Copaq deskpro power problem but bringing standby light on the pannel and no power on when you press power botton.
  • 26 Answers
You may need to replace the power supply unit.
Posted on Dec 30, 2008
  • Diana Umukoro Dec 30, 2008
My sony kdl-46v3000 standby light blinks 5 times tv wont turn on
The TV enters standby mode when there is no signal for 30 seconds. https://docs.sony.com/release/KDL46V3000.pdf
I searched standby using Ctrl+F and found this information. It seems you should be able to bring it out of standby using the power button on the remote. You want to make sure there is an input connected and if it is connected to a PC that the PC isn't telling the TV to go into standby.
Try pressing the input button and changing inputs once you press the power button and the Standby is flashing.
If this doesn't work you may need to contact Sony Support.
1-800-222-SONY(7669)
Apr 10, 2014 | Sony Bravia V-Series KDL-46V 46 in. LCD...
Sony music hi fi system mhc-gzr88d show only demo not started
If only demo mode is playing,it's mean set is in standby mode.Normally
in standby mode it can't be operated.You have to power on the set by pressing power botton during demo mode.Once it gets power on,it will
start to work according to user required function.If the set not get power on after pressing power botton,then it's an electrical problem
and need to visit your nearby repairing centre.
Oct 17, 2012 | Sony MHC-GZR88D USB MINI DVD HI-FI SYSTEM...
I try to turn my computer on but no luck, the little green light in the back is on, does that mean anything?
The green light indicates that the power supply is standby, if you press power botton and PC doesn't turn on, the simplest failure could be a defective power botton, also at the worst case you could have a defective power supply or motherboard.
Feb 18, 2011 | HP Hewlett Packard Pavilion Slimline...
Copaq x09 - drive light and power light are on, but nothing else happens- no sound no video- nothing
well its a gaming computer. meaning that is was custom build. it could be that your sound and graphic card are not secured in place. take off the side pannel and do this.
Sep 25, 2009 | Compaq X09 Gaming (DE410031934163) PC...
I can't swith my Acer laptop on. There is a yellow
REMOVE THE BATTERY AND ALL THE POWER SOURCE IN 20SEC THEN POWER IT AGAIN BUT YOU HAVE TO PRESS THE POWER BOTTON IN 3-5SEC.IF NOTHINGS HAPPEN YOUR UNIT ARE TOTALY POWER DOWN IT'S IN STANDBY MODE
Aug 18, 2009 | Acer Aspire 5720-6661 Notebook PC
Eror code4
It is switch that you need to push to enter into service mode. It is located inside the front door right above the fixxing unit next to the total meter.. It is a small Pin hole with a botton behind the cover. Most people use a paper clip to press the botton.Once you press the Botton there will be showing on the display pannel a "$" sign. Procede in to service mode... Good Luck
Jun 26, 2009 | Canon NP 6050 Copier
I have a xv n330 dvd player and it says lock when I try to take out the dvd in the player and it says lock.
When you press the eject botton while pressing down the stop botton on the unit in
standby mode, the tray lock function is activated. The disc tray
cannot be opened or closed in this status. To release this
status, press the eject botton while pressing down the stop botton on the unit in standby
mode.
Mar 01, 2009 | JVC XV-N330
Ricoh 3245c code is SC542
A SC542 error is a fuser problem. Did you have a power problem? You can try to reset it by turning the copier "ON" and once you have the code displayed on the screen.... Press the Yellow clear botton once - then the #'s 1 - 0 - 7, one at a time then press the Red Stop botton till the display changes..... Once, it changes turn the Main Power Off, not the one on the control pannel. Then turn it back "ON" and that should take care of it for you.... If it did not, you may have some more problems that can not be reset till they are repaired.. Good Luck
Jan 28, 2009 | Ricoh Aficio 450 Copier
Change number of rings to answer on iRC3170 fax
I believe, you just have to open the doors on the control pannel. It will show you more funcation of the fax. There should be a botton that say's "Data Entery" press it once and the display changes. Next you use the arrow bottons on the control pannel to move in that mode. Scroll down to Fax Setting and press the OK botton and scroll some more till you see number of rings and change it from 5 to 2 rings. Then press OK or Set, the press Stop/Rest twice and you should be done. It's alot hard to explain then doing it. It's called panich botton pushing..... Good luck
Jan 01, 2009 | Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
