Question about Dell A215 Computer Speakers
Speakers don't start up right away
When I play something that uses the speakers for sound - either a CD, an attachment, You Tube or even just re-boot the machine, the sound is broken up and doesn't produce a solid sound for a few seconds. It's almost like the machine is not giving the sound card the capability it needs when something else is going on.
Any suggestions on what little I have give you.
Give it a minute
Posted on Dec 31, 2008
Have power but no sound come out
the drivers might have been corrupted by something foreign or you might have got a virus run your antivrus program
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If you are having problems with you sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 02, 2011 | JVC Audio Players & Recorders
My computer speakers don't work & i've tried everything even my headphones don't work so what should i do
also
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 27, 2011 | HP Audio Players & Recorders
I have a problem with my speakers and i can'nt hear any sound from my computer and i don't know what kind of speakers have adjuts with my computer
click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
you might need to select stereo speakers
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try swapping the speakers around if the problem still persists either the speaker is faulty
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps you
Aug 20, 2011 | Logitech LS-21 2.1 Speakers
I hooked up the boston speakers 4 plus wolfer and when I play music on You Tube, the rear speakers don't play. They work in the sound "test." They also work when I set the speakers...
the sound on utube is only stereophonic, hence you will get only stereo putput. If you play anything recorded as quadraphonic or above all your speakers will give sound output.
Jun 22, 2011 | Boston Acoustics MicroMedia Computer...
Wont turn on or play a single sound
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty graphics card clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 27, 2011 | Gateway Edison Computer Speakers
Sp[eaker system model no ps-102. i have had these speakers given 2 i, i have them connected 2 my computer, i can can c you tube and itv player but i have no sound do u thing you could help. u could ring...
also
hope this helps
don
Feb 27, 2011 | Audio Players & Recorders
Why put woofer on the floor?
Because low frequency sound travels better lower to the ground. The effect if placed high up would be minimal
LF sound has more punch that regular speaker sound, it also caused more speaker movement and if placed high up could in theory pull itself from the shelf or mount.
You tube has some sub sound tests you could use to show this theory. or maybe the candle trick of putting a lighted candle in front of a sub when turned up a bit may convince you.
put a candle about 6 inch away from a sub and play some nice bass it will blow out the candle more than a regular speaker
Oct 11, 2009 | Insignia Audio Players & Recorders
Sound works on CD's and winows media player BUT not on you tube o
please re-install the drivers on sound card...might solve the problem
Feb 13, 2009 | Ozaki DT-500 3-Piece Speaker System...
Sudden crackles in the right surround speaker!
Your speaker is busted. You will need to get another one. It really can not be repaired and if it can, it will cost more than a new speaker.
Sep 12, 2008 | Logitech X-540 Computer Speakers
Speakers Muffled
Say "sound card" or maybe you fryed something due to overuse and or playing them too loud? Nah. Everyone plays speakers at the recomended level. Seriously, you need to get this checked out: radioshack.
Oct 20, 2007 | Audio Players & Recorders
Dell A215 Computer Speakers Logo
32 people viewed this question
Top Dell Audio Players & Recorders Experts
dochubert
dochubert
Level 1 Expert
SmartAviator
SmartAviator
masterwest
Level 1 Expert
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
