Question about Dell PowerEdge 2600 Server
Power light Sometimes i've seen that power light shows Orange which is generally shows Blue. Is it a problem if yes then plz tell me the soluation
    Novelist:
    Scholar:
  • 104 Answers
Are you referring to to Power LED or the System Status Indicator cause what I can remember from that particular model Dell server thst system status indicator was blue! Use this page to help identify what exactly is showing up as orange(or amber)! http://support.dell.com/support/edocs/systems/pe2600/en/sm/beep.htm#1057698 If it is the system status you'll need to go over the other indicators to troubleshoot what exactly is causing the problem! regards, babb
Posted on May 03, 2007
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
Power wont turn on..battery led flash orange
Remove battery. Maybe faulty? Try another cord/charger with the EXACT same specs. Reseat the Memory Mods. has the AC jack been damaged by pulling on the cord? Try plug in and at the laptop's AC jack "wiggle" the AC jack plug. Any change?
Jan 04, 2013 | Toshiba Satellite U305-S2804 Laptop
How can i tell the battery on my dsc-hx9v is fully charged?
Yes! mine works the same way, when fully charged it cuts power to the battery.
Jul 15, 2012 | Sony Cyber-Shot DSC-HX9V Digital Camera
I previously had a problem with my Netbook power jack on the side of the computer, but it seems to be fixed now. When I plug the adapter into the computer, the orange light comes on showing that it's...
I guess it depends on why your power jack was dameged at first.
If the old power jack was replaced after any electric accidents, this current problem can be caused by your damaged motherboard.
(After shock, the motherboard can still perform ok for a while. I've seen it.)
Or sometimes, rarely the battery can cause it. I don't know why but, that's what I've heard from laptop manufactuers.
To find out, please, take out the battery and plug in AC power adapter and try it again.
I hope it helps you.
May 27, 2011 | Acer Aspire One PC Notebook
My temperature gauge turned from a blue light with the temperature showing to an orange light with a picture of a car with arrows pointing left & right inside.... what does this mean?
when the blue light is on its telling you that the engine is COLD and not to use full power.the other warning light is telling you that you should check the water system for fluid/levels/airlock.
Jan 07, 2011 | 2002 Volkswagen Beetle Turbo S
Vizio tv orange light on, not blue, won't bring up picture
if orange it is on stand by mode ,the cable that you changed is it power cable if yes then you used wrong one it may affect, i think you need to check power supply board . also get other opinion too. good luck
Apr 29, 2010 | Vizio L32 32 in. LCD HDTV
Trying to fit G202 electronic ignition to G11 Charade. The G202 coil has blue/brown wire and black/blue. G202 distributor has black/brown wire and black. Can you tell me where these wires should go?
The colour coded wires seem to differ at randomn. To identify the cables:
Dizzy:- use a multimeter set on ohms.. When you measure about 3 meg ohms, your red probe is on the +ve wire and the black probe is the signal to the coil.
For the coil, it hard to measure the primary resistance so the general convemtion is looking at the pins on the coil with the taper at the top, the +ve is on the right and the signal (coil -ve) is on the left. Sometimes you'll notice one of the wires on the coil is a thicker gauge, which is generally the +ve.
Jul 30, 2008 | 1990 Daihatsu Charade
Dell 2200MP Powers off
I have 2200MP projector that when you turn it on,it clicks about 8 to 10 times and then the power seams to turn on, but the lamp light light comes on and nothing lights up. it will shut down after that, with the green light still flashing. What could be the problem? Roger
Jul 28, 2008 | Dell 2200MP Multimedia Projector
Dell PowerEdge 2600 Server Logo
1,189 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
