Question about Avanti FF802SS Top Freezer Refrigerator
Avanti ff802ss light works but doesnt cool at all
I twisted the little red thing mounted on the white box in the back of the fridge mounted to the left of the compressor. After I twisted the red dial clockwise about a 1/8 turn the compressor started up and so far it is cooling. only been 2 hours though, What is the red thing I twisted??? and what is it's purpose?
    Problem Solver:
  • 3 Answers
Avanti Customer Service 800-220-5570
Posted on May 17, 2007
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Avanti RM440W mini fridge not cooling.
Hello Dave;
My name is Peter. I am a retired field service refrigeration technician.
There are several things to check.
1.) Door Not Sealing Tightly - I addressed this problem by raising the front end of the unit to assist the door in remaining tightly closed.
2.) Bad Thermostat - This is a long white tube about 1/8" in diameter mounted on the liner wall.
3.) Freezer Compartment Iced Up - You only have one cooling source and that is your freezer compartment. If the compartment is full of ice and frost you will not get good cooling.
4.) Refrigerant Leakage - Most Probable - The freezer section is made of formed very thin plate. The raised contours are also very thin. Your owners manual advises not to use hard steel tool to defrost. All to often, my customers use hammers and screw drivers to defrost and nick the contours. Run you hand across the cooling plate. If you feel a oily substance, then you have a refrigerant leak. If you have a service contract, it is less expensive to replace the unit than repair the seal system.
Dec 28, 2014 | Avanti Refrigerators
Nothing working when thermostat turned on.checked voltage at transformer 110 at top and 24 v at bottom,cant figure out whats wrong .any ideas
Be the thermostat. Kill the power to the air handler so you do not burn the transformer. Remove the thermostat from the wall. Twist the red and white wires together and turn the power back on to the transformer. The heat should come on. If it does, the thermostat is bad. If it doesnt, do the same thing but twist the red, yellow, and green wires together and power the transformer up. The air should come on in cool mode.If it does come on then we know what to check next
Oct 27, 2013 | Goodman Manufacturing Goodman GMS81005CN...
Fridge is not cooling. lights are working. freeer is working
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
This will help.Thanks.Helpmech/.
Jul 24, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Bottom fridge has stopped working. Top freezer is okay. Fridge light is working and thermostat is making operating noise, just no coolness.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
May 26, 2011 | Avanti FF510 (5.1 cu. ft.) Top Freezer...
Have a magic chef refrig model mcbr1010w it is not cooling i have not heard it running there is electric to the appliance light is on inside but nothing else is running
in the bottom back of the fridge, there is a black box (3"x3") with a little white plastic screw type thing in the center. turn it slightly to see if the fridge starts up. Mine is doing the same thing, making it untrustworthy as it shuts off at will. I am currently looking for the replacement part.
Oct 21, 2010 | Magic Chef Refrigerators
My freezer is working fine but the fridge is not cold at all. Not sure what could be the problem. Its an Avanti FF501W
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 11, 2010 | Avanti FF501W Top Freezer Refrigerator
Our wine fridge doesnt seem to be cooling properly
it may be as simple as the coils needing cleaned you can buy a can of condeser cleaner at your local hardware store.
Oct 14, 2009 | Avanti WC681BG Wine Cooler
Whirlpool gold refridgerator light not working and is making funny noise
I had the same problem. Model Number GS5SHAXNL00 Light wouldn't work on the fridge side and the led's wouldn't light up. Ended up being a blown circuit path on the control board.
All I did was soder a wire between the 2 points that path was connecting and *BINGO* the lights are back on!
Hope this helps someone. To find the burned out spot just look for a little black smudge on the white plastic case when you remove the board.
Feb 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Avanti compact Refrigerator NOT COOLING
I had this same problem. I did some troubleshooting and figured out that the fan was being bogged down by ice. It wouldn't spin because the ice was so heavy. I turned the power off completely and let the ice melt. Once the ice was removed from the fan, the fridge began working again!
Feb 16, 2007 | Avanti EC15W-2 Compact Refrigerator
Avanti FF802SS Top Freezer Refrigerator Logo
194 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
