How do I determine what kind of memory that I need?
I need to know how to determine what kind of memory to buy.
How do I determine whether to use high density or low density memory?
What is the advantage to low density memory?
Are external bus speed, FBS, and/or memory speed the same?
I ask because my laptop external bus speed is 400 MHz but the memory calls for either 200 or 266 MHz memory but I don’t know if they are talking about high or low density memory.
Thank you for your help.
Don Jones
  • 3 more comments
  • donejjones Dec 30, 2008
    Your guesses contradict everything I have read about high and low density memory, so I need answers to the questions I asked, not guesses.
    All of the manuals say my Inspiron 2650 will only use 256 modules, but the DELL techs put 1 gig modules in their test machine and it worked great. I also know it uses the same Intel chip set as the 8500 which uses 1 gig modules and the Intel manual says it will use 1 gig so you can’t always believe what the manual says.
    Thanks for trying though.
    Don Jones
    Thanks for the suggestion, but if you read my comment to Knotbeerdan, you will see that I already know that the motherboard will support 1 gig modules, both by talking to DELL techs and experience as well as refering to the Intel mnaual for the chip set. When I ran crucial's scan, it parroted the DELL mnaual exactly, even though DELL uses the same chip set in the 8500 and uses 1 gig chips the 8500 module.
    Now you know that Crucial's scan isn't necessrily right about the maximum memory that will work but gives a SAFE max based on the manufacturer's literature.
    Also, I know from installing my son's memory that it will use memory that is faster than crucil says it will use.
    Don't blame me because you tried to answer quesions that I didn't ask but instead tried to second guess what I really wanted to know and guesed wrong. Next time READ the questions and reply to the questions asked or ask for clarification before answering. You childish rsponse just got yu another inappropriate rating so just keep on lashing out because you messed up.
  • donejjones Dec 31, 2008
    I only rated your responses one time each to the best of my knowledge. In fact I am not sure that I even rated your second response like I said I was going to do.
    If the managemnet has any question they can feel free to contact me to try to straighten it out. At the most there shuld have only been 2 ratings and if you hadn't lashed out at me in your second comment there would have only been 1. I can understand youranger at getting 20 bad ratings, but once again, you need to understand what you are responding to and not second guess and dhten go off on a tangent withot verifying your assumption.
    I consider your answers to have been dealt with and have NO desire to screw with your ratings by putting 20 inappropriates in nor do I even know how to do it.
    This is only the second post I have made and I could NOT find any choice that said that your response was off target or unresponsive so I rated the first one INAPPROPRIATE because it wasn't appropriate to the questions asked. I am sorry if the system glitched and put in a whole bunch of INAPPROPRIATEs.
  • Anonymous Apr 06, 2009
    my motherboard is Time ms-7095(p4mam2-v) I asked crucial to do a scan and they advised me to get 2 x 1gb memory cards, I have bought these but am only getting a total of 990 mb. Is this to do with high and low density ? Can you help me with what I should ask for to get 2gb total.
  • 413 Answers
In order to know what kind of memory you need you will have to look up the model of the computer and hopefully that is it. High density is manufacturer specific and it is very important if you order hi density for the wrong brand it wont work. My educated guess is you will want low density 266mhz and depending on how new you might only be able to upgrade 256 mb per stick I hope this helps i know its a confusing subject but really you just need to get online and start researching ram before you make any decisions.
Posted on Dec 30, 2008
  • 2 more comments
  • Dan rogers
    Dan rogers Dec 30, 2008
    I do not have one of these systems available to me so the best i can do is go online and research this stuff. And on top of that take educated guesses. I don't appreciate the ranking however. It took time and thought and although some facts may be incorrect but that is based off the info given if you want better feedback provide more info. The last bit would have been really helpful before. Now i have to spend a WHOLE lot of time trying to repair my rating thanks for using fixya
  • Dan rogers
    Dan rogers Dec 31, 2008
    i would like to know how you added over twenty innapropriate ratings. Though it seems you already knew the answer and apparently neither of us that tried to help could understand what you were wanting. And all i was sayin is to please not be so fast to rate people as Inappropriate. We work hard to try to help people out. For free, this is not a site that people need to pay for so keeping that in mind sometimes we need people to bear with us while we try to figure out the real question. But again, I would like to know how you added so many Inappropriate ratings?
  • Dan rogers
    dont feel bad just wonderin if you had found somethin that i should look out for in the future
  • Dan rogers
    I would like to take a second to thank you, Like i said it was not necessary to remove the rating. But thank you anyway.
  • 49 Answers
Go to and install their configuration utility through your browser. They will tell you what you have and all the combinations you can do to max out your system. Look at the specs of the RAM and you can get it from Crucial or some other vendor.
It is hard to remove xenon headlights from BMW x5 and put aftermarkets ones?
If you already have an x5 with original factory fit Xenon headlights, that's the way to leave it. Xenon headlights are a lot more fiddly to install than the old fashioned kind. They can be dangerous to handle, and contain high voltage capacitors that could shock you.
At the end of the day, the odds of you being able to switch out the lights, and do a better job than the factory is pretty slim. Especially as you apparently don't even know where to start.
When you eventually trade your car, its value will be determined by the mileage, vehicle history, condition, and whether or not you have been messing with it. No one wants to buy a car that some enthusiastic amateur has been playing with. People are looking for a good clean vehicle in as close to original condition as possible. You will get more information in here about BMW aftermarket.
Aug 27, 2012 | Cars & Trucks
What is the high side and low side of the AC in 1994 Cheyenne?
Are you trying to determine whether it needs filling?Unless your a/c system has been completely changed to use the current freon,you will be unable to do it yourself.1994 has the old R-12 which mainly shops can only do because you need a special permit just to buy handle and use it and is very costly.1995 and after have the R134-a freon which you can do yourself much cheaper than a shop.You cannot use one with the other as they have different properties.Let me know if you have the old system or are unsure.
Good luck! Greg
Aug 15, 2010 | 1994 Chevrolet C1500
Have 512MB RAM. Was told to max it out because the machine is extremely slow. Has two slots with 256MB. Can I put two 512MB memory modules in those slot to increase 1G or RAM?
yes, after looking up your laptop on hp's website, I have determined the kind of memory you need; (assuming your computer is the one you put in the question, HP Pavilion ze4805us Notebook PC)
you need 2x 512 mb, 200-pin, DDR 266 memory
I looked and found some Corsair (highly respected company in computer memory) memory, for 22.99 for each DIMM (you'll need to buy 2); see link below.
If you have any more questions, please let me know!
May 16, 2010 | HP Pavilion Ze4805us Notebook
Update failed
You need the low density ram and not high density. Unfortunately the low density stuff is rather more expensive then the high density so you're best trying to get some second hand - ebay maybe? I think the cpx only accepts pc100 even though the crucial site recommends PC133. Hope this helps.
Sep 28, 2009 | Dell Latitude CPX Notebook
How to upgrade the RAM
1Instructions Things You'll Need:
  • Computers Memory
  1. Step 1 Check the owner's manual or motherboard manual to determine if RAM is parity or non-parity. The website of the company you purchased the computer from usually will tell you what kind of memory your computer needs as well.
  2. Step 2 Find out the speed of RAM (for example, 60 nanoseconds).
  3. Step 3 Determine whether the computer uses single in-line memory modules (SIMMs) or dual in-line memory modules (DIMMs).
  4. Step 4 Find out whether the computer uses regular, FPM, EDO, or Synch DRAMor DDR1/DDR2.
  5. Step 5 Determine the number of pins on the motherboard: 30, 72 or 168.
  6. Step 6 Remove the cover from the machine to find the number of open RAM slots. Look for between two and eight same-sized parallel sockets on the main circuit board. Usually at least two of those sockets will contain RAM - ruler-shaped circuit boards with chips on one or both sides.
  7. Step 7 Purchase additional RAM that matches existing memory specifications.
  8. Step 8 See the Related eHow "How to Install RAM" to learn how to put in RAM yourself; you can also get it installed (recommended if you don't feel comfortable opening up your computer case).
Tips & Warnings
  • You usually have to install SIMMs in pairs.
  • If you don't know how much RAM you have installed currently, check your My Computer properties in Windows or choose About This Macintosh from the Apple menu.
Jul 03, 2009 | Sony VAIO VGC-V617G PC Desktop
Determine whether 289 V8 engine is high performance.
Vin Number on car drivers side on dash call dealer or do a search on vin #
Jun 18, 2009 | 1966 Ford Mustang
Want to get more ram for my computer
Use the free tool on this site to scan your PC to determine what kind of memory you need:
Mar 16, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Sd memory card
You can buy them anyplace that sells electronics. Best Buy, Circuit City, WalMart - as far as cost, it depends on what size you get.
The phone has a limited memory, which is used by phone numbers, pictures stored in the phone, and the phone's base software, so music would eat the phone memory up pretty quick.
When you buy the micro SD card, it usually comes with an adapter for PC media readers.
I just checked ebay and I saw 2GB for 11.00 shipped. That is a great buy!
Jul 22, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Dell Dimension 8250 Memory Question
Computer Memory Information Upgrade Questions Troubleshooting Memory Diagram Upgrade Help Buying Tips · Memory definitions. MEMORY ABCs. Memory, which is commonly referred to as RAM
Installing PC computer memory Additional information and help with isntalling PC computer memory. ... Installing a PC computer memory. Question:. Installing PC computer memory.
Determining type of hardware within computer Reference, Issue / Question. Memory, Information and help with computer memory. CH000149, How to determine system resources / RAM available?
Buying tips on computer memory. How much memory should I get? This question really depends on the type of computer user you're and what type of programs you plan on running on the computer
Determining what type of memory to use in a memory upgrade. Determining what type of memory to use in a memory upgrade? Question:. Determining what type of memory to use in a memory upgrade.
E-mail CHID: 5683
Good Luck read and follow instructions will find your answer.
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | Dell Dimension 8250 PC Desktop
Computers & Internet Logo
222 people viewed this question
David Payne
David Payne
