Computers & Internet Logo
varun mehta Posted on Oct 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The PSU of my 5yr old Lenovo Q series desktop got
The PSU of my 5yr old Lenovo Q series desktop got burnt.. I need to replace it without changing the Cabinet.. I have 2 problems regarding a new psu 1) PSU size 2) The cables are quite long in my old psu so i dont have any short lenghth issues whereas new psu's have short wires 3) Psu powers my Lcd monitor( well i can buy a power adapter for it) Now, what should i do??
Brian Sullivan
Level 3:
  • Computers & ... Master 27,725 Answers
  • Posted on Oct 11, 2012
Brian Sullivan
Level 3:
Answers
27725
Questions
Helped
5664230
Points
79191
Yes there are cables you can get to adapt to your current psu
http://www.ebay.com.au/itm/HP-Slimline-Desktop-Computer-Power-Supply-Adapter-Cable-/221009922774?pt=US_Power_Cables_Connectors&hash=item337537cad6
http://www.ebay.com.au/itm/Standard-20-24-pin-ATX-Power-Supply-HP-Slimline-Desktop-PC-Adapter-Cable-/251157669237?pt=LH_DefaultDomain_0&hash=item3a7a29e575
im not sure if these are whay you need
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
2 Related Answers
Anonymous
  • 1185 Answers
  • Posted on Jul 05, 2009
SOURCE: HP won't power on at all~PSU light blinking, then solid, then off
Dead short on the machine causing the power supply to go into shutdown (Fold Back Protection)
Remove all of the connectors coming from the power supply (Label them so that you know here they go back to on the Motherboard and the DVD etc (Including the processor fan one)
Place all of them back one at a time starting with the main one if the led stays on then plug in another till you locate the short.
If the led dies when you plug in the main MB connector then you are in deep brown stuff
All you can do then is to remove the Ram and any other unpluggable device to see if that is the cause
Anonymous
  • 6 Answers
  • Posted on Sep 25, 2009
SOURCE: I want to replace the PSU on a Dell XPS 710. How
Open up the back of the case, unplug the cables and pull it out.If you don't know where the PSU is, it's where the power switch pokes through your case.
1helpful
2answers
I rebuilt computer with new parts, now won't start up. No POST. Power LED lights up, no cpu fans spin, no beeps. Psu works with paper clip test. New mobo, ram, psu, cpu.
Check display without cabinet maybe motherboard getting short with cabinet and try new Power supply check all the power supply connectors connected or not .
1helpful
Lenovo desktop PC Power supply probems after changing voltage setting from 230V - 115V
If your country uses 240V mains then flicking the switch to 115V bypassed a voltage divider and probably blew the fuse in the power supply. If you are comfortable working with mains voltage, you can pop the PSU open and check the fuse. If it's blown then just get another one with the EXACT same ratings and you should be up and running again.
If it's not the fuse then you have bigger problems and it's time to replace the PSU. Any PSU should work as long as the wattage is the same as the original or higher.
Also, you could call Lenovo to see if the PC is under warranty. If so, the PSU is probably a user replaceable part, meaning they will send you a new one to put in and you just send the old one back.
Lenovo 3000 series desktop pc switch problem
I cannot argue with what you want. Since you did not tell the whole story, there is no way to answer your question.
1helpful
How do i find out which Lenovo model is my Desktop PC? Its a Lenovo ThinkCentre 9637-AA5.
1) Series:
It's a ThinkCentre M Series Desktop
2) Subseries:
ThinkCentre M55e
3) Machine Type:
9637
4) Model:
The Model Number will be right after ThinkCentre M55e-9637
It will be two numbers and a letter, or two letters and a number, or three letters.
Three characters. (symbol)
Some examples; 21B, 21H, 22U, 28s, 28y, B2F, B26, I2F, (i2F), I64, (i64), W2Y, W2Z, WJW, WJM
ThinkCentre M55e-9637-WJW
(Above is fictional. Just an example)
Regards,
joecoolvette
1helpful
Dear experts, I have an old IBM PC M55 desktop type 8142 . nowadays it randomly shutdown. I had checked PSU and cooling fan is OK. I eliminate windows/software/virus problems because in BIOS mode the...
It is very possible that it is the motherboard; they tend to be unstable, especially old voltage regulators that regulate the power to the CPU. With the number of things you have eliminated, I would agree that is the MoBo, and the solution would be to replace the MoBo.
Our Pavillions a610n won't power on. This has happened before and we were able to disconnect and then reconnect the power supply to get it running. I'm assuming we need to replace the power supply......
Bad PSU day: 13 year old PC, retired, at HP and legacy status.
the A series desktops are very very old, and no support now.
the problem is there is not just one PSU now,
they evolved the PSU ATX sec as things changed. in time.
any watts over 400 is ok, unless gaming and power sucking new, GPU card is added.
point 2: ive no idea at what is inside that case now
upgrades, add-in PCI slot cards, ext.? how may HDD.
or what. its old things change,
so Ill pretend nothing changed, ok/ and tell you what it has
and what to buy, buy more watts , as the bigger watt PSU is higher priced and more quality, built in. a $15 PSU is junk class.
Q1: is the power jack 20 or 24 pins.?
Q2 does it have IDE drives or SATA.
Q3 do you really use that floppy? and its silly PSU power cable.?
more watts never will hurt you or it.
ever go here.? newegg, nice , choices on left.
https://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007657%20600013999%20600479293&IsNodeId=1&bop=And&Order=PRICE&PageSize=36
and see the left side under TYPE.
that must match your needs,
  • first I buy quality,(and brand names) never china nonames.
  • then large fan
  • then type,
  • More watts gains you quality line 1 above. most times.
in that order. what matters to you , I could never guess
the large fan is quiet, if you like less noise,. bingo.
this?
Lucky you no relic IDE Drives, inside, more pain.
https://www.newegg.com/Product/Product.aspx?Item=9SIA9384673962
I have a 13 month old Acer Aspire ax1700 Desktop. Had turned it on yesterday and Fan was making lout noise. Today I turned it on to check it. Was on for about 10 minutes and it just turned off. There are 2...
It seems that the power supply unit has gone. If you power it on and nothing happens then obviously the psu has gone. The heat that you felt was the psu overheating because of no fan and hence no ventilation. The noise was of the faulty psu fan that got stuck or did not work and the psu got overheated and got burnt eventually. Please replace it with a new one as a repaired psu may work but you cant rely on it.
2helpful
PC dead. Replaced power supply. No lights. No nothing.
When that happens it is usually the motherboard.
To test parts you need a benchmark.
PSU can be tested using a multimeter.
Motherboard is tested using a tester like this one: PCI Test Card, PC Analyzer, Motherboard Test Card
Ram and CPU (CPU sometimes get damaged) are usually not damaged by this kind of problems, they can be tested mounting them on a working motherboard. For the RAM we also use a RAM tester that costs about $200.
Ensure also that the switch contacts to new motherboard are installed properly. A technician can test cabinet power switch using a multimeter, or carefully bridging with a screwdriver the switch on contacts on motherboard (do not do this unless you are sure about what you are doing)
Test the new PSU on a different socket, when a PSU blows , it may damage the main socket.
Also remember that new power supply units have two connectors. The big rectangular main one (24 pin) and a smaller 4 pins squared one.
As an home user you may not have access to testing equipment, therefore my suggestion is.
Ensure you are using the right PSU.
Ensure that the motherboard is connected to power switch.
Test the new PSU with a multimeter.
Examine the motherboard for blown or leaking components and burnt areas.
If you do not find anything, but the mainboard is still not working, then buy a motherboard-cpu bundle compatible with the PSU that you bought and assemble a new system inside the old cabinet.
Regards.
Repair psu for gx280
I have had several issues with this same problem, you may need a new power supply, because your old one may be failing and may need replacement.
My solution to this problem is that you may need to buy a need psu. I recommend either calling dell or buy a new psu.
2answers
HP D530 SFF, PSU replacement
You need to find out the motherboard make or a serial number. As this may have a slocket type fitted processor(on it's side) and makes you limited with fan types etc.
Grand Canyon Tech
Grand Canyon Tech
