Cd player spins and then shuts off.
I have a three disc sony cd player which starts to spin but shuts down and no music plays
  • Anonymous Feb 04, 2009
    i have a sony boom box CDF-454,,,my cd was also spining then shuts off ,,,so i used a little hyderx proxide and a cue tip then took a little terry soft cloth and wiped the eye beam ,,,and so far it has been working ,i can now listen to my cd"s again
    Problem Solver:
  • 18 Answers
It could be that the lens needs to be cleaned. best soltion is to go to an elctronic store and ask them for a lens cleaner it should be very cheap if that doesnt solve your problem then ill try to find another solution
Posted on Jan 09, 2009
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
Wont spin or play discs
Two possibilities, The Spindle motor need lubrication or the unit is in such condition that the pickup can not focus on the disc. This happen if the spindle platter goes out of specs- they slip down mostly. The CD olayer wants to get a Focus OK signal before the disc is told to spin.
Sep 29, 2012 | Sony Mxd-d5c Cd Changer Rare
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
Apr 14, 2012 | Sony CDP-CX300 CD Player
The CD player will play some purchased CD-s but will not play others. The ones that it will not play do NOT iniate the disc motor but a click is heard and the display reads NO DISC. I have cleaned the...
If you can disassemble the CAP(disc holder) and place it on the disc while it is on the spindle and at the same time push the (hidden)lid switch you will see the lazer"s lens move up and down while trying to focus on the disc. If the lazer see's the disk it will tell the motor to turn. If it dosn't see the disc it will not turn the motor. Some model will kick the disc to spin a little while trying to see the disc. This type of player can be tricked into seeing the disc if you spin the disc a little by hand when the lazer's lens is moving up and down. At that point in time it might see the disc and take over the motor and spin up to normal speed. If the disc is an illeagal copy sold as a original the quality of the disc could be the cause. If the player is very clean (no small hairs stuck to the glue that holds the lens in place) (never clean with a cotton swab, use a shammie swab with rubbing alcohol or isopropal 99%) the problem could also be that the lazer is just not strong enough and the whole lazer-motor assemble should be replaced. Older units could use 1 drop of light motor oil on the motor shaft at the bearing to help start the motor when the system kicks the disc to spin. If the player reads the disc at the time you manually spin the disc maybe a good cleaning and oiling is all that is needed. The disc spins clockwise. if the disk spins counter clockwise replace the whole assemble. Maybe simpler, just give the disc a good clockwise spin and quickly close the door and push play while the disc is still spinning. if it starts, there you go. Don't use caned air on the lazer assemble. it will blow the dirt further into the lazer mechanism under the lens and make matters worse! Good luck!!
Oct 29, 2010 | Sony CFD-G50 Cassette/CD Boombox
My cd player D-FJ003 says "no disc" now whenever I put any disc in. It was working fine before.
I have two of these players now and i know what this is. It is because of the disc holder. It has been pressed down to the bottom and no longer lets the motor spin the disc. The fix is to carefully pry off the small disc holder that spins and find a place where it will spin freely then apply superglue to the center of it and very carefully sliding it back on making sure its not too far down as to not play. Let the glue dry for a long time and carefully put a disc on and see if it plays. This worked with mine but i kind of broke it in other ways and didnt let the glue dry fully so its still kind of scetchy so i bought another on on ebay for like $10.
Feb 17, 2010 | Sony Walkman D-FJ003 CD Player
CD player stopped working on Sony ICF-CD831 PSYC Clock Radio/CD P
I've been able to prolong the life on mine by doing this:
Insert the disc, then spin it by hand and quickly close the door and hit play.
It's always worth using a laser cleaner first, as it may just be dirty and stops spinning because it cannot read the disc.
Apr 26, 2009 | Sony PSYC ICF-CD831 Clock Radio
My ford mondeo 6X CD Sony is playing up all the time with original c.d's Can you help showing change cd check cd then suddenly works Do i need a c.d. cleaner?
The problem maybe that the drive gear that spins the disc is sticky. I had same problem, take cd unti out remove front facia then remove cradle that locks cd into dash. This give access to 4 screws, remove top lid on cd and temp connect facia and cd back in car load cd and watch to see if it spins up if not spin gently with finger. If it plays ok remove and gently oil between black drive disc and motor. Play cd again hopefully this will resolve problem.
Make sure laser is clean of any oil that may have spun off disc.
Best of luck it worked for me.
Apr 20, 2009 | Sony Audio Players & Recorders
Sony CD player C305 not playing
The laser or spin motor could be faulty.
Take it to a service centre for professional help.
John
Dec 15, 2007 | Sony CDP-CE375 5-Disc CD Changer
545 people viewed this question
 Grubhead
Grubhead
