Question about Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop
For some reason my personal computer at home stopped running windows vista and asks if I want to start the operating system in safe mode or normal mode.  When either option is chosen I get a blue screen that ends with "technical info:  *** stop: oxooooc1f5(oxoooooooo,oxoooooooo,oxoooooooo,oxoooooooo)
  • 42 Answers
Everything I have researched states that your problem is with the installation of SP1 for Vista. Unfortunately the remedy is a reinstall of the operating system.
Posted on Dec 30, 2008
What does starting in safe mode acconplish?
Booting in safe mode simply launches the operating system with minimal services enabled, usually no network availability, and a limited ability of usage, safe mode is used when diagnosing possible threats or for emergncy data access. In the event that the computer has stopped you from gaining access to it. A computer should never forcefully start in safe mode, it is an option usually selected on a black and white screen, start normally or start in safe mode, or start in safe mode with network. Hope this explains is a little better
Jun 14, 2014 | Microsoft Windows 7 Home Premium Operating...
WHERE DO I FIND SAFE MODE IN LAPTOP OF HP 6735s
Enter Safe Mode at startup Follow the steps below to start Windows Vista in Safe Mode.
  1. Remove all CDs and DVDs from the computer.
  2. Restart the computer.
  3. At the first screen on restart, before the HP or Windows logo appears, press the f8 key repeatedly.
  4. When prompted, select the Safe Mode with Networking option.
  5. Log onto the computer with a user account that has administrator rights.
Enter Safe Mode when PC is operating If the computer can boot into the Vista operating system, follow the steps below to enter Safe Mode.
  1. Click Start , type msconfig in the search field, and then press the enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Diagnostic startup .
  3. On the Boot tab, select Safe boot and click OK .
  4. When prompted, click Restart to start the computer in Safe Mode. If the computer does not restart automatically, press the Power button to turn the power on.
  5. On the Tools tab of the System Configuration window, select and launch the desired diagnostic tool.
The computer is now operating in Safe Mode. Exit the Safe Mode After completing the required troubleshooting and repair, follow the steps below to exit Safe Mode and return to normal operation.
  1. Click Start , type msconfig in the search field, and then press enter to open the System Configuration window.
  2. On the General tab of the System Configuration window, select Normal startup and click OK .
The computer restarts in the normal mode.
May 18, 2012 | HP Compaq 6735s Notebook
Cannot start up vista keep getting message configuring updates then it shuts down
Hi friend,
You should run in safe some for start the window...you need to press F8..then computer will ask you for safe mode then you need to select the same mode...then computer will start in same mode then shut down and restart again...then it will work....if it is not working ..you need to install the window vista again...
Jan 01, 2010 | Microsoft Windows Vista Ultimate Edition
I had my laptop fixed 6 months ago and i was told i no longer have safe mode. I recently made a mistake and set my computer to start in safe mode. Now i can't get it back to normal mode. The screen says...
who ever fixed your laptop must has done some thing that has led you to this issue....it's just not possible that you wont have Safe Mode, it's one of the inbuilt safety system of Windows OS....press F8 to get into the option to go to Safe Mode or.....Normal mode of operation.....
You need to press F8 before the Windows screen appears...after you switch ON your laptop.
Dec 10, 2009 | Microsoft Windows Vista Home Premium...
I have a toshiba A205 5813 that will only function in safe mode. None of the drivers will come on in normal mode resulting in a black screen with the cursor when i load it up. I tried running the chkdsk...
Have you tried running repair my computer and system restore, either from the F8 menu or from a recovery disk? Try that to begin with, or run startup repair.
Otherwise, some good suggestions in this post. unfortuanately, you're not alone.
Among them this one:
A simple solution to resolve this black MS screen follow the below
steps:
1- Run Vista with safe mode command prompt
2- Type “msconfig” and hit Enter key,
3- select “Diagnostic Sartup” option, click on Apply then OK
4- System will ask restart the PC, choose yes,
5- System will start logging off but it will stuck at this stage, force
your PC to shutdown by pressing and holding on the power button until it
is off
6- Start your PC “et Voila” it will work
Note:
- it is possible that some of your services will not start or function
properly (this is an other problem)
- This solution tested on Vista Home Premium 32bit OS
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Aug 29, 2009 | Microsoft Windows Vista Home Premium with...
HELP ME PLEASE
This normally comes up when the computer is not shut down properly..or some files got corrupted. Normally you also have a choice of Start Repair With Windows. If none of those work then the only thing you can do is reinstall your Vista.
Good Luck..
Mar 22, 2009 | Microsoft Windows Vista Home Basic for PC
Laptop stuck on screen "Windows is resuming"
First determine if windows is really hung.
Restart the laptop and keep pressing the F8 function key. You will get a menu. Try the safe mode option by selecting it with arrow keys and pressing enter. Click on Yes when it asks the question.
If Windows runs okay in safe mode, reboot and try starting normally without pressing any keys). If again it won't start, then go back to safe mode and when asked the Yes/No question, reply with a No and it will ask you to do a system restore. Just select a recent restore point say one or 2 days ago or the most recent and select restore. It will take some time and reboot the system. Now everything should be hopefully okay.
HTH,
Deboo
Jan 03, 2009 | Microsoft Windows Vista Home Premium with...
Unable to boot the computer
start the sys and press F8 KEY to go to safe mode.
then run chkdsk
Apr 03, 2008 | Microsoft Windows XP Home Edition
Compaq Presario SR1103WM-B (PC183B#ABA) PC Desktop Logo
201 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
