Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Oven door wont stay shut
Kenmore 6657502210 gas. The oven door doesnt shut all the way flush. its open at the top of the door. it lets out heat. any ideas??
  • Kenmore Master
  • 3,463 Answers
U need to fit new door hinges, only solution as they are not adjustable.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
DEBIG24SS Gas Single Oven: oven want stay on after you let loose of the ign...
replace the gas safety valve thermocouple,it has a thin coil of copper colored tubing going from the safety gas valve into the pilot light flame and as the flame heats the copper tube end it keeps the gas valve open to supply gas to the unit,they get old from being in a flame and cant signal the gas valve to stay open any longer,they just unscrew out of the gas valve and the opposite end is positioned in the tip of the pilot flame to heat it
May 18, 2010 | DeLonghi DEBIG24SS Gas Single Oven
Do I leave the oven door open a little while broiling?
Yes, it is a good idea to let it open just in the first posistion which gives it about a 3 or 4 inch opening at the top. This will hold enough heat in to broil your food but will let enough out so that the ovenwill not over heat and it will keep the burner on. Usually broiling times are not that long so this will not over heat your home or present any other dangers. Of course you still want to preheat the oven with the door cloded for best results.
Heatman101
Jan 28, 2010 | Kenmore Ovens
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven door not staying fully open
phone bosch for clarification first. If this is not the case get the gas board out again
Oct 21, 2009 | Ovens
Cant get the oven door to shut all the way??
Try opening the the door a few inches and lift it straight up. Then push it straight down. It should slide on the hinges up and down. You need to seat the door properly on the hinges. Don't be afraid to man handle it but, be careful the oven may tip if it's free standing. Good luck. Please rate me so I know if I helped. Thanks.
Dec 30, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
My oven is a kenmore gas single, self cleaning oven about 8 years old. the oven will not light. the top of the stove is fine.
Open the oven door and take the bottom panel off. you will be able to see it the hot surface ignitor starts to glow or not. Now turn the oven on and see if the hot surface gets red hot it not that is the problem. Should be able to get the part at a heating and air parts house or a appliance parts house. let me know what you find out. ken
Dec 13, 2008 | Kenmore 30172 / 30174 / 30179 Gas Single...
Broiling
it really doesnt matter because the heat transfers directly onto the food therefore you can leave the door open or shut.
Jan 05, 2008 | Equipex PZ-330 Electric Single Oven
1990 Kenmore Self Cleaning 24in Elec Double Oven - Top Oven door does not open
hit cancel or stop clear see if that helps if that doesnt work start self clean then stop it
Jul 29, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
218 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
