Question about Kenmore 30464 / 30465 / 30469 Gas Single Oven
Cant get the oven door to shut all the way??
Kenmore 6657502210 gas. The oven door doesnt shut all the way flush. its open at the top of the door. it lets out heat. any ideas??
    Scholar:
  • 140 Answers
Try opening the the door a few inches and lift it straight up. Then push it straight down. It should slide on the hinges up and down. You need to seat the door properly on the hinges. Don't be afraid to man handle it but, be careful the oven may tip if it's free standing. Good luck. Please rate me so I know if I helped. Thanks.
Posted on Dec 30, 2008
Door will not open and oven will not shut off
The door latch will open after the shut down, therefore go to the home circuit breakers and shut off the power to the oven. Wait a few minutes and try to open the door. If still locked, reset the power to the on position and see if the oven rest and shut down properly and the door lock released.
Dec 31, 2013 | Kenmore Ovens
My oven is flashing a F10 code and the door is locked. This happened while the oven was in self cleaning mode
more than likely the tco thermal cutout fuse has opened during cleaning and now the ovens latch motor cant get power to open,its under the top cover where the surface elements are located its a frequent thing with all ovens/stoves
Jan 12, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
We self cleaned and the 2 days ago and the door is still locked. Help
The lock is operated by a solenoid and may have stuck due to friction or goo around the magnet core. Try bumping the stove or lifting it 2 inches in front and dropping to the floor. 2 inches will not break anything. There may be a mechanical timer in the self-cleaning circuit... is your gas stove still plugged in and showing signs of power such as ability to ignite top burners electrically? If the timer has failed the door lock solenoid is still activated and there could be a slight hum. Try unplugging the range and see if the door can be opened. The thermal interlock should be free to let the lock retract. If that works replace the timer motor. If solid state (no timer motor) replace circuit board with timer relay.
Dec 12, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
I am having trouble with the electronic ignition lighting the gas burner in the oven. It makes the clicking sound, but there is no spark 75% of the time. Gas flow is consistant every time. It is a model...
I tried the one thing no repair person or manual ever mentioned: take out the bottom drawer, which is used for storage, and check the wire connection under the stove that connects to the ignition wire. If it is loose, disconnect at the spade connector, clean, and re-attach. Now it works fine.
Dec 10, 2009 | Kenmore Ovens
I had food put into the oven and pressed clean instead. Now I cant open the oven door to get the food out. How do I open door?
If you're in a hurry, try holding down the clean button for 3 seconds. This may stop the clean mode. If not, respond back and I'll get you additional info.
Apr 06, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
Oven door wont stay shut
U need to fit new door hinges, only solution as they are not adjustable.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
My oven is a kenmore gas single, self cleaning oven about 8 years old. the oven will not light. the top of the stove is fine.
Open the oven door and take the bottom panel off. you will be able to see it the hot surface ignitor starts to glow or not. Now turn the oven on and see if the hot surface gets red hot it not that is the problem. Should be able to get the part at a heating and air parts house or a appliance parts house. let me know what you find out. ken
Dec 13, 2008 | Kenmore 30172 / 30174 / 30179 Gas Single...
1990 Kenmore Self Cleaning 24in Elec Double Oven - Top Oven door does not open
hit cancel or stop clear see if that helps if that doesnt work start self clean then stop it
Jul 29, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 30464 / 30465 / 30469 Gas Single Oven Logo
131 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
