Question about Microsoft Word 2003 for PC
Creating labels Once I get to the end of the first page of labels and try to go to the next page. I've tried pressing "enter" or even "control enter" but the second page of labels will not come up.
  • 728 Answers
Hi cguardo,
What that means is your data labels extend page the first page, you need to either resize your font, or delete a line or two until the second page disappears.
Good Luck
Mark
Posted on Jan 05, 2009
Address Labels. How do I continue to create extra pages
0 0 Using Avery Design & PrintTo add another page, click on Add Sheet in the Sheet Navigator (located on the upper-right of the Customize screen).
Using Microsoft® WordTo add another page using Microsoft® Word, place your cursor outside the last label on the bottom right of the page and press Enter. Then press the Tab key to create each new label.
Jan 16, 2017 | Office Equipment & Supplies
How do i find the inverse of a matrix on a CASIO fx-9750GII
Once the matrix is created you can use the reciprocal key to get the inverse.
I hope you will not hold against me if I showed the whole porocess. (No reflexion on your or anybody's abilities to create a matrix. Just trying to be helpful to more people.)
Press Menu to display icons.
Press 1 or use Arrows to highlight Run/Mat.Press EXE
Press the F1 key to activate the Mat TAB.
While a matrix label is higlighted press F3:Dim to enter the dimensions.
Matrix must be square.
Fill her up!
Press EXE after entering the last element.
Then press EXIT to return to the Run/Mat Screen.
In Run/Mat screen press the OPTN key. Press F1 to enter the Mat identifier
followed by [ALPHA] A (if the matrix you created is stored in A)
At this point the screen displays Mat A.
Any of the continuations of the command shown below will yield the inverse matrix.
The minus sign you see in the 2nd and 3rd commands below is the change sign (-)
For the bogus 2X2 matrix I entered, the result is as follows.
Notice that even if inside the answer matrix the elements are displayed as decimals, the
values you will see at the bottom are exact fractions.
Aug 26, 2011 | Casio FX9750GII Graphic Calculator
I've got some problems with my zebra zm400 printer. It says error ribbin out
The default setting is thermal transfer for this printer. You can change the setting on the printer so it doesn't show you the error any more by doing the following: Press SETUP/EXIT Press Plus (+) to scroll through the different parameters About the 6th parameter is "PRINT METHOD" Press "SELECT" to select the parameter Press Plus (+) or Minus (-) to change to Direct Thermal (no ribbon) Press "NEXT/SAVE" to save your changes If you make the changes to you printer and as soon as it prints it reverts back to thermal transfer, then your label software or your driver are overriding it and you need to make the change there.
Changing the setting in your label software - this will also change the settings for this label only Open your label Make the change under "label setup" or "page setup" inside your label software.
Changing the setting on the driver - this will also change the default settings for all future labels that you create Go to control panel and devices and printers. Locate the driver for your label printer and make the change under "Printing Preferences".
May 05, 2011 | Zebra 203DPI Printer
My tecra m1 os not working safe safe mode with net working safe mode with comand prompt last known good configration start windows normaly i choose one by one that does not working i install...
place XP CD into your CD Drive that is set to boot first in your Bios.
And reboot, When prompted (usually one of first things) press any key to boot from CD" do that....
once you get to the screen that loads press ENTER to "set up XP now"
Then press F8 for the user agreement
The next page will show your previous installs.
choose yours..
Select "Install a Fresh Copy of XP without repairing"
the next page will show some options with your drives and partitions listed below.
from there you want to select the partition with your current XP install,
Then smash "D" on your keyboard to delete the partition (this is where all data is lost on the drive)!
you will need to press Enter on the next page to confirm.
and another confirmation press L
next you will see your drive press C to create an new partition
next you can just hit Enter to create partition the full size of your drive. (suggested) or you can change the size and have multiple partitions.)
once you have created the partition press Enter to install
windows will tell you the drive is not formatted and will offer you
some choices... choose NTFS Quick or Slow ( I use slow on smaller drives and quick on the big ones.)
Feb 08, 2011 | Toshiba Tecra M1 PC Laptops
My Computer does not load...Windows management does not work. My Computer takes a long time to search for the local drives,i cannot view the drives form my computer,but i can open the drives from other...
first take backup your important files from my dcument c drive & desktop in other than c drive
now place XP CD into your CD Drive that is set to boot first in your Bios.
choose yours..
Feb 07, 2011 | Microsoft Windows XP Professional
How to format win xp
Please refer the below link
http://www.ehow.com/how_7231523_perform-install-windows-xp-laptop.html
Feb 05, 2011 | Microsoft Windows XP Professional
I can not get my Crosley CR248 Songwriter to Finalize when I try to transfer from cassette to cd. It keeps showing me FAIL....
I don't know this particular machine but here are some general comments.
Most CD recorders need you to press (and sometimes hold) the record button followed by the play button before tehy actually record anything (if you don't press the play button you will still hear sound via headphones etc. but no recording file will be created)
Does it record from vinyl records okay or is it just cassettes?
Are you using the correct sort of CD?
We use a Denon CD recorder and it only works with AUDIO CDs - computer data CDs or CDRWs will not work in it. Even if the Crossley will accept computer CDs it may require a particular format either +ve or -ve (labelled CDR+ or CDR-) to be compatible. Once you have tried finalising a disk and it has failed you cannot use the same disk again.
Jan 29, 2011 | Crosley CR248 Turntable
How to create simple batch files
Creating a batch file
MS-DOS users
Microsoft Windows and other users
MS-DOS users
To create a basic batch file in MS-DOS, follow the below steps that give you an example of how to create a basic batch file.
  1. Open an MS-DOS command window or get to MS-DOS. Additional information about doing this can be found on document CHDOS.
  2. At the MS-DOS prompt, type: edit test.bat and press enter.
  3. If typed properly, you should now be in a blue screen. Within the screen, type:
    pause
    dir c:\windows
    dir c:\windows\system
  4. Once the above three lines have been typed in, click File and choose exit; when prompted to save, click "Yes." Users who do not have a mouse cursor can accomplish this same task by pressing ALT+F to access the file menu, then pressing "X" to exit, and pressing enter to save changes.
  5. Once you are back at the MS-DOS prompt, type: test and press enter. This will execute the test.bat file and begin running the file. Because the first line is pause, you will first be prompted to press a key. Once you press a key the batch file will run line-by-line; in this case, listing the files in the windows and windows\system directories.
If you wish to add more lines to this batch file you would simply type "edit test.bat" to edit the file again.
Additional information about the MS-DOS edit command can be found on our edit command page. Some versions of MS-DOS and bootable diskettes may not have the edit command; if this is the case, you would either need to obtain the edit.com file to access this file or use the copy con command.
A Windows user can still use the above MS-DOS steps if they wish to create a batch file. If, however, you're more comfortable using Microsoft Windows or your operating system, you can use any text editor, such as Notepad or Wordpad, to create your batch files, as long as the file extension ends with .bat. In the below example we use the Windows notepad to create a batch file.
  1. Click Start
  2. Click Run
  3. Type: notepad and press enter.
  4. Once notepad is open, type the below lines in the file or copy and paste the below lines into notepad.
    @echo off
    echo Hello this is a test batch file
    pause
    dir c:\windows
  5. Click File and click Save; browse to where you want to save the file. For the file name, type "test.bat", and if your version of Windows has a "Save as type" option, choose "All files", otherwise it will save as a text file. Once all of this has been done click the Save button and exit notepad.
  6. Now, to run the batch file, simply double-click or run the file like any other program. Once the batch file has completed running it will close the window automatically.
Jan 04, 2011 | Computers & Internet
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
Forgot my password
try to use a safe mode?!?!how?? before to start youre windows try to click a F8 and choose a safemode,,, create a new account!!! you dont like reformat.......
Jun 27, 2008 | Computers & Internet
Microsoft Word 2003 for PC Logo
22 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
