Question about E-Machines eMachines Desktop PC
No signal on monitor when powered up 3 long beeps
  • 2 more comments
  • audasfl Dec 30, 2008
    yes everything is plugged in correctly and the monitor says no signal this is on a previously working computer *at least till this point*
    (ive read on different systems the beeps mean certain things, )
    no changes to the computer have been made ,
  • audasfl Dec 31, 2008
    ok finally got it to work ....had to take out battery and memory then put back in ....unhooked monitor for the billionth time hooked to a new monitor then back again now its working yeahhhh ty everyone for your help
  • mwit465
    mwit465 May 11, 2010
    Hi there;\
    I'll attempt to help you. You say you have no signal on your monitor after powering up. Beeps might mean hardware error. Is the monitor plugged in correctly as well as plugged in to power?
    Novelist:
    Scholar:
  • 72 Answers
Snowchick is on the right track. The monitor is working and the message "no signal" is the monitor's way of telling you it is working, but the computer is not sending any video to display.
Before opening the box, try removing every single connection to the computer except power supply and monitor only. This eliminates all external sources of mechanical failure.
If you suddenly get a display, add the items one by one until you have a problem again. The last item added will be your culprit.
Remember, power down between unplugging and plugging. Only USB devices are safe to plug in under power on conditions.
If that does not help, unplug power to computer, open case and reseat (remove and replace) your memory. If you have more than one, try with only one and swap them out one by one to see if one of them will work. It would not be a bad idea to have someone knowledgeable help with the reseating process.
Another step you can take if the RAM makes no difference is to remove any other expansion cards (modem, sound card, etc.) and try again. Most E-machines have integrated video, sound and NIC so there may be nothing much to remove. You can also try disconnecting the cables to all of the drives (hard drive, CD, floppy, etc.).
Let me know if you need further support.
Honest1abe
Posted on Dec 30, 2008
    Scholar:
  • 76 Answers
Ok if everything is plugged in correctly have you made any other changes to this computer configuration? Have you also tried re-booting with the new monitor installed?
  • mwit465
    mwit465 Dec 30, 2008
    Ok if no other changes have been made to your system, either the monitor is plugged in wrong, (or not completly), not turned on, (of course you've checked that), or is not compatible somehow.
    Give me the details on the computer and monitor. model, age, etc.
Hey there,
Beeps generally point to RAM, this would also be why the monitor has no signal as the computer wouldn't be POSTing. I'd suggest reslotting the RAM and if this doesn't work then swap out the stick with a new one :)
3 beeps at start up
refer here
http://www.tomshardware.com/answers/id-1725459/computer-beeps-times-monitor-signal.html
Apr 23, 2014 | Computers & Internet
1 long beep and then 3 short beeps
Hello here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5KPL-AM%20SE&p=1&s=22
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
It seems to be a graphic card problem, or the power supply not giveing enoug power.
Try to change the graphic card.
If you are useing the onboard graphic, look for bad caps on the mainboard:
If they look like this, the mainboard is dead.
Good luck
Feb 16, 2013 | ASUS P5KPL-AM SE Motherboard
No signal on monitor, vga tested and ok
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Mar 11, 2012 | Computers & Internet
My acer 19" monitor has no signal what should i do?
  1. check whether the signal cable properly connected to the vga port or not ?
2.listen the single beep from PC
3.try monitor on another PC . if persists , then the fault lies in the monitor . if not then the fault is in the CPU
thank you.
4.if no beep from CPU then disconnect RAM . listen contineus beep . if heard , then the RAM is faulty , replace it .
Jul 23, 2010 | Acer AL1916W 19" LCD Monitor
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
No Signal To my Monitor and no beep.
First refix the RAM and Pci graphic card.
Pull cmos cell from mother bord for 15 minutes then put again into its position then all settings are defaults.
Then if still face problem then check with other RAM.
Aug 13, 2009 | Computers & Internet
No video, monitor and video card are good
There 3 possible problem with your board...
1. Processor
2. Ram
3. Bios
Check one by one
Nov 25, 2008 | Soyo SY-KT333 DRAGON Ultra Motherboard
E-Machines eMachines Desktop PC Logo
240 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
