Question about Samsung HL-R4264W 42" DLP HDTV
Dark transperant vertical line, left side of screen
Replaced color wheel because of noise on a samsung 42" dlp. After reassembling color was great no problems, no noise. However now there is a faint transperant darker line on left side of screen, about an inch wide (vertical). At first I thought a wire was blocking the lens or color wheel. Disassembled, nothing was blocking either of them. Any ideas??
  • bestilmyhear Dec 30, 2008
    Would replacing the light engine solve that problem?
  • 106 Answers
Your light tunnel is bad. This requires partial disassembly of the light engine. Suggest contacting a tech
Posted on Dec 30, 2008
  • tvguy171
    tvguy171 Dec 31, 2008
    Yes, but it would be less expensive to have the light tunnel replaced. The light tunnel can be ordered from samsung and is much less expensive
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
I have a Samsung dlp, the front LAMP flashes and there is a humming noise from the left side. What is the issue with th DLP?
Color Wheel. Look up your Model on this website
Encompass Parts Distribution they will list Part/number and their Prices. I found my lamp on Ebay for $85.00 and Ballast board for $65.00.
Also here on FixYa was a Post with Sevice Manual showing you how to Replace Color Wheel.
May 03, 2010 | Samsung HL-R4264W 42" DLP HDTV
Samsung DLP R&R Color wheel Model #HLR5078w
Samsung's digital light projection (DLP) televisions use a spinning color wheel to create the colors that are seen on the screen. If the color wheel becomes misaligned during use, it will become damaged and have to be replaced. Replacing the color wheel on a Samsung DLP television can be done at home, once a compatible-sized color wheel has been bought from a TV supply store.Replacing the color wheel yourself will void any Samsung warranty that might be in place, but is the only solution for getting the TV working again in as short a time as possible.
Put on the anti-static grounding strap to keep static electricity from damaging the internal components of the Samsung DLP TV. Turn the Samsung around so that the back is facing you. Make sure the Samsung is unplugged from the AC socket.
Use the Phillips screwdriver to remove all of the screws from the back panel. Put the screws aside. Pull off the back panel.
Loosen the two screws from each side of the projection bulb's case. Pull the projection bulb out. Put the projection bulb aside. Use the Phillips screwdriver to remove the two screws from the left side panel. Pull the side panel and the circuit board attached to it out carefully and put it down so that the cables attached to it have not been pulled out.
Take a picture of the power cable's position with the digital camera so that you can put it back correctly later. Pull the power cable out from inside of the Samsung's case so that the center panel is free to be pulled out. Remove the two large headed screws from the center panel with the Phillips screwdriver. Remove the top two screws holding the panel to the plastic case using the Phillips screwdriver.
5
Slowly slide the center unit out a few inches. Take a picture of the projector lens' positioning with the digital camera so that you can put it back correctly later. Unplug the two cables from the left side of the center panel. Unscrew the sensor switch using the Phillips screwdriver. Slide the center panel completely out of the Samsung and put it down on the clean cloth. Blow off the color wheel assembly with the compressed air.
6
Use the tweezers to remove the green plug from the top of the color wheel cover. Use the tweezers to remove the two cables at the side that are coming from the color wheel. Use the Phillips jeweler's screwdriver to remove the screws from the top, front and back of the color wheel cover. Slide the color wheel cover straight up to expose the color wheel.
7
Use the Phillips screwdriver to remove the three screws holding the color wheel to the color wheel assembly. Lift the color wheel up and out of the color wheel assembly and discard it.
8
Position the replacement color wheel in the color wheel assembly. Reassemble the color wheel and reassemble the color wheel assembly. Put the color wheel assembly back into position in the rear of the Samsung DLP TV. Reassemble the Samsung DLP TV. Plug the Samsung DLP TV back in for power. Turn the Samsung on and enjoy seeing the colors displayed properly again now that you have replaced the color wheel.
May 02, 2010 | Samsung HLR5064W DLP Projection TV
My Samsung 56 DLP picture lost is color and is making a buzzing noise which I suspect is the color wheel. The picture is now black
you need to change the color wheel
5
6
7
8
Feb 07, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
How do I change the color wheel on my samsung HL-P5663W. I have already removed the lamp and loosened screws for the lamp housing. Doesn't seem to want to come apart. Am I on the right track?
5
6
7
8
Jul 10, 2009 | Samsung DLP HL-P5663W 56" TV
My Samsung DLP TV HL-R4266W is making a noise when I Turn it off. It sounds like the fan is rubbing on something. I took the back off and all 3 fans look fine. Could the noise be the Color Wheel and is...
Yes, the Color Wheel would be the only thing left. I am not sure about this exact model but the Color Wheel in other Samsung models are replaceable.
Hope this helps,
Skyassoc
Jul 06, 2009 | Samsung HL-R4264W 42" DLP HDTV
Color wheel for Samsung HLR5688WX DLP TV
5
6
7
8
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
HLN507W Samsung DLp Horiz. lines
it sounds like the dmd board is failiing
Mar 13, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Samsung HL-R4264W 42" DLP HDTV Logo
364 people viewed this question
Henry  Thomas
Henry Thomas
