Question about Whirlpool LGQ8000JQ Gas Dryer
Hums with no spin, then turns off
Hums with no spin the turns off
    Scholar:
  • 140 Answers
Turn off and unplug. Reach in and try to spin the drum by hand . if it won't turn the support rollers are probably bad and need replaced. If it turns then plug it in and try to turn it on. If it turns on and spins then the motor may be going bad. If it won't spin the motor or capacitor may need replacing. Good luck and let me know if I can be of any help. Please rate me so I know how I'm doing. Thanks.
Posted on Dec 30, 2008
Dryer motor hums but doesn't spin
Sounds like the motor has gone bad.
May 10, 2015 | Amana Dryers
The disposal only hums. I can turn the blades inside so there is no food stuck. I know there is a reset button but cant locate it.
I had the same problem, it was just humming, then after a few second the on board circuit breaker would cut out. After a little while I could hit the reset button and it would just hum again.
It turns out that the base of the disposal was jammed. There are 2 blades on the top that should spin freely, but the base plate that the blades are attached to also spins. In fact, that's what the motor drives. The two blades on top are not powered, they just flip back and forth as the base spins. So get a broom handle or a strong wooden spoon, stick it down in there, and try to pry the base plate free so it spins. That should do it.
Oct 28, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
When time to drain pump drains water then just hums and it wont spin, get error code f01. when i turn dial to drain and spin pump just hums drum might turn a little but it never spins. i have emptied...
f01 is main controller (board) failure.
Replacing it is the only solution.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Humming sound when Sony DVD player is turned on. The player is attached to a TV. The sound continues when a DVD movie is played.. The intensity of the humming changes with changes in the Video.
Is the humming just from the power on or is it when the DVD is spinning some media will spin with a loud humming noise something to do with the balance similar to an unbalanced car wheel, just a lot quiter. Burn the DVD using ImageBurn create an ISO and reburn.
If it hums without the DVD spinning it is probably the transformer on the PSU on it way out this can happen at any time it is caused by the voltage step down coil becoming damaged in some way and the lower voltage provided causes the noise.
If this is the case I suggest a new PSU or at least a new Transformer.
Jan 07, 2010 | Televison & Video
Dryer drum will not spin. motor hums when button
either the belt is broken that turns the motor or thr idler tension pulley is bad, if it were a motor problem the breaker most likely will trip
Nov 01, 2009 | Dryers
Washer wont agitate or spin motor hums i canturn
if the moter hums when working but does not move time for a new moter the torque side of the moter has gone look on ebay or espares
Jul 29, 2009 | Washing Machines
Whirlpool LGQ8000JQ Gas Dryer Logo
126 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
