Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
How would i switch mine over to hdtv source
I would like to switch my tv over to hdtv source for digital analog before Feb. 17 2009 help me to do this.
  • RCA Master
  • 5,138 Answers
If your set is HD you are Ready!
Posted on Dec 31, 2008
  • ladywinn
    ladywinn Dec 31, 2008
    HAPPY NEW YEAR!!!
Can't get all digital channels
There are several possibilities assuming you have an outdoor antenna with the amplification. You are too far from the transmitter or the station is still on a low power digital transmitter until the analog broadcasts end. Additionally, there may be buildings, hills or trees in the way. The first one is called the digital cliff - you either have enough signal for your tuner or you don't. Some stations may need to add transmitters to cover the secondary areas that could still receive the analog signal. The second possibility will either resolve on Feb 18 or June 12 or anywhere in between. (It will depend on your station and the Digital TV transistion delay bill. Some stations are changing frequencies with the transistion and can't go to full power until another analog station moves its frequency.) The last one can't be resolved.
If you have an indoor antenna, you can try moving it around to get better results. My household has an amplified outdoor antenna with a rotator to get the antenna to line up with the signal. We have two analog stations that give problems when we look for their digital signals. We hope the issue will resolve with the changeover since we have seen the signals on both stations improve when they wanted to broadcast football games.
Feb 07, 2009 | Initial HDTV-320 32 in. LCD TV
Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Jan 08, 2009 | Toshiba 24AF42 24" TV
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
No, unless you are receiving over cable or satellite. You will need a DTV converter box if you are using an antenna to receive Over The Air television signals. The Proscan has an analog only tuner, so the ATSC (digital) signals will not be visible.
tom
Jul 20, 2008 | Proscan PS27123 TV
Turned on my ilo RC-500 tv and i got an error message saying that this channel has an encryption on it
mine has done this as well, all you need to do is turn off the tv, unplug your cable going into the tv, turn the tv back on and switch the source to analog instead of digital. then you can plug the cable back in and BAM! hope this helps someone.
Jul 15, 2008 | Televison & Video
My JVC tv Is in digital and i want it in Analog
Look to see if your remote has a button with A/D on it. That is the button to press to switch back and forth between the analog and digital tuners.
Mar 28, 2008 | JVC HD-56G886 56" Rear Projection HDTV
Do I have an analog or digital TV ?
You have an ANALOG set. After 2/17/09, you will need to be connected to cable, satellite or get a convertor box to watch this set.
Mar 24, 2008 | Televison & Video
No sound through Panasonic SA-HT930 surround system
I've had similar problems in the past. With audio problems trace the problem from the source to the amp.
1. What output is the cable box using for audio, digital or analog?
2. Is there a setting in the cable box to switch between digital and analog?
3. Once you have determined the output of the cable box check to make sure that it's going into the right output on the panasonic
4. This is where the problem usually is...what is the receiver expecting for sound, analog or digital?
5. Switching between the sources...the sound should be on one of them.
Mar 17, 2008 | Panasonic sa-ht930 Home Theater Audio...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
