Connections for a Grundig reel to reel tape recorder
I have an old Grundig tape recorder (1960's) which I wish to connect to an external tuner to transfer the recordings to my computer. It has Din plugs with symbols on them, but I don't remember what they stand for! Can you help? One symbol is a double wavy line, like '' = '', but wavy. Another symbol is a square with the right hand edge protruding beyond the edge top and bottom, like a square '' d '' without long upstroke. Another symbol is like a '' Q '' but reversed right to left. I hope you can help! Thanks very much. Bill Hart (Warrington, Cheshire).
  • ulh4080 Jan 14, 2009
    I have the same problem with my TS 340 tape recorder. I need to replace the speaker and DIN cables for this machine, and the symbols confuse me for sure!...Does anybody know where to find the cables , manual or any info at all?. Frank Davis (Myrtle Creek, Oregon)
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
Posted on Feb 05, 2009
  • 1 more comment
  • andreas906 Feb 04, 2011
    Great help! I actually took the thing apart, to find the ext speaker connection!
    Andreas
  • stupot2 Apr 06, 2011
    Top marks sir, very helpful, thank you for taking the trouble to post this information
  • Yasser Fawzy Jan 11, 2012
    A great help.....one more request do you have the pin assignment for Earphones and Squiggly lines - Outputs.?
Akai Reel-to-Reel Tape Recorder Model X2000SD how do I hook up the cables for sound? I can get sound through the speakers, but can't turn it up.
Most reel to reel tape recorders have "line out" in the form of RCA phono jacks. These are designed to be connected to an external amplifier. Some unit, however also have an internal amplifier and will output to speaker jacks that should be clearly marked. If your unit has such jacks and you cannot control the sound, your amplifier must be bad. Keep in mind, on most recorders, there are no internal speakers or output amplifier and the volume controls on the front are for recording only.
Apr 29, 2017 | Akai Audio Players & Recorders
How to set up Panasonic videotape recorder
was this the one seen in the 1960 lost in space tv show meant to be in the future of the year 2000. Guess they never thought of devices being smaller or digital.
https://www.youtube.com/watch?v=VA_sd229TVM
https://www.youtube.com/watch?v=Quf6FeOnk-M
it is not a video recorder it is an audio device built in 1969
The first VCassetteR or VCR were sold by Sony in 1971.
betamax was 1975
vhs in early 1970
Aug 14, 2016 | Panasonic Vintage Rq-705 Reel To Reel Tape...
Amp works but the tunner doesn't all tubes look ok
Basic fault finding would be good. Check for the correct voltages on the valve bases.
Jul 16, 2017 | Grundig Audio Players & Recorders
Grundig tk5
With a bit of luck you may be able to find some adapters to allow a plug into the Line IN port of the computer.
Here is a site that appears to have the Grundig manual if you register ( its free). There may also be some very knowledgeable people there that you provide the info you need.
Oct 29, 2013 | Audio Players & Recorders
I have an old technics su-z22 amp and a denton tape deck with an it seems an incompatable record out socket from the amp and two rca sockets on the tapedeck how can i marry the two up
Having looked at the back of the model referred to I see two sets of RCA sockets for the connection of two tape decks. So I don't know what you mean by incompatible record out socket? There is a 5 pin din but you can use the two RCA sockets to connect the tapedeck. If you have a good quality RCA lead it should record and playback. You can in fact connect two tape recorders to this unit using the RCA sockets.
Apr 11, 2013 | Audio Players & Recorders
I have grundig tm 245 reel to reel tape player make some noice o 1-2 ch. 3-4 ch is fine
it could be a weak solider point inside the machine, or a poor connection on the outside. if it's a reel to reel it probably has some age to it.
Nov 08, 2012 | Audio Players & Recorders
Low volume recording on reel to reel tape deck
Problem could be in either the record or playback circuits of unit. Try playing back a tape in another machine to see what the volume is like. If also low then the issue is with the record amp circuits.
Fixing will not be cost effective, however.
Aug 21, 2017 | Audio Players & Recorders
I cannot record digital when I try to set up my Magnavox ZV457MG9 (DVD). The unit will only record in the external L1. I have a Comcast box.
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
The manual for the Magnavox ZV457MG9/F7 is available here: http://download.m4c.magnavox.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf . The unit was manufactured for Magnavox by Funai; thus another link to the manual is http://www.funai-corp.com/6pdf/om/ZV427MG9.pdf .
I wish that I had better news for you.
(If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
Oct 01, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
How do you find a dvd recorder that does not need and external tuner? Does the new tv's have a tuner that you can use with the current dvd recorders
U have cables or satallites tvs services hook up.U can record VHS tapes and used any DVD/VCR recorder machines hook up.Because the pay services does convert the signal back to analoge tv signal so u can record VHS tapes.
May 12, 2011 | Toshiba DVR620 DVD Recorder/VCR
How must I connect the amplifyer V500 with my computer for recording from a tape player?
I assume you want to record from tape to computer and monitor the recordings later.
Simple three steps.
1) Connect the tape deck line out ( or labeled PLAY ) to any one of the inputs like Aux / Tuner using an 2RCA connector.
2) Connect Rec out from the SUV' to line input of your PC ( blue socket ) sound card.
3) To monitor your PC sound after recording on to Hard Disc , connect a cable between the PC sound out ( green socket ) and the the SUV Tape monitor IN ( sometimes labeled PLAY ) Now comes the tricky partbobhifi_30.jpg.When you want to record on to your PC put the source switch on the SUV to where you have connected the Tape deck ( Aux / Tuner ). On the SUV keep the Tape Monitor switch to source ( released position ). After having done the recording to monitor and hear the Hard Disk playback turn on the Tape Monitor switch ( dipress it ). The pressing of the Tape switch on the SUV lets you toggle between the source and recording - In your case Tape deck and PC
Mar 31, 2011 | Technics SUV500 2-Channel Amplifier
2,628 people viewed this question
 Grubhead
Grubhead
