Question about Doro 530 Twin Cordless Phone
Main handset won't work; additional handsets do.
I bought a Doro 530+1 phone from a guy on eBay. It was the Doro 530 ONLY (that is, on the base of the phone, it says "530+1" but I only got the base). As well as this, it came with three additional handsets which are all the same - marked "DORO 1000 AHS" - (AHS = Additional HandSet??). Regardless of whether the additional handsets are in use, the main base unit's handset won't work. It shows a flashing aerial symbol on the handset screen, which suggests to me it's trying to find the base - only it never does. Yet despite this, all the additional handsets work flawlessly. How can I get the main handset to "connect with" the base so that it works? Thanks in advance! :)
  • 3 more comments
  • allison85 Dec 30, 2007
    The main handset has a flashing antenna in the right hand side of the screen. I have made sure that the power is connected to the base. Also the two additional handsets do not work. They have dashes on the screen and do not work at all. I do not have a manual to be able to check what is wrong or see how to fix the problem.
  • Anonymous Mar 14, 2014
    model #30524....additional handset says check battery...warning battery
  • Anonymous Mar 17, 2014
    how to connect doro 331 pendant phone to base unit
  • Anonymous Mar 18, 2014
    The additional handset is crackly but the main unit is ok. Can I do anything to fix it
  • Anonymous Mar 21, 2014
    the handset on the base, people who call say it sends them to voicemail
Check that you have the larger power adaptor connected to the base unit.
Posted on Jun 09, 2007
Phone says no link to base reconnect to mainbase ac addapter
The instructions worked after the additional KX-TGA402N handset was fully charged and I kept pressing the menu/ok button of the additional handset to advance from initial settings to the handset registration mode.
How do register an optional accessory handset to my existing main base...
Feb 08, 2013 | Panasonic KX-TGA402N 3 Pack KX TGA402N 3...
Is there a battery in at&t 530 handset?
The ATT 530 is not a cordless phone, so any suggestions related to base/handset are erroneous.
Dec 09, 2012 | AT&T Lands Phones
I bought 2 sets of the uniden DECT 1480-3. I want 6 handsets to work with one base. How do I add 3 handsets to a base that already has 3 handsets?
Jill,
The only logical way is to get the additional handsets to communicate with the base. And to do that you must set them to the frequency of the base. You Use guide will tell you how to set the frequency n the handsets to talk to the base. They way you set the original ones.
BUT, I doubt if this will work. Why? Because if that was the case if you and I had the same company phones, then I would stand outside your home and set the same frequency on my handset and misuse your phone. A great security risk in today's world. But there is no harm trying it out. Just set the same frequency on the additional ones as the base. If it works, then you will have that many more intercoms too. And do let me know if it works.
Apr 11, 2011 | Uniden Additional Handsets - DCT640 Phone
Vtech Dect 6.0 says not registered. how do I register?
Instructions for registering additional new handsets on VTech Model DS6151: Place additional handset on main base. Press HOLD on main base and # on handset. Asks you to de-register. Press no. Registration of additional handset takes place.
Aug 17, 2010 | Vtech DECT 6.0 Digital Cordless Phone
DORO NeoBio 10 Cordless Phone
The hand sets probably need to go through the 'registration' process with the base station. Look up the steps on how to do this in your manual.
One thing that the manual sometimes does not highlight clearly is that first you need to press and hold down a button on the main base station for a while until it beeps. Then you can go through the menu on the hand set to complete the registration process.
Aug 01, 2008 | Doro 530 Twin Cordless Phone
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
Programming old handsets to a new base
Cancel the old handsets registration at the previous base unit if desired.
For additional handsets, you must register each of them at the new base unit. Only one handset can be registered at a time. A handset will be assigned anextension number at registration.
Make sure the base unit and the other handsets are not being used. Program the same way as the extra handset you bought.
Registration must be completed within 1 minute.
Jun 25, 2008 | Panasonic KX-TG2740 Cordless Phone
Doro 130 R
Go to http://www.doro.com.au select home phones then Support then Manuals Then you type in your model which should be on the back of the base unit.
Oct 28, 2007 | Doro 530 Twin Cordless Phone
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Jun 26, 2006 | Uniden TRU8885-2 Cordless Phone
Doro 530 Twin Cordless Phone Logo
472 people viewed this question
Top Doro Lands Phones Experts
castletech
castletech
Gene Tuck
David Burbee
David Burbee
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
