Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Lights stay on
I'm trying to figure out how to make the timer work. I've already set the time points in the right spots but lights stay on. g
    Genius:
  • 1,605 Answers
Manually turn the dial pass the red pointer. that shoudl shut-off the light.
if not, you have a defective timer.
if it does. follow the instruction set the gree pointer for the time to turn-on and set the red pointer to the time off.
turn the dial one or more revolution till the arrow head in the center align with the time of day in the center windows.
Posted on Dec 30, 2008
I've got a Heller 10-fin standing oil heater, H-2400T. I would love it if someone can show me where to find the online instruction manual for this. Or just explain how to make the timer function work....
G'Day
I have one of these Heller H-2400T heaters. To operate the timer try this: Plug into power and turn on. Set power control to either Low/Med/High. Set temperature control midway between Low & high.Rotate timer dial to the right to align time of day to the reference point. Ensure all of the red tabs are pulled out. Then push in the ones for the period you want the timer to operate. Works for me. Good luck
Jun 13, 2011 | Heating & Cooling
I cannot set my GE timer--15119----I have no instructions and have tried many times---I can't believe how difficult this timer is to set----
Here's what I found.
Pull up all of the little pins around the dial.
Push down all pins for the time that you want the light to stay on.
Leave pins up for all time that you want the light to stay off.
Rotate the dial to the current time of day.
Plug timer into wall.
Plug light into timer.
Ensure light is ON.
Gary
Feb 16, 2011 | General Electric GE 24-Hour Timer, 2-Pin...
I've set the time on/off and ive tried turning on manually but the lights wont turn on on exact time set. y? when i manually turn on the lights come on 2 hrs later or so, y doesnt it turn on right away?
If I understand correctly, you have an Intermatic timer.
The timer has a yellow dial that rotates around like a clock.
Does the manual override work?
If yes.
a) then the circuit has electricity
b) the lights are in working order
Does the clock rotate?
If yes
a) then the timer is probably good
b) the clock motor could be bad
c) the gears could be rusty and dirty
Do you have the current time set correctly?
Lift and rotate dial until current time lines up with silver pointer.
Do you have the trippers set on the correct time?
There are ON trippers and OFF trippers
Attach trippers to correct time
Tripper pins wear out
Suggestion: You sit in front of the timer and watch the trippers as they rotate to the bottom of the dial
When the trippers get to the bottom, they push a lever that turns lights on and off.
Look at the photo:
Here's a website that sells tripper pins and clock motors for Intermatic timers.
You can buy new trippers or clock motor
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
Answer this post if you still can't figure out the problem, or need more help.
Oct 23, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Can't seem to figure it out. Directions are not specific enough. We set "the time now", but the white/AM, dark/PM is weird. Please help w/ directions. We need the light for chicken house. Light on 5:00 AM...
What kind of Woods timer do you have?
Is the dial turning? The dial is the clock. And the clock needs electricity to work, just like alarm clock. If dial is not turning, the wiring is not right.
Does the manual override turn on the lights? Maybe the slider switch set to OFF? Set slider to "Timer" for timer functions to work.
Wall timer:
If you have 59017 wall timer, it has dark PM white AM. You rotate dial until correct time lines up with little triangle located on right side of center knob.
There are 48 plastic pins on dial ... when pins are moved out, the lights are off. For timer functions, set slide switch to 'Timer'
Correct wiring is needed for timer to work:
Timer black attaches to Hot wire from breaker box
Timer red attaches to wire going to Load (lights)
Timer white must attach to white Neutral (or if your box has no neutral, connect white to bare ground)
Timer green connects to bare ground
If wiring seems right but dial on front of timer is still not rotating, then reverse Timer red and Timer black and see if that sorts out problem.
If this is wrong Woods timer, please re-post question.
Oct 02, 2010 | Woods Hardware & Accessories
Timer will run when flipped on manually
THE YELLOW DIAL MOVES THE HAND STAYS IN THE SAME SPOT POINTED DOWN AND NEVER MOVES, THESE ARE A TUFF TIMER AND TO SET IT YOU MUST LIFT OUT ON THE YELLOW DIAL TO SET THE TIME AND THE DIAL SHOULD SPRING BACK TO THE GEAR TO RUN , MAKE SURE THE DIAL IS SET IN THE GEAR BY TURNING LIGHTLY LEFT AND RIGHT . LOOK ON THE BACK OF THE TIMER MOTOR AND MAKE SURE IT THE 208 - 277 VOLT . IF THATS THE VOLTAGE YOU ARE NEEDING FOR YOUR PUMP ONE MORE THING MAKE SURE THE GEAR FROM THE MOTOR IS MESHING WITH THE BIG GEAR THAT RUNS THE TIMER, THESE TIMERS GET RETURNED TO THE STORE WITH A BAD MOTOR IN THEM AND THEY JUST STICK THEM BACK ON THE SHELF.. IF YOU NEED A NEW TESTED ON I FOUND THEM HERE..YOU CAN LOOK THREW THE LITTLE WINDOW TO SEE THE GEARS TURNING ON THE CLOCK .. IF NOT ..Intermatic Timer Motor WG1573 / WG1573-5 clock POOL FIX ON EBAY TO INSTALL THIS MOTOR REMOVE SCREW ON LEFT AND JUST BACK SCREW ON RIGHT A FEW TURNS, TIMER WILL ROCK UP OUT OF BASE THIS WAY . UN-HOOK WIRES ONE AT A TIME AND INSTALL WIRES FROM NEW MOTOR ONE AT A TIME.. THESE TWO WHITE WIRES GO TO LINE 1 AND 2 THESE ARE THE WIRES THAT GO TO THE 220 VOLT BREAKER ... NEED MORE HELP JUST GIVE ME A BUZZ. .. VOTE PLEASE THANKS... JAY
Jan 09, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I have a turbochef C3 and it works fine. It heats up and stays hot, but i can't figure out how to program it to cook on a timer. The screen says "please wait - warming up - CC494*F IR 855*F" So...
the oven is not really able to cook on the fly,it is pre programmed so the times are set due to weight and mass.try to use the programs already set up and then trial and error will show which 1 to use,hope this helps
May 09, 2009 | TurboChef C3 Single Oven
..not able to set timer to come on and go off a certain time
the pin for the timer and be any color.
if you have the pin in the right place, and turn the timer dial to the time you plug into the wall and turn on the black switch on the side. it shoud work.
check the timer after couple of hours. and make sure the timer is running correctly.
chances are there is a flat spot on the timer. it stops at a certain spot.
hope that helps
Apr 09, 2009 | Intermatic & Lighted Dial Timer
SL5618 Heath Zenith lights on all the time and during the day...
i've install many automatic lights- none of them work 100% There are patterns with most of them (flip switch on,off,on) to make lights on constantly, but they should all turn off when you turn the switch off.
Apr 07, 2009 | Hardware & Accessories
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
133 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
