Question about Vivitar ViviCam 3785 Digital Camera
Any suggestions on what SD card to use with this camera?
I want to get an SD memory card but not sure what will work with this camera
  • noreen_mcder Dec 31, 2008
    The camera is a vivitar 3785 and it has a slot for a memory card just sounds like a lot of folks having a hard time with memory cards and just wanted to check before i purchase
  • nennachen Jan 18, 2009
    I can tell you for certain that a 16-GB card WILL NOT WORK with this camera.  I just bought the card and the red light comes on on the camera and won't turn off.  It just stays jammed.  I didn't know a 16-GB would be incompatible.  Now I have no idea what to get for it.
I put in a san disk ultra II 1.0 gb and it works fine. I don't know if it means anthing but my card is the breakable kind. You can break it down to go in a computer. I could not turn my camera off, I could not load pictures, it would tell me that my card is full and i was ready to throw it across the room. It works great now!!!
Posted on Jan 21, 2009
  • shawnee1 Jan 22, 2009
    If that wont work, try less than the 1.0. U can always take it to the store with u and ask them do they hav a card they can try in the camera 2 c if it will work be4 u buy it!!!
  • 122 Answers
Try going to the web site or find out who made the camera. It might not even have a memory card .
Posted on Dec 30, 2008
  • 1 more comment
  • john vecchione Dec 31, 2008
    i need more on the camera mabey more pics .
    sakar bought out vivitar corp so try sakar .com
    pc world .com retrvo .com on your camera has info on your camera.
Who can repair a Gateway DC-T50
Refer to the manual page below - note the last 2 items
If you take the camera and the card to a sales outlet the assistants are usually helpful
Inserting an SD Memory Card(Optional)
All images and video clips taken by the camera can be stored in an SD (Secure
Digital) Memory Card. Even if the camera's power is OFF, the images saved in the
SD Memory Card are not erased. An SD Memory Card can be repeatedly read and
written. You may also expand the memory capacity up to 512MB so that you can
store additional images and video clips.
1. Make sure the camera is off.
2. Slide the battery/SD Memory Card cover in the direction of the [OPEN] arrow.
3. Insert an SD Memory Card :
The front side of the memory card (printed
arrow) should face towards the front side
of the camera.
If the card cannot be inserted, check the
orientation.
4. Close the battery/SD Memory Card cover.
To remove the SD Memory Card, make sure
the camera is off. Open the battery/SD Memory Card card cover. Press
lightly on the edge of the memory card and it will eject.
Note:
If the camera is powered-on without the card, the "NO CARD" message appears on
the LCD monitor.
To prevent valuable data from being accidentally
erased from an SD Memory Card you can slide the
write-protected tab (on the side of the SD Memory
Card) to "LOCK".
To save, edit or erase data on an SD Memory Card,
you must unlock the card.
MultiMedia Card (MMC) can not be used.
You need to format an SD Memory Card before using it in this camera
Feb 19, 2015 | Gateway DC-T50 Digital Camera
My camera doesn't see SD 16GB anymore. Worked fine until a few days ago. SD works fine on PC
Try inspecting the memory card slot, eventually with a magnifying glass. Sometimes just a little bit of dust, a small paper or other debris, can block data transfer. Be sure al contacts on the card, but also in the camera are clean and shining. Never use sharp tools in or around a camera. Don't scratch the contact points.
And to make sure you can put pictures on a memory card, there must be space. If possible try to format the card in the camera. Just to make sure the camera sees the correct file system on the memory card.
Dec 15, 2013 | Panasonic Lumix DMC-FZ28 Digital Camera
Memory stick lost does camera work without one?
Yes, but not very well. At full resolution the camera will hold about seven pictures or sixteen seconds of video.
I strongly suggest buying at least one SD card. Make sure you get SD cards and not SDHC cards, as the latter will not work in this camera.
Aug 30, 2011 | Kodak EasyShare C340 Digital Camera
What type of memory card do i use for kodak easy share c310 camera
The C310 works with MMC and SD cards. MMC cards are nearly obsolete and hard to find, so I suggest SD cards. Be sure you get an SD card, 2GB and smaller. Larger cards are actually SDHC cards and will not work in the C310.
Aug 22, 2011 | Kodak Cameras
I purchased a Kingston 2G SD card for my Canon A530. It says "memory card error". In fact, the function to format the card does not even light up but is dimmed and skips to the next function. My...
The card is obviously too large, in memory capacity terms, for the camera. In fact, it might not be an SD card, but an SDHC card. "SD" cards larger than about 2GB are actually SDHC cards. I'm not sure about the 2GB ones, maybe there are some of each type. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
A 1GB card is plenty of space. If you really need more room, carry a spare card, like people used to do with films.
Dec 29, 2010 | Canon PowerShot A530 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
When I insert the sd memory card into my Mitsuba dc500t digital camera, it won't function until I remove the memory card. Any suggestions as to why this occurs and how to correct the problem so I can...
On MEMORY Card Problem, Make SURE its the SMALL Insert SD Card you are using & Not just a SD Card!
I Have same Camers & it should fix your Problem to use from 2 to 8 GB Memory.
Good Luck,
Dan
Apr 21, 2010 | Mitsuba DC500T Digital Camera
Camera does not recognize memory card
It appears the SD card the retailer sold is not compatible with the camera. Put in a different memory card and camera works fine.
Dec 28, 2008 | Nikon COOLPIX L18 Digital Camera
Problem with taking picture with SD card
The only thing I can recommend is using the brands of memory cards that Casio recommends. They are Panasonic, San Disc, Toshiba. Make sure the card is formatted with the camera before use.
Nov 07, 2008 | Casio Exilim EX-Z750 Digital Camera
Memory SD full
Can you put the SD card in an external card reader and see any files? Did you format the sd cards in the camera? You should never format the cameras sd card with a pc.
Apr 14, 2017 | Vivitar ViviCam 3746 Digital Camera
Vivitar ViviCam 3785 Digital Camera Logo
158 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
