Question about Canon EOS 30D Digital Camera with 18-55mm Lens
EOS 30D is slow to fire.
When the shutter release button is depressed, ( on auto focus ) the camera focusses, shows the focusing light in the viewfinder, bleeps but doesn't shoot . I focus on auto, then change to manual and it still doesn't fire. When it does work, it is sometimes a second or two slow.  I can get it to shoot if I quickly press the shutter release button 5 or 6 times.  Any ideas ? Thanks for your help.
Simon.
  • simes2002 Jan 01, 2009
    Thanks for your comments, I'll have a look through the manual and see if it's on a delay setting. I shoot mostly landscapes and generally use the P mode, sometimes manual. The problem occurs whatever setting I use though. I've also changed the cf card and reset the camera back to its default settings.
    Cheers, Simon.
    Novelist:
  • 121 Answers
Are you sure you aren't in the delay setting in drive mode? This camera has 2 delay settings, one for 2 seconds between when you press the shutter and when it takes the photo, and one with 10 seconds delay - often used when you want to be in the photo (e.g. self-portrait or group photo).
If you aren't in the delay mode, then I need to know more about your settings. What shooting mode are you using? What type of photo are you trying to take (portrait, landscape, sports)? Are you shooting indoors, outdoors, bright sunlight, overcast, etc.?
Posted on Jan 01, 2009
  • jcdill
    jcdill Jan 01, 2009
    Here are some things to check:
    1) Are you fully pressing the shutter, or 1/2 pressing? Try 1/2 pressing first (to establish focus and exposure and focus) then pressing all the way, and see if it takes the shot right away when you fully press.
    2) Is the lens having any problems finding focus?
    3) How long have you had the camera? Is it still under warranty, and have you ever had it serviced? It may simply need servicing.
Why does my camera not capture any picture? Whichever mode I use, it does not capture any picture regardless of how many times I click the button.
Flash flicker is the camera trying to get enough light to focus, It occurs when you press the shutter release part of the way down.
Try the same thing outside, ensure you press the shutter real ease all the way down. If it still does not fire, switch the lens to manual focus (sliding switch on the side of the lens, move from A to M) If the camera shoot then, the camera is struggling to auto focus.
Feb 23, 2015 | Canon EOS 1100D / Rebel T3 Digital Camera
Canon EOS 400D Flash Problem
yes..that's a twitchy button all right..can you inspect it to see if there's any accumulated dirt/grease can cause it to actually 'stick'
Mar 29, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Hi there. i owned a Canon EOS 60D model camera. The problem is, its AF option is not working except Auto n 'C' modes. While i am trying to use it in M mode with AF, its not working but in auto mode an
Are you sure you did not put the AF/ MF switch in the wrong position? Although I don't think it would focus in Auto mode. In all other modes, are you sure you selected a (or more) focus point(s) in the centre of the frame?
When the selected focus point is on the side of the frame it won't focus on the parts you want it to focus. Then while pointing to the point you want the camera to focus, please press the shutter release button half and what till it focusses. Then press it the whole way down. Be aware the camera needs enough light to focus and certainly can't focus with a lens wit a min aperture of 6 or a larger number. On your 18-135 you can shoot at f16 because it will first focus on wide open and only close the aperture after you pressed the button.
Jan 27, 2015 | Canon EOS 60D Digital Camera
My shutter won't fire using 18-55 lens, either on Manual, P or Auto mode. It is set to AF. But when lens is set to MF, shutter fires. I tried switching to another lens and shutter is perfectly fine.
I could be that your lens isn't focusing. If the Auto focus can't find something to focus on the shutter won't fire. If you are shooting in low light sometimes it has trouble try shooting something that is well lit. also your auto focus point may be somewhere other than the center. there is a button on the top of your camera that looks like this [ ][ ] [ ] [ ]
More or less that will switch where your focus point is. If you look in the view finder and see a red dot when you push on the shutter button that is your focus point. push the above button until the red dot is in the centre. that may fix your problem.
Jul 26, 2011 | Canon EOS 450D Digital Camera with 18-55...
2 problems. I have the Coolpix L100. Sometimes my photos are blurry and also. there is a delay when I snap a photo which isnt good when trying to get action photos.
With autofocus digital cameras, blurred photos are almost always a result of camera shake. You need to hold the camera still even after pressing the button, as there is often a short delay before the shutter fires.
Many digital cameras have a two-stage shutter press- first pressure causes the camera to focus, then the follow through pressure takes the picture. If you are rushing this, you may get unfocussed shots.
If you take lots of action pictures, you will have to work on a technique of partially pressing the shutter to get focus in anticipation of the shot (perhaps focussing on where the action will occur), then holding it part-pressed until the moment you want to capture. This is really no more of a problem than setting an anticipatory focus on a manual focussing film camera use to be. Some more complex digital cameras will allow you to turn off auto focus and focus manually.
Nov 05, 2010 | Nikon COOLPIX L100 Digital Camera
Auto focus does not work in creative modes
That is a custom function of the camera that can be change back to default with ease. While in one of the creative zones press the menu button and navigate to the 5th and final tab on the top right. 8f5da8f.jpg
This is the Setup menu 2. In this menu, select “Custom Functions (C. Fn)” . This will open a submenu of numbered options. Select #04 and set it to 0: the default AF/AE lock on a half depress of the shutter. 7528356.jpg
That should get your camera back to the expected auto focus with the shutter button.
Mar 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Auto focus does not work in the creative zone
Sounds like your custom functions have been changed to work this way. On the EOS 350 D it is Custom Function #04. To change it back to default you need navigate through Canon's menus. Here's how to get there: while in one of the creative zones go to your camera menu and navigate to the 5th tab on the right. Select “Custom Functions (C. Fn)” from this tab. This will open a submenu of numbered options. Select #04 and set it to 0: the default AF/AE lock on a half depress of the shutter. That should get your camera back to the expected auto focus with the shutter button.
Happy shooting :-)
Feb 06, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Only one auto focus point
have you already pushed the focus point button - top right, under your thumb and then push the set button? Pushing the set button will flip between only the centre focus point and all 7.
May 06, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Will not auto focus
"... Autofocus Lock ("AF-L"). Pressing the AF-L (Autofocus Lock) button enables the Nikon F4 to lock the focus. Simultaneous lock of AF-L and AE-L is possible. "'FREEZE FOCUS" - is another great function in the F4. It allows automatic shutter release when subject enters a pre focused distance - available with Nikon MF-23 and/or the 250 exp. MF-24 Multi-Control Back. i.e. with the shutter button fully depressed, the shutter is automatically fired when a subject comes into a preset manually focused position. This function is recommended for sports races because the racing course is usually known beforehand. It also works well in wildlife remote control photography, scientific, forensic and other technical photography. ..."
Nov 11, 2005 | Nikon F4s 35mm SLR Camera
Canon EOS 30D Digital Camera with 18-55mm Lens Logo
304 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
