2000 Audi S3 Logo
adam patel Posted on Oct 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the tyre pressure for all tyres on a audi s3 2000
Randy Prevost
Level 3:
Guru:
  • Master 894 Answers
  • Posted on Oct 10, 2012
Randy Prevost
Master
Level 3:
Guru:
Answers
894
Questions
0
Helped
21744
Points
2612
Hi
Look on the side of the tire for the max psi.
Hope this helps
Randy
3 Related Answers
Arjun Komath
  • 1170 Answers
  • Posted on Mar 25, 2009
SOURCE: What are the correct tyre pressures for a 2008
Audi A3 Recommended Tyre Pressures 1.6 96 - Onwards 28 28 32 40 1.8 96 - Onwards 28 28 32 40 1.8 SE 96 - Onwards 28 28 32 40 1.8 Sport 96 - Onwards 28 28 32 40 1.8 T Sport 96 - Onwards 28 28 32 40 1.8 T Quattro Sport 00 - Onwards 28 28 32 40 S3 99 - Onwards 30 30 36 40 1.9 TDi - 110bhp 96 - Onwards 30 30 36 40 1.9 TDi - 130bhp 01 - Onwards 28 28 32 40
Anonymous
  • 5 Answers
  • Posted on Jun 27, 2010
SOURCE: recommended tyre pressure for 1993 audi 80
see the recommendation in the "refuel's place intake" (it;s an adhesive with the car sketch of the car's tires with pressures) in atmosphere or PSi it doesn't matter!
Anonymous
  • 196 Answers
  • Posted on Apr 05, 2011
SOURCE: my car picks up a vibration from rear at 60 to 80
Welcome to fixYa !
you might have the rear bush problem cause it handle the cars smoothly, ... moreover check the rims sometimes RIMS get curvy or erected( i dont have the word for it right now , meaning = bends) by jumps or bumps( or even if you cross a speed-breaker in high speed) that causes wobbling .. more over check for EXCELS. sometimes EXCELS cause these problem .
do write back for your problem is solved or did it remain unsolved !!
we are here to help you .!
best Regards
2answers
My Audi Q5 3.0 TDI shows the TPMS malfunction, and was not changing from gear 4 while driving. i stopped the car, switch off the car and changed gears which could change,but still wont move was towed.
hi
There is TPMS (tyre pressure monitoring system)
they are inside every tyre. Which tell the car about your tyre pressure. If they have failed or you have recently changed tyres where sensors are not placed properly then light will come on and most likely car will stop, due to safety issue.
Thanks
I have 2008 a4 Audi, message center reads tpms I know it's tire pressure but dont know how to reset, pressure in all 4 tires is exactly the same
Tyre pressure monitoring system could work in a few different ways and invariably needs special dedicated diagnostic equipment to locate faults and to reset. Handheld units are available fairly cheaply but not yet quite as cheaply as some of the diy code readers.
Problem could be a defective sensor or radio sender valve. System will need resetting every time the tyres are changed around the car or when a tyre is changed with some systems.
I have a 2007 A6 with 4 yokohama tires, recvntly my dashboard computer is showing a low tire pressure warning, so I checked all tires and inflated them to the reccomended pressure on the door 35 front 39...
It's a Tyres Monitoring Pressure (TMP) system ECU (Electronic Control Unit) temporary faulty. Run for few miles above 30 mph, and all the temporary faults of Tyres Monitoring Pressure (TMP) system ECU will dissappear themselves. Also you can access & erase the TMP system ECU for all Diagnostic Trouble Codes (DTC) memored, if you will connect a VW / Audi diagnostic equipment to the data link connector of the car.
2answers
Recommended tyre pressure for 1993 audi 80
The recommendation is 26 PSI front and rear tire pressure for the 1993 Audi 80.
See
http://www.etyres.co.uk/tyres/audi
Please rate this solution. Thanks.
1helpful
Correct tyre pressure
with standard tyres that came with the car see below: Standard Front: 28 Rear: 28 Loaded Front:32 Rear: 36
2helpful
What are the correct tyre pressures for a 2008 Audi A3 1.6 Petrol 5-door hatchback?
Misleading A4 Cab Tyre pressure
. M&S means mud and snow rated tites, this will be on the body of the tire.
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Audi Expert? Answer questions, earn points and help others
