Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Cruzer not showing on my computer but showing everywhere else
Sandisk Cruzer USB Storage device does not show up on my computer as a drive but shows up on safe removal on taskbar and in device manager. Device Manager shows no problems and the device is working properly. The same driver is running another 2 storage devices without a problem. Any assistance would be appreciated.
  • Anonymous Jan 07, 2009
    I have a windows vista, and a windows XP. I got the XP to work, but on the vista, I plug in my 4GB micro cruzer flash drive, but it only comes up as removable hard disk m, I try to open it, but it says, please insert disk into drive m. Can anbody help?
  • Anonymous Jan 16, 2009
    My device was showing up on my computer and was working fine. Now it's not. I used it on another computer and it also work, just not on my computer in my office. It just shows up as an Uknown Device in device mgr
    Problem Solver:
  • 6 Answers
Is it just removable or it has the U3 on it ?
Posted on Mar 25, 2009
How can I format write protected usb flash memory device
You can use Advanced Folder Encryption to shred files in this external storage disk.
Or you should unlock the card in the first place.
Here is the site you can refer to:
Oct 15, 2012 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk Cruzer Blade is not showing data. The drive shows up in 'My Computer' but data is not showing.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
Aug 31, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a Sandisk Cruzer 8GB pendrive. I was copying files halfway until a message pops out telling me that my drive is not there. i ejected and reinserted the pendrive, but I couldn't delete any files...
Right click my computer and click on manage. In disk management try to reformat as another solution for your usb storage drive. Try another usb port on your computer as well when you reinsert it and restart the computer. Usually when a usb device turns off and doesn't show up like yours did the device could be faulty or the usb port you have it connected to or for laptops sometimes the usb ports turn off if only using battery instead of ac adapter. There are power save modes for usb ports so have to check that in device manager as well. Good luck!
Dec 22, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
When I plug in the flash drive it lights up but doesn't show up as a drive in "my computer". If I start the device manager (which shows the cruzer device as a funtional drive), disable it and...
STEP 1 - Connect the Cruzer to the PC
If you receive a "USB Device Not Recognized" error on the computer, the flash drive is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: The Cruzer might show up under several places under Device Manager such as:
1. Disk Drives
2. DVD/CD-ROM drives
3. Universal Serial Bus controls as USB Mass Storage.
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click on the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
STEP 4 - Verify if the flash drive is detected
1. Double-click My Computer.
2. Look for the Cruzer under devices with removable storage.
There might be a conflict in drive letters, see Resolving drive letter conflict.
Oct 26, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computer is not detecting the drive?
right click on "My Computer/Computer" then go to Manage then go to Disk management check to see if the drive shows there if so right click on it and navigate the tabs until you see Assign a drive letter select a letter that is not in use, i usually use p-v because its use is rare. If it does not show in Disk manager check device manager and see if its under Usb/Unknown/Drives/removable storage/ or other devices if its not there then your device may be damaged or your port may not be installed properly/damaged
Jul 21, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do you save files on a sandisk cruzer flash drive?
Insert the cruzer into the usb port. You should see a message pop up and say new hardware found and then flash off. It may also say usb memory or storage device or even recognize it as the cruzor. This recognition process is fairly quick say 5-10 seconds. After that the computer knows what the cruzer is and its ready for use.
The cruzer is now seen as another drive or storage drive on your computer. Your hard drive is usually C , the CD/DVD would be D drive and the cruzer would be seen as E. If you are in a program and want to save to the cruzer you open the file/save and you should see E drive or Cruzer if not click on my computer and look for it there. Once you find it just click on it and then hit save/ok. Thats all there is to using one. Once you know how to find it as a save option or a loading option then you just treat it like a hard drive.
Once you get it sorted out you will use it a lot. They are very handy.
Jun 01, 2010 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
My cruzer is wroking fine except when i try and use "my computer" the drive doesnt show up. In any other program i can save to it and it shows up...just not in "my Computer"
In [My Computer]
select [View] from the top menu row
[Arrange Icons by]
[Arrange Icons by]
Checkmark on [Show in Groups]
The cruzer will show up as
"Devices with Removeable Storage"
Oct 01, 2009 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My copmputer wont let me install a sandisk cruzer
Check you have your chipset drivers installed if not go to manufacture's website and download from there what Operating System do you have?Right click over my computer drop down to properties,click on hardware,click on device manager and make sure there is no yellow explanation points and see that all drivers are installed correctly.Have you plugged the sandisk into another computer to see if it is accessible on another machine?
Aug 08, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Sandisk 4gb pendrive not working
Best thing to do is format the drive. Dont go for a quick format
Jun 14, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How do I get my SanDisk Cruzer working again
If you connect it to any computer and it doesn't show up, it has gone bad. Sorry.
Mar 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
159 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
