Question about Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
I have an F&P E522B frideg Freezer, freezer works but fridge warm
I have an F&P E522B frideg Freezer, freezer works but fridge is warm, checked upper and lower fans and both work, checked seals all good, compressor works, I am out of options.
  • 3 more comments
  • Missfixup Jan 02, 2009
    Fisher & Paykell active Smart Fridge about 3 years old.  Has been moved twice in its lifetime.  Freezer works, fridge warm, a little bit of frost around the vents at the back of inside the freezer.  Fridge will start beeping in the middle of the night or at anytime.  Beeping stops when you press one of the temperature adjustment buttons.  Lights correlating with the temperature buttons keeps flashing on both fridge or freezer options.  seals good.  Compressor seems to be working ok.  Not dirty at all around the back of the unit.
  • Anonymous Jan 03, 2009
    I have the same problem. Freezer part is working but fridge part is warm. HELP!
  • jhumblej Jan 17, 2009
    Hi. I have a similar (the same?) problem. Technician came and took off the cover inside the freezer and showed me that the defroster had burnt out (and destroyed some of the freezer lining - about 10 cms). I'm now waiting for him to get parts and something to repair the insulation.
    I'm less than impressed that this expensive fridge has such a problem after only four years! And I am worried about the extent of obvious burning inside my freezer - completely invisible until the internal panel is removed.
    Waiting for the fix is annoying since the thing beeps about every 8 - 10 hours!
  • shaynermac Jan 19, 2009
    I could guess there is a fan issue in the fridge compartment (freezer fan ok, hence the freezer getting cold). I just replaced my fan after having the same fault - however, I used a cheap and nasty PC fan after getting quote for $79 for a replacement F&P. The fridge now gets cold, but I"m getting the alarms sounding (in the middle of the night!, it's like it knows what time it is) - have another fan now that might fix it...
  • shane kammermann Nov 24, 2011
    same symptoms. any help??
    Champion:
    Habit-Forming:
  • 279 Answers
Firstly you must totally defrost the unit, turn it off empty it & leave the doors open for at least a day or overnight, if the fans are working then ice is blocking the return air duct.
Posted on Nov 30, 2011
  • Fisher and P... Master
  • 43,501 Answers
Posted on Aug 12, 2010
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
I have a fridege freezer - model no: E522B. The light inside the fridge has gone. The fridge and the top part of the freezer are not working. the bottom part of the freezer is cold.
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 16, 2011 | Fisher and Paykel Refrigerators
I have a Fisher & Paykel E522B fridge that has suddenly stopped cooling.....it appears that the compressor is still working but both the fridge and freezer are warm.....as we live in a remote area of...
Check fans in freezer and near compressor. Is compressor running continuously or clicking on and off? If fans are running and compressor is running continuously, your problem is most likely within sealed system. That would require a technician and may not be cost effective to repair.
Sep 23, 2017 | Fisher and Paykel Active Smart E522B...
Fridge compartment not cooling. Freezer seems OK. Fisher & Paykel - model E522B
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 07, 2011 | Fisher and Paykel Icon E522B Bottom...
Freezer nice but fridge is very warm
When fridge or freezer compressor is running but contents are not cold, feel the black radiator with the hand. Basically if the radiator is cold there is no gas or a bad blockage or a leak.( Radiator must be nice and warm on one 1/3 of its length.).
Dec 13, 2010 | Fisher and Paykel Active Smart E522B...
I have an active smart fridge freezer. The freezer seems ok but the fridge has stopped working but it doesent get cold. how can it be fixed. It is only 18 months old.
Check fan in the freezer
Also check auto defrost (ice on the freezer coils anot allowing
air to the fridge.)
If so go to appliance parts store to learn the parts to fix auto defrost.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Fisher and Paykel Active Smart E522B...
Zanussi Z87 problem
my fridege needed defrosting for a couple of days maybe this is the problem with yours.
Sep 22, 2008 | Zanussi FJS1225W Front Load Washer
Freezer and fridge to cold setting does not seem to work
the thermostat faulty or sensing piece not against the evaporator.check that the thermostat supplied is for the right fridge.eg:that is not a freezer stat that is installed in the fridge compartment.
Nov 05, 2007 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
548 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
