Question about HP Pavilion a620n (PC028A) PC Desktop
Windows Virtual Memory Minimum is Low
Sometime while working on my pc, I get the following pop-up:
"Windows Virtual Memory Minimum is Low" -- Your system is low on virtual memory. Windows is increasing the size of your virtual memory paging file. During this process, memory requests for some applications may be denied. for more information, see help.
After a short time, the message goes away without any apparent change, until the next time I get the pop-up.
Is this normal? Or, what is the problem?
Desktop is a:
HP Pavilion a620n
AMD Athlon (tn) XP3200+
220 GHz, 448 MB of RAM
System :
Microsoft Windows XP
Hope Edition, Version 2002, Service Pack 2
  • kelly89 Feb 17, 2009
    i only run a xp 284mb ram i want to know how i can get more and what it means by my virtual memory is low and i cant play games becouse of these problems.
    Scholar:
  • 149 Answers
Fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Posted on Dec 30, 2008
  • 26 Answers
You may run low on memory when using lots of programs at once. The paging file can be increased in size to increase performance. You may want to buy a card with additional memory (RAM). Take the serial no and model to any PC store and they should be able to supply the right card. Then just install it in the spare slot inside your PC or get them to do it.
  • 104 Answers
You need to increase your virtual memory manually. Do the following
My computer >Right click > Properties > Advance > Performance Setting > Advance / Change
then increase the Number there (eg. 750) then Press SET then OK
Thats all you need to do!
Windows-virtual memory minimum too low. your system is low on virtualmemory.windows is increasing the size of your virtual memory plugin file.during this process,memory request for some applications maybe...
Right-click 'My Computer' and select properties.
Click 'Advanced' tab.
Click Settings button.
Click 'Advanced' tab. Click 'Change' button.
Select 'System managed size' and click 'Set' button.
Click 'OK' buttons to close all dialog windows.
This will correct your problem.
I hope will vote my answer.
Sep 12, 2011 | Computers & Internet
Tip
Solution to Virtual Memory Too Low Problem
This problem was reported by one of our readers that in spite of having a sufficient amount of RAM, he is running out of Virtual Memory and his Windows PC gives the following error:
Your system is low on virtual memory. To ensure that Windows runs properly, increase the size of your virtual memory paging file. For more information, see Help.
This is a common problem and you may have seen it if you are trying to open many heavy applications at the same time like Microsoft Office.
Let’s see what the causes are and what can be done at this stage.
Windows XP or Vista uses the concept of Virtual Memory that aims at providing the additional memory from the Hard Disk if most of the RAM of the computer is already occupied. This memory used from the Hard Disks is called Paging File. Windows reserve some part of the memory for this purpose only (this is one of the reasons why we see less memory than specified on the hard disk).
Virtual Memory also known as Page File or Swap File can be located at C:\pagefile.sys (it is system hidden and can be viewed if you Uncheck the option of “Hide Protected Operating System Files” inside Folder Options).
on Nov 17, 2008 | Microsoft Windows XP Professional With...
Low virtual memory and slow loading
Go back into the virtual memory settings, change the settings using the custom size adjustment.
Change the initial size to 650 and the maximum size to 1200, make sure nothig else is checked and click set and then ok and exit out of all windows and reboot the mechine. let me know what happens and if the bubble popup disapears. cheers.
Mar 25, 2010 | Computers & Internet
Virtual memory is low computer is very slow
hello frnd, you can increse your virtual memory manually...
1.go to properties of my computer
2.go to advance tab...
3. there is option to change virtual memory.
4.click on it and change virtual memory accordingly..
hope this will help you
Jun 30, 2009 | Dell Dimension 2400 PC Desktop
Low virtual memory
You have to increase the Virtual memory.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 04, 2009 | Dell Inspiron 1300 Notebook
Not Necessarily Not Enough Drive Its Your Virtual Memory May Just Be Set Low. Go To Your Start Menu And Right Click On It Scroll Down To Properties and Click It. Then Once The Prompt Box Pops Up Select The Advanced Tab. Your Gonna Wanna Locate The Performance Settings Button And Click It. Now Select The Advanced Tab And Go Down To Where It Says Virtual Memory, Click Change Up The Number Mines At 384 top and 1500 bottom. Now Click Set After Changing The Numbers And Select Ok,Ok,Ok On All Three Tabs. This Will Do It
Jan 14, 2009 | Maxtor One Touch II (EO1E200) 200 GB Hard...
Virtual memory
Your hard drive is getting to full for it to be used as virtual memory
When normal memory gets used up windows uses the hard drive as memory ans if insufficient room on hard drive is not available you get this message.
Solution.
1) delete programs from hard drive to create more space
2) Install new hard drive and transfer programs to it. creating more room on C drive
3) If hard drive is already partitioned and 2nd partition has a lot of free space transfer Virtual over to it.
Go to Start / Control panel Open The System folder go to "Advanced" "performance settings"
Then to "Advanced " Click on change and set Virtual memory to new disk.
Set maximum and minimum the same at 3 times the amount of normal memory you ave
Jan 05, 2009 | Computers & Internet
Virtual Memory Minimum Too Low
Hi!
Here's the procedure on how to increase virtual memory of your PC:
Right click on My Computer > left click on Properties > Advanced > Settings > Advanced. Under Virtual memory left click on Change.
Select (left click) on the Drive on wich Windows XP is installed. In most cases this will be Drive C.
Under Drive:
Space available: Select the radio button labeled: Custom size:
To play it safe, in both the Initial (MB)size: and Maximun size: dialogue boxes type 2560 (i.e. allocate 2.5GB for the pagefile) provided you have the free memory space to spare. If you don't have enough free memory available enter the amount of memory you can spare, and meanwhile seriously consider getting a larger Hard Drive.
Mine is set to 4096MB (4GB), max. allowed by XP. This may seem like quite a lot, but the reason for this is that recent games now require a lot more real and virtual memory to function correctly, even if you have 2GB of RAM. Having a larger pagefile size does not hurt performance as such; it only takes up a bit of additional disk space.
After setting the new page file size left click on
OK > OK > OK. Then restart the computer.
Dec 21, 2008 | Microsoft Windows XP Professional With...
Nintendo DS lite game card
there several steps like these....
may be the virtual memory is low.... you trying increasing virtual memory..
this can be done by following
1. go 2 control panel,system,advanced tab
2. in performance option click settings
3.go to advanced
4. go to virtual memory option there click change select your operating system drive and increase the virtual memory minimum for 700 and max to 900... give ok
and then have check...
if same problem persists may be ram u r using is low upgrade your ram to atleast 512mb ram
or
may be you are using the old version of directx... install latest version of directx ( atleast you install directx9.0c)
or may be operating system problem(may be due virus attack system files have became unstable) try reinstalling it...
Jan 16, 2008 | Computers & Internet
HP Pavilion a620n (PC028A) PC Desktop Logo
242 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
