Question about Mintek DTV-263 26 in. LCD Television
No power to TV.
Wall outlet is working and the AC adapter's light is on but tv won't come on.
  • 1 more comment
  • scibekc Dec 30, 2008
    What's a dm board? On the back of the tv, it says not to open it due to risk of electrical shock. Our tv is a Mintek 26" LCD...DTV-263. It worked fine in the morning, later in the day it wouldn't come on. The AC adpter has a small green light lit.
    Thank you for your response. We have tried unplugging from the AC outlet, waiting some time and re-plugging the adapter again. It didn't help. Are there other possibilities??
    yes/no thanks for trying
    Sergeant:
    Novelist:
  • 326 Answers
Its not a power supply problem. its the problem of some faulty capacitors or short tracking on the main board. but i would advice you not to try working on your own on this board as first of all it requires a proper tecnical knowledge and second thing is it is hazardous as it has high voltages inside and can be fatal.contact a local technician to repair the main board.
Posted on Dec 30, 2008
    Sergeant:
    Champion:
  • 304 Answers
Try to plug the tv power cord into different outlet.
if the problem was still the same. you better call for a service man to check the unit.
    Genius:
  • 1,269 Answers
This sounds like a fuse was blown inside the TV's circuit board. If you don't wanna risk opening the cover, you need to ask assistance from a TV technician or bring the unit to the nearest electronic service center.
  • 104 Answers
If the TV is within the warranty you can get it repair free of cost. As your adapter is working fine the cap or the power board might have gone bad that can only be repaired by expert.
  Good Luck!
  • 10,594 Answers
Unplug AC adapter from AC outlet for couple of minutes and replug back then try.
  • Shahid Electronics
    Shahid Electronics Dec 30, 2008
    Other possibilities requires to apart the TV and required qualified Tv tech to examine it like its power supply board, back light inverter board testing etc.
  • 916 Answers
Check the dm board.
Klipsch soundbar (SB1) won't power on ... green light on power adaptor seems to trip and go off when I power on the SB
I have read that this may be due to the order in how the AC adapter is attached to the sound bar. After some research I found that you need to unplug the AC adapter from the wall and the sound bar and let it sit for about 15min. Then flip the power switch "ON" on the sound bar and connect the AC adapter to the rear of the sound bar. Lastly, plug the adapter into the power outlet.
Feb 21, 2013 | Klipsch Audio Players & Recorders
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
Tv won't turn on power indicator light not lit
As you mentioned the tv have problem with the power supply stage. Before suspecting for any intenal fault Chcek the following first. Remove the AC plug of the tv and connect the same in any other wall outlet. If then also it shows the same problem then its the powersupply board of your tv.
working on power supply board should be done by a skilled worker. Because there is risk of electric shock even if the power is disconnected. some of the capacitors will hold charge even if the power is not connected.
Here i have adde the link which will lead you the powesupply board.
Power supply board
Ajin
Apr 01, 2012 | Magnavox 32MF338B 32 in. LCD HDTV
WII IS ABOUT 2YEAR OLD.IT WILL NOT TURN ON....NOTHING
Wii - Power Problems
Please use the information below for all power-related issues with your Wii console. Some power problems are caused by unlicensed or damaged accessories (such as frayed wires on controllers, A/V cable, etc.). Avoid the use of these products.
Please select a topic:
No Power
    Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
      1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
      2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
      3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
      4. While you're waiting, check the AC Adapter for the following:
        • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
        • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
      5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. If the power light comes on and stays on, then it appears resetting the AC Adapter worked. If resetting the AC Adapter did not fix your power issues, please continue reading:
        • Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter (see above).
        • Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
        • Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position, make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
        • Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
        • Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
        • Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector). Click here for detailed instructions.
        • Once plugged in, check the power light on the Power button to see if the system is receiving power.
      If the power is still continually shutting off regularly, please click here for repair options. For this particular symptom, it is best to include your Wii console's AC Adapter with your system. This will help our technicians ensure they are able to resolve your issue.
Aug 22, 2011 | Nintendo Wii Console
Unplugged my 32LV67U to vacuum behind it and now it will not power up. Yellow LED keeps blinking and I waited several minutes but tv will not power up. Worked perfectly until I unplugged it. Called...
That wall outlet may have frequent surges so try another wall outlet see if it turns back on. If it turns on be sure to use a surge suppressor and never plug the TV directly into the wall outlet. The AC surges will kill the power supply of the TV in short time. See if there's a kill-switch near the ac adapter of the TV if there is turn it on.Get a surge protector/suppressor then try plugging it back in the wall. If still no power then the power board is already damaged, you can send the board too me and I'll repair it for you or seek your local repair center.
http://tvtechwork.webs.com/
Oct 18, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Wii console light won't come on
One of two common possible problems. Either 1) Your AC adapter needs to be reset or 2) Your AC Adapter is bad.
If it's not working, you can get a *new* NINTENDO brand AC adapter at the following page. Beware of cheaper knockoffs around the internet.
http://store.richspsxparts.com/ofniwiiacadr.html
May 24, 2010 | Nintendo Wii Console
Hooked up Wii console to TOSHIBA TV.....nothing.
Hello :
Most power problems with the Wii can be fixed by resetting the [AC] adapter. You can easily reset the [AC] adapter by following these steps:
It's also recommended you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
1:Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
2:Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
If resetting the AC Adapter did not fix your power problems, please continue reading:
3:Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC Adapter again (see above)
4:Check any accessories that connect to the Nintendo GameCube Controller ports or the USB ports of the Wii -- whether licensed or not -- for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. Remove any damaged products and try resetting the AC Adapter again (see above).
5:Make sure the Wii has good ventilation. Avoid operating the Wii while it's on carpeting or inside an enclosed space. If you have the Wii placed in a vertical position , make sure the vent on the bottom is lined up properly with the hole in the plastic stand and no foreign material is obstructing that hole.
6:Check the vents on the back and side of the Wii for dust build up. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vacuum cleaner with a soft brush attachment.
7:Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on to verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
8:Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Wii (the port is labeled 12V IN) and into a working wall outlet (not a power strip or surge protector).
9:Once plugged in, check the power light on the Power button to see if the system is receiving power
If that didn't help , then replace your Wii with new one if you still have the guarantee .
If this solution is helpful please click a thumbs-up rating below.
Best regards .
rate please !
Mar 23, 2010 | Nintendo Wii Console
No power The light does not come on. The game does not turn. The fan does not blow.
  • No Power
    1. Make sure that the words "Nintendo GameCube" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    2. Make sure the Nintendo GameCube has good ventilation. For best results, make sure that the system rests on an open, flat surface. Avoid operating the Nintendo GameCube while it's on carpeting or inside an enclosed space.
    3. Check the vents on the sides of the Nintendo GameCube for a build-up of dust. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
    4. Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC adaptor (see below).
    5. Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    6. Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Nintendo GameCube (the port is labeled DC 12V IN) and into a working wall outlet.
    7. Press the power button on the Nintendo GameCube and check to see that the red power light on the top of the Nintendo GameCube illuminates.
      If this fails, try resetting the AC adapter.
      1. Unplug/remove all accessories from the system (including game discs, memory cards, and all controllers), hookup cables, and the AC adapter from the outlet and Nintendo GameCube.
      2. Let the system rest for about 45 seconds. While you're waiting, check to see that the cords on the controllers, AC adaptor, and Stereo AV cables/Component Video cables (or RF Switch) are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
      3. After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Press the power button to see if the system works.
        • If the system works, turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (GameDisc, controller, Memory Card), there may be something defective with that accessory.
        • If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Control Deck or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
    8. If the power is continually shutting off after aprox. 30 minutes, listen to hear if the fan is working while the system is powered on. If the fan is not running, the problem will continue (Nintendo GameCube is avoiding overheating) and the system will need repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair.
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
Dec 21, 2009 | Nintendo GameCube Console
Can't turn wii back on
Did you unplug it from the Wii, or from the Wall Outlet? You need to unplug it from the wall outlet, not the Wii. If you haven't unplugged it from the wall outlet and left it unplugged for 5 to 10 minutes, then unplug it from the wall outlet and leave unplugged for a good 5 to 10 minutes.
This is a common problem with the Wii. Even if it's hooked up to a surge protector. If there was a power surge, or the power went out, etc...anything, this will happen. The problem is with the AC adapter, not the Wii itself, so power to the AC adapter needs to be cut off.
There is a circuit inside the AC adapter that needs to be reset. Unplug the AC adapter from the wall/surge protector outlet. Don't unlpug it from the Wii, it has to be at the outlet. You have to kill power to the adapter.
Unlpug it from the wall/surge protector outlet, and leave it unplugged for 5 or 10 minutes. This will kill power to the AC adapter, and give the circuit time to reset. When you plug the adapter back into the outlet after 5 or 10 minutes, the red led on the front should be lit up.
Dec 08, 2009 | Nintendo Wii Console
I moved my Wii to another room, connected it to the tv and the screen came on then went totally black. The power light doesnt come on.
First try another wall outlet.If not help unplug the AC adapter, then wait 30 min and plug it again.If this not help may your AC adapter is defective.
Oct 27, 2009 | Nintendo Wii Console
Mintek DTV-263 26 in. LCD Television Logo
37 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Jason Morris
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
