Question about Compaq Presario 700 470024-192 Notebook
VEO --vista program
Moved my veo camera from home pc to my laptop which is programed with vista and will not allow me to download this program. can I solve this problem?
  • SoleAngelus May 11, 2010
    Yeah we need more inforation, what programme, what error message if any?
  • Dan rogers
    Dan rogers May 11, 2010
    what error messager are you getting? What are you trying to download? We need more info
Need Vista driver for Veo Stingray
Just as a matter of interest see what happens when you test your webcam here - hit "allow" in top window and see if your webcam fires up in the left hand window
http://www.testmycam.com/
This is a long shot but may be worth a try.
There is no Vista driver I could find - you can try to run it in compatibility mode whichever your old system was
http://download.cnet.com/Veo-Stingray-Connect-Web-Camera/3000-18489_4-69767.html
Don't run the program but save it.
Browse to that directory, right click on setup, properties, compatibility, set it to your choice or xp sp2 compat. close the properties. Install.
Aug 09, 2009 | Veo Stingray
Veo web cam
Normal 0 You need to go to the manufactures site and download the VISTA driver for the camera. Then follow the info below to install the program.
Try disconnecting the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Hope this helps. Bud
Aug 08, 2008 | Veo V500000 Webcam
Webcam
Jul 19, 2008 | Veo Advanced Connect Webcam
Veo cam
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Jul 07, 2008 | Veo Advanced Connect Webcam
Veo blue web cam not compatible
Jun 22, 2008 | Veo Connect Webcam
Veo stingray cam problem.
First you should check to see if the camera is Vista ready meaning you wouldn't need the installation cd. If its not vista ready try to manually install the camera by left clicking the the camera when it pops up as new hardware. You can also leave it connected to you pc for a few minutes which may allow it to self install; or check the website for the camera and see if they have a file where you can install the cd.
Apr 28, 2008 | Veo Stingray
Veo Stingray web cam
This fix will work for all of the VEO Stingray problems because it gives a good driver download site and it tells you step by step how to get your cam to work with VISTA Good Luck and let me know if this fixed your problems.
1.Go to this site and download the driver you need: http://www.softsci.com/veodrivers.htm
2.Download it to your desktop
3. Don't unzip, install, or plug in your cam yet
4.Search for this in your start menu: Program Compatibility Wizard
5. Of the three choices click the one that says look for the program manually
6. Choose the option for XP
7. Choose the 680 x 420 or whatever it is not the 256 colors
8. Choose to run as administrator
9. Click next and it should change your screen to a real big resolution and then it will start to install the driver
10. Go through the install wizard
11. After it has loaded plug in your camera
12. Try a program that it is supposed to work with
13. Finish the Compatibility Wizard
now everything should work for your cam.
This works with all of your programs that vista will not run.
Dec 28, 2007 | Veo Stingray
Not compatable
Dec 27, 2007 | Veo Stingray
Web cam connection
Nov 07, 2007 | Veo Stingray
Veo webcam drivers
Hi mjay
driver related problems can be solved by this program: http://tinyurl.com/m2hrabd. enjoy
Oct 12, 2007 | Veo Advanced Connect Webcam
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
