Question about Neff 24 in. S5456 Built-in Dishwasher
Program stuck at 1, machine keeps running indefinitely
We have tried cleaning drains, etc. The program never progresses past 1. When we opn the door, the dishwasher stops running, but water has not drained.
    Novelist:
  • 114 Answers
SOUNDS LIKE THE TIMER CONTROL MAY BE BAD. IT COULD BE THE ELECTRICS OF THE TIMER OR GEARING THAT ARE BAD. PERSONALLY I DO NOT !!! RECOMEND TRYING TO TAKE APART AND REPAIRING ELECTRICAL TIMER COMPONENTS. (CLEANING CONTACTS I HAVE DONE TO GET A/C EQUIPMENT TO RUN FOR THE ELDERLY OR HEART PATEINTS UNTIL A NEW PART IS AVAILABLE... SHIPPED OVER-NIGHT) ALL CONTACTS !!! ARE DESIGNED TO AN EXACT THICKNESS AND TOLERANCE TO ACCOMIDATE THE AMPRESS LOAD/DRAW. A BAD CONTACT THAT IS CLEANED IS TEMPORARY AND IF TOO MUCH SURFACE IS REMOVED CAUSES HI-AMPREES AND EXCESIVE HEAT ... IT CAN BURNOUT THE MOTOR THAT IT IS CONTROLING DUE TO INSUFFICIENT VOLTAGE WHICH CAUSES HIGH AMPREES WHEN THE MOTOR RUNS. IF YOU DO DECIDE TO TRY IT ON YOUR OWN? MAKE SURE YOU NUMBER OR "COLOR CODE MARK" ALL WIRES AND CONECTIONS BEFORE YOU REMOVE ANY WIRES ... GOING TO YOUR LOCAL "APPLIANCE PARTS STORE" WITH TIMER PART IN HAND IS WHAT I RECOMEND ... MOST COUNTER SALESMEN WILL TEST THE PART FOR YOU. GOOD LUCK ...
Posted on May 03, 2007
SOURCE:
Laundry still heavily wet after machine finished program
Pump not working? lint or fluff stuck in the filter or drain , Drain hose kinked or blocked? Check for foreign objects coins etc stuck in the hoses under the machine.
Mar 21, 2017 | Washing Machines
Drain pump will not drain tub,but if i place drain hose on ground,tub drains with full hose.is the pump belt drive,or transmission shaft driven.thanks bob
check underneath but normally the pump is a stand alone unit at the bottom of the tub
it gets its power from the program board when it is progressed from wash to spin
problems that stop it from working mostly come from items stuck in the pump impeller preventing the motor from spinning
look for coins , hair pins , bra wires etc that get lodged in the pump housing
Oct 18, 2016 | Maytag Washing Machines
Why does the pump keep running and it won't spin?
check for a problem control board not selecting next program
May 24, 2015 | Washing Machines
My washing machine washed a load on the medium cycle but when it is time for it to drain the water it just stop the only thing it is doing is fulling back up with water and not doing anything else on
Not sure what you are saying, I assume the water is not pumping out at the end of the wash cycle. Is the water draining out at the end of each cycle? Is it spinning at all? Is the exhaust tubing clogged? Is the pump burned out or are you trying to pump it uphill too much. If it's stopping mid wash, try advancing it manually past where it's stuck and see if it continues. I have that problem, the tank fills with water and it gets stuck at the 6 minute changeover. It will run stuck at this point indefinitely if I let it. We just set a timer for the fill time, then manually advance it past this stopping point.
Sep 30, 2014 | Washing Machines
My 15 yr old Bosch d/w starts at 13 min & runs to 1, doesn't gets to CL. No water in or drain out.
IF IT ENDS UP WITH WATER SHOWING AT THE END OF EVERY WASH THEN THE DRAIN PUMP IS JAMMED OR FAILED THE DISHWASHER PROG WILL JUST KEEP LOOPING BACK TRYING TO DRAIN THE WATER.
Mar 04, 2017 | Bosch Dishwashers
Electrolux EWF1074 7kg washer stuck on drain cycle
The first thing I would check is the drain line, not for a blockage but to see if the drain line isn't pushed down in the drain so far that its below the level of the pump. If it is you'll have a siphon effect going and the machine will never advance past rinse
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 26, 2012 | Electrolux Washing Machines
Water coming out of washing machine
your drain valve is STUCK OPEN!
if you know how to open the valave at the rear panel, you just open it and clean the debris that stuck the diaphragm to OPN position!
Nov 06, 2010 | Washing Machines
My F&P GW611 washer gets stuck on the first shower rinse cycle. It just fulls, drains and spins until we 'Advance' to the next rinse stage. The machine washes, drains, spins etc no problems it just...
The fault is in the timer, the program controller is not moving up as there is a linkage failure in the mechanism.
It will be good to clean and see if the stepper motor is not slipping off the groove. If the motor is running clean and use a WD 40 to clean the gears and contacts.
Oct 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Gets stuck on timer and wont count down
We had a similar situation with our LG washer. It was not a timer problem.
The machine was not entering the spin cycle and was just stuck in limbo. A sensor or something was not being satisfied and allowing the progression to the next cycle. Our problem had to do with the drain line; it seemed as if it was air locked?? After lowering the drain line height (to reduce the head pressure), and manually draining some water out of the drainage cap (where the strainer is located) onto the floor, the sensor became satisfied and the machine completed its cycles properly.
What told me that it was not a timer issue was the fact that on different wash settings (normal, heavy, quick cycle), the machine timer would get stuck at different countdown points (22mins, 12mins, etc.).
Jan 17, 2009 | Washing Machines
Neff 24 in. S5456 Built-in Dishwasher Logo
164 people viewed this question
Top Neff Dishwashers Experts
vince
Marvin
Marvin
Lawrence Oravetz
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
