Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
IMAGE TOO DARK ON GEI GRAPHIC ZOOMER POSTER BANNER SYSTEM
ghend74 on Dec 30, 2008
I HAVE A 1824 GRAPHIC ZOOMER Q205. THE COPIER IS USED FOR CREATING LARGE BANNERS FROM SMALL ORIGINALS. THE MACHINE SEEMS TO ONLY OUTPUT COPIES THAT ARE ALMOST "BLACK" WITH TONER AND THE SWITCH TO ADJUST THE IMAGE QUALITY EITHER LIGHTER OR DARKER DOESN'T SEEM TO EFFECT THE IMAGE QUALITY MUCH AT ALL. IN THE DARK MODE IT IS VERY DARK IN THE LIGHT MODE IT IS JUST A LITTLE LIGHTER BUT STILL CANNOT MAKE OUT THE IMAGE, THE ENTIRE PAGE IS BLACK.
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 04, 2009
Not Rated)
jpd8
Rank: Wiz
Rating: 84%, 45 votes
First I would give the optical area a good cleaning --- mirrors, lens, etc.. If this device has the 'slide' adjust for the image quality, the slide may have come out of the holder. Try seeming if the slide is seated properly. If this is the 'thumb / circle ' adjust, the POT ( value adjust on the board) may need to be reset. There is always the chance the the board is cracked or has a cold solider joint (pins) for the adjuster. IF you are inclined, that the cover off and check for crack, if no crack heat and re-solider the pins for the adjust switch.
Was this helpful?
Yes
No
Related Problems
I HAVE A 1824 GRAPHIC ZOOMER Q205. THE COPIER IS USED FOR...
I have a Konica 7030 photocopier. f-26-1 code came up what...
Can you Help with these Copier problems?
Error Code E075-004 on a clc 1000 I...
Solve
Error Code E075-004 on a clc 1000 I have Re-position the transfer belt but I keep getting this error... (More)
konica 7130 error
Solve
i try to copy after processing error call service center f-28-3,please help me to solve this problem... (More)
9-345 wate problem
Solve
9-345 wate problem
MFC-290c Brother printer magenta...
Solve
The MFC-290c Brother printer magenta color is not printing. I have had the printer clean the... (More)
error code E002 cannon 6612...
Solve
cannon 6612 phopto coppier error code e002
Sponsored Links
Describe your Office problem:
Top Copier Experts
Rank: Guru Guru
Solutions: 703
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more Copier Experts
Top Copiers & Faxe Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
