Question about Buffalo Technology WHR-G54S Wireless Router (WHR2G54S)
Resecure network I had to reset my wireless buffalo connecter, (i did this by holding down the INIT button to reset it) now it is no longer a secure network. How do i resecure my network? I have already recreated a new passwork and key, but when i try an dconnet to the wireless, it still says its unsecured, and now shows the MAC adress as the name of the server, and from what i have read i dont want that? How do i remedy this situation?
  • 192 Answers
First enter the router ip adress in iternet explore. You will need to know the username and password to change the setting for you router.
Posted on Jan 04, 2009
I want to chang the pasword of airstation ag54
Try this:
Reset the Airstation to factory settings by holding the reset button until the lights flash (10 seconds).
Once the airstation has been reset, reset it changing your password.
Below are the instructions on how to setup your Airstation.
http://www.columbia.edu/acis/networks/aptnet/buffalo/index.html
Good luck!!
Aug 16, 2012 | Buffalo Technology AirStation WLA2-G54L...
I cant connect i-pad2 to buffalo
Buffalo Technology WHR-G54S Wireless Default IP, Default Username, Default Password
Reset WHR-G54S by holding RESET down while powering it on. Hold 30 seconds, then remove power
Nov 01, 2011 | Buffalo Technology WHR-G54S Wireless...
I have forgotton my password for my wireless router is there any way I can get it back?
You will need to reset your router to default settings then resecure your router. To reset simply press and hold the reset button in the back of the modem for 15 seconds or until router resets.Here is a link to show you step by step how to secure your router.
http://www.columbia.edu/acis/networks/aptnet/netgear/index.html
Jan 14, 2011 | NetGear WGR614 Wireless Router
I've had a new laptop but require my security key, model WBMR-G54 to access the security enabled network, from my old laptop.
If you've forgotten the wireless security key you entered when you set up the router you can reset it by connecting to the router directly with an ethernet cable instead of the wi-fi. Plug a cable into the router and then laptop and access the setup page for the router. See the manual (or download one from the buffalo site) for setup instructions.
Dec 27, 2010 | Buffalo Technology Buffalo AirStation...
Can't find AOSS button on my router
The AOSS button as for as I know is only on the Buffalo brand routers
HERE is the link to the Buffalo website explaining the AOSS feature so your Linksys router will NOT have an AOSS button at all
Buffalo Solution
The AirStation OneTouch Secure System (AOSS™). With AOSS, users can set up the securest wireless network possible, easily and quickly. AOSS automatically detects and configures other AOSS enabled wireless devices and clients and seamlessly negotiates the most secure connection possible between your wireless devices.
Apr 25, 2010 | Linksys Wireless-G Broadband Router
Network is "out of range" only after securing my wireless network
reset your router
should be a reset button on the back,
hold in till the lights on the front flash then its reset open explorer browser
type in 10.1.1.1 or 10.0.0.1
log in as Administrator
add new user
set password while adding new user
save your new settings(write them down too)
run your network wizard again with your new settings applied
test the internet for function
if no function then contact your ISP to assist with connection to internet
all sorted now please rate me MISTERDJ
Apr 11, 2010 | Toshiba (PA3070U-1MPC) 802.11b Wireless...
How do I secure my Buffalo WZR-G300N? I have lost the pin code and camnt get back in. I have read on another site that to reset the username is: root and Password is nothing (i.e blank). Once this is done...
Some wireless routers have a pinhole reset button on the back of the router. If so, use a sharp point to press and hold this button until the LED lights flash, then release the reset button. The router should be restored back to the factory defaults.
You can then open IE browser and type in the configuration IP address of the router to configure the wireless settings, you most likely need to connect a LAN cable from the computer to the router, configure the wireless settings (ie SSID, encryption etc) take a note of these settings and configure the wireless card on the computer with these settings. Then the computer can communicate with the router without using a LAN cable.
Nov 10, 2009 | Buffalo Technology AirStation Nfiniti...
Wireless connection problem
Reset the router back to factory defaults by using the end of paperclip to push a very small button on the back of it. You will have to reset the security if desired.
May 01, 2009 | Computers & Internet
IOGEAR GMFPSU22W6 PRINT SERVER not being seen by the control software that came with the hardware. Using a Wireless N router with hard wire from the router to the print server and network is up and...
For the GMFPSU22W6, there's two possible reason why it's not being seen by the MFP Control Center. First, the MFP Control Center was properly installed, second, the Print Server is not working correctly. To resolve this problem, please try the solutions below:
1. Uninstall/re-install the MFP Control Center.
2. Reset the GMFPSU22W6 by holding down the "Init" button that's located on the right side of this device. Hold it down by 10 seconds and then unplug the power adapter while still holding down the "Init" button for another 10 seconds.
3. Resealse the button and turn it back on by connecting the power adapter to it.
Mar 19, 2009 | IOGear (GMFPSU21W6) Print Server
What is the aoss button/
To set up Wireless correct? Well apparently there is none and you have to set up the wireless connection manually, you do this by going into your network settings. This is where you set up your network options.
May 26, 2008 | Sony Playstation 3 (PS3) Console
Buffalo Technology WHR-G54S Wireless Router (WHR2G54S) Logo
113 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
