Question about Dell Latitude C400 Notebook
Dell Laptop- My number keys and the g/h button are frozen. Any help?
  • SoleAngelus May 11, 2010
    Frozen how do you mean? they arent working? are they are wring incorrectly?
Dell inspirion n5030 laptop
Are you using the touchpad, or a regular mouse plugged into the laptop. If you are using the touchpad on the laptop, make sure it is enabled. There is a button to the right of the F12 key to enable/disable the touchpad. If you are using an external mouse connected to the laptop, try restarting the computer by pressing the power button once (that will initiate a shut down).
Nov 23, 2013 | Computers & Internet
Laptop types numbers instead of letters
Hi!
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
Jul 10, 2011 | Dell Inspiron Mini 10 Notebook
Brand new dell latitude e6510. been using it with no problem for a week. now when I tirn on none of the keys respond except for the button mouse in the middle of the keyboard. can't close open windows,...
Call Dell open a ticket and ship it back to them. Could be many things. Was anything spilled on the laptop or was the laptop violently jarred or dropped?
May 28, 2011 | Dell Latitude E6510 Laptop
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    The keyboard is locked
    Dear Sir,
    plz folow this step to unlock keyboard
    1. Step 1 Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
    2. Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
    3. Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
    4. Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
      For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
    5. Step 5 Reconnect the power adapter or AC cord. Start your computer.
    6. Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard.
    Thanks For Your Time,
    Apr 13, 2010 | Dell adamo PC Notebook
    Dell keyboard locked up
    Dear Sir,
    PLzz folow this step to unlock your keyboard
  • Step 5 Reconnect the power adapter or AC cord. Start your computer.
  • Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard
  • Thanks For Your Time.
    Apr 10, 2010 | Dell 0Y3740 Keyboard
    My dell laptop types numbers instead of letters on some keys without pressing fn key
    HI,
    If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
    This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
    Hope This Helps
    THANK YOU
    Feb 27, 2010 | Dell Vostro 1510 Laptop
    Keyboard is not responding it does sometimes then stop again
    Step 1
    Nov 15, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
    View laptop on tv
    Most laptops have a combination of buttons you have to press on the keyboard to get it to output on the monitor output. Try pressing the FUNCTION KEY or FUNC/FN key usually found in the bottom left hand side of the keyboard. Keep that button held down while press one of the number keys. Usually the number key will have a picture of a TV screen on it. Might be number 8 or 9. Press both keys at the same time a you can switch between laptop screen, Sony LCD or you can have both..
    Mar 23, 2009 | Dell Computers & Internet
    No signal sony bravia to dell laptop
    Mar 20, 2009 | Sony Televison & Video
    Dell Latitude C400 Notebook Logo
    133 people viewed this question
    Alun Cox
