Tv wont switch on
I have a onn lcd tv it wont switch from standby transformer is a 12v 5amp i plugged another transformer in and worked i just need to no which part of the transformer is faulty so i can replace the part,the broken transformer lights up the stand by light but will not boot up the tv when pressed to switch on can you help the transformer model is
I had a very similar problem with mine. The blue LED light came on, but the TV would not switch on from standby with the remote or by pressing the buttons. After getting frustrated, I held down the remote and the blue LED changed from being bright to very dim and I could hear, very feintly, a sound from inside the TV like a flourescent light trying to 'strike'. I kept the button pressed and the TV switched on eventually but the screen was just fuzzy (no picture), then it changed to blue with the input source being shown then it switched off.
I took the back off (with the TV unplugged!) and had a look at the wiring between the circuit boards making sure that they were all still sound. Most of the circuit boards are soldered by machine, but the transformer board looked like the major components were done by hand and some of the connections on the transformer looked iffy. With a small screwdriver, I made sure that the pins on the transformer were separated (except where two pins were obviously meant to be soldered together) and put everything back together.
I'm not an electronics expert by any means and no doubt someone will say that you shouldn't go poking around inside a TV with a screwdriver, but it worked...!
Posted on Sep 30, 2009
My Lg flat screen tv keeps turning itself off after it comes on within 1 min and then it won't turn back on for about 5 min and then repeats all over again? Help?
Posted on Dec 31, 2008
Toshiba 19BL502B wont switch on
On the main power board inside the TV there are fuses take a look at them and the transformer and capacitors for damage
Dec 15, 2013 | Hitachi 50V500 50 in. HD-Ready LCD...
Onn
The start signal does not comes from the main system control section. Contact any service technician. The work is a skilled one, and dangerous too, for an inexpereinced person.
May 21, 2013 | Audiovox FPE1506DV 15 in. LCD TV/DVD Combo
Polaroid TLX-01511C LCD TV REMOTE WONT WORK
Change battery and see. Look for any jammed buttons on the remote and/or on the control panel of TV. If you have removed the plug, when the TV was in standby mode, sometimes the system controller could not have got time to reset. Try using the control panel buttons and see whether the TV responds. If not, switch it off manually, switch off power and remove plug and retry after 48 hours.
Aug 21, 2012 | Polaroid TLX-01511C LCD TV
Why does my onn le42lcd0701 keep on turning on to standby
It is due to some internal fault in the board. Try switching off the TV manually, switch off power and remove plug, retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Televison & Video
50 in lg plasma wont turn on just clicks
hi,
you have to check the power supply first.
As u mentioned about the click sound, the 5v standby supply is ok. The click sound you hear is from the standby relay.
you have to check the other power supplies in the SMPS (switch mode power supply board) board.
first of all check the standby supply 5v on tne pin of connector P800. check the voltage at this point in standby condition and at the time of power on. it should stay at 5v. if it reduces the you have to check the components related with standby SMPS transformer T501.
If the 5v volt is ok the u have to check the 3.4 v at the pin 1 and 2 of connector P802, at the time of power on. if it is missing then check the components related to T112 ,also check the following voltages at the same power on condition.
19v at Pin 1and 2 of P803
6v at the pin 5 and 6 of P802
12v at the pin 9and 10 of P802
check these to verify your tv's power supply
proper care should be taken while working with power supply, because there is risk of getting electric shock.
if you need any more assistance fell free to contact me through fixya.
I have with me its field service manual ( does not have any schematics) if u need that i will sent it to you, if u give me your email id through fixya.
ok
Jan 18, 2011 | LG 50PC3D 50 in. Plasma Television
I am currently repairing an onn lcd 32 angel-a with the standby fault, how would you recommend repair without changing main board?
Check for buldging caps. Burn marks and discolorations around the components. I have found newer caps are failing around the bottom instead of bursting the tops. Check the voltages out to the mainboard to make sure they are where they should be. Another thing to do is reflow the solder on fets, transformers anything that looks broken, you can use a jewlers glass to check for these cracks.
May 31, 2010 | Spectroniq PLTV3250 32 in. LCD TV
Red ir light floashing and tv wont come on Onn lcd tv
red light flashing on bottom of tv and no picture
Nov 27, 2009 | Televison & Video
TV wont switch on ONN LCD32ANGEL-A
i have the same problem and i find if i take the panle off were the buttons r i heat it with a hair dryer and my tv woke just find i do it every moring and thats me alll day the tv will work find so give it a try i just leave the 2 screws out from the top panle and its easy dun
make sure u hold the on botton in wen u r heating it with the hair dryer and u willl be find let me no how u get on
Sep 30, 2009 | Televison & Video
Power problem
hi there the problem is find.when i remove decoder the power on aut transformer 12V coming back.now i just need new decoder and start use tv..manny thanks greg PS:im lock in side of corse is after woranty,bye
May 06, 2007 | Oxxotek LT-3001W 30 in. LCD Television
Televison & Video Logo
522 people viewed this question
Top Televison & Video Experts
