Question about Quartet gbc 5220S Shredder
We have a 5220S GBC Shredmaster and the cutting blades are all jammed with paper. Is there a way to remove the cutting blades in order to clear out the jam. We have tried about everything but cannot take the cutting blades out to clean them. Thanks.
4 Suggested Answers
  • 3 Answers
SOURCE: How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
Posted on May 27, 2009
SOURCE: Seeking online owners manual for GBC Shredmaster 2260x
http://www.gbcconnect.com/assets/docs/2260X.pdf
Posted on Jun 03, 2010
SOURCE: GBC Shredmaster 3220S stopped taking paper in and makes a loud,
Myi shredder does the same thing so I removed the screws to see what was going on inside.
What happened is the fan tail that spins when the shredder is in operation and cools the motor had broken off. I got some gorilla glue, adhered the fan back on, then let it dry for 24 hours. Replaced the screws, turned on the shredder on it worked just fine. The loud grinding noise stopped and the shredder worked wonderfully. I am looking for a replacement part because I don't trust whether the glue maintains its hold when the motor heats up after excessive use . Darlene
Posted on Oct 22, 2011
Why won't my shredder come on?
Plugged into socket? Paper jam? Bad switch?
Feb 26, 2015 | Swingline GBC ShredMaster GLX2030 Jam Free...
On, Fwd, Rvs button has stopped working on my Shredmaster 75X. How do I fix this?
First check the power point is still working - plug in another appliance, like a table lamp. If OK check the fuse in the shredder cable plug.
The commonest reason for a shredder stopping is a paper jam, or running the shredder for too long. By 'too long', many shredders will cut-out after 5 minutes continuous working, and the sensor may take 15 minutes to cool down! Read the manual.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
Apr 02, 2014 | Quartet gbc 75X Shredder
I'm having a problem with my Quartet gbc 5220S Shredder.What it is doing I have all of the doors shut and everything is in place and it is saying that the door is open. What could be the problem going on?
Check that a piece of paper is not causing any safety switch to be kept open.
make sure lid is fitting correctly.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Quartet gbc 5220S Shredder
It will not grab the paper; need to press forwared
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Quartet gbc Shredmaster 6550X...
My shredder is stuck in reverse. How do I get it to go forward?
Unplug, open and remove all partly shreded paper fron the underside, then try it again. If it is hot to the touch, let it cool for about 15 minutes before trying it again.
Dec 19, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
Taking the top off a Shredmaster cc55
They hide some screws pretty good. Also, try with a putty knife to gently pry arouond the cover seam. Their is always a puzzel to keep end users from DIY.
Jun 19, 2009 | Quartet gbc CC55 (Cross-Cut) Shredder
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
My GBC Shredmaster 2260X is jammed and I can not clear it. The teeth try to rotate when stimulated but something is jamming it. Where can I go for service? I am in murfreesboro, TN.
you can do it yourself!! it take a little bit of time and patience. do it in an area that you can clean easily. take off and unplug the top, turn upside down, get a flat screw driver and start removing all the papers in the teeth area. from time to time you will need to put it bank and turn it on and make it go forward and reverse.
Sep 15, 2008 | Office Equipment & Supplies
Quartet gbc 5220S Shredder Logo
Top Quartet gbc Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
