangle lint screen duct/housing on your left side , there are 3-4 screws at the bottom of the duct that need removed there , and at the top where the sreen is inserted there are 2 phillips screws that you need to remove. after all screws are out duct should be loose and you can move it out of the way freely and you should see the fan behind it , remove unwanted items and re-assemble. Let me know if you have any more questions , good luck o and dont use the dryer you could do major damage.
Posted on Dec 30, 2008
Csn you remove trap where lint filter goes
How To Clean Your Dryer's Lint Trap, Screen And Vent ...
greenlivingideas.com/2014/08/14/clean-dryers-lint-trap-duct-screen/
Aug 14, 2014 - Cleaning your dryer's lint trap, screen and vent is a great way to keep it using energy efficiently. ... (Of course, if you can hang your clothes to dry, you'll not have to go ... Now use the vacuum to remove any lint from the lint trap.
Stackable Dryer-Lint Screen-Where is it? - YouTube
? 3:09
https://www.youtube.com/watch?v=-qu0OF9V2vA
Dec 27, 2011 - Uploaded by OcRefrigeration & H.v.a.c.
This Video Shows Where a " Lint Screen " is in a Stackable Washer Dryer and How to Remove it. Clean it ...
How to Clean a Dryer Lint Screen ' Cleaning Guides
www.howtocleanstuff.net > Cleaning Guides
Jan 11, 2016 | LG DLE5001W Dryer
Dryer element is blowing
Hi rdneck40...
If your element keeps blowing, then you have an overheating problem.
Check and clean if necessary your vent hose.
If you vent hose "seems" to be clean then,try running the dryer with the vent hose off and see if the dryer is not running hot anymore.
Make sure your lint screen is in place and has no tears or holes in it and is still firmly attached to the frame.
If you are running too hot you are not moving enough air thru the system.
It could be that the fan blade is plugged up.
The problem could be a large lint ball build up in the center of the fan or a sock,thin pants,a pen,etc. that has gotten into the fan by falling down the hole where the lint screen is normally inserted.
You have to find the air restriction to solve the problem.
It also can be a loose or worn out blower wheel/fan.
Please take time to rate me.
Sep 23, 2011 | Kenmore Dryers
On low setting dryer is to hot
Hi linjonlyn...
Please take time to rate me thumbs up.
Sep 21, 2011 | Kenmore Dryers
Kenmore dryer over heats and blows fuse
Hi roger301
Aug 30, 2011 | Kenmore 400 6942 Dryer
Dryer is extremely hot inside back of dryer, top of dryer back and the back of the unit
Hi laurie a pow...
Aug 22, 2011 | Kenmore 62872 Electric Dryer
Lint filter will not go back in kenmore soft series dryer
Lint could be preventing the screen from re-inserting into the slot. Unplug the dryer and use a coat hanger with some duct tape on the end looped around so that it attaches to the hanger and has a sticky side for the lint at the bottom. Remove lint and try re-inserting the screen.
Apr 30, 2009 | Kenmore Dryers
I need the schematic for my dryer series 80. Model number 11062822101 A night light bulb accidentally fell in the vent hole, when I pulled out the lint screen to clean it off. My dryer opens in the front,...
lift your lint lid and remove the 2 screws you see then pry the top up at the edges with a wide flat screw driver. If you have a rear cover remove it then remove the 3 crews that hold your lint catcher assembly to the blower housing and you should find your bulb
Mar 11, 2009 | Kenmore Dryers
Kenmore dryer 10+ years old model 86376100 63761
Make sure that the lint vent is attached properly to both the outside wall and the dryer. Also make sure that it did not get a hole punctured in it either
Feb 13, 2009 | Electric eBay offers you smart deals and...
Check lint screen come on
Check the tubing the lint goes through (exhaust). This may be stopped up or clogged. There is a build up here of heat or something that is preventing proper air flow.
Dec 27, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
Top Dryers Experts
