Question about D-Link AirPlus DI-524 Wireless Router
Printer not being detected
Hi, i am currently having an issue with my Brother MFC-7220 USB Printer. the router has a usb port specifically for printers, so that all users on the network are capable of printer when ever the router is turned on. however, i go to the status page (192.168.0.1) of the router, and check the printer status, and it states it being 'idle'. and whenever i want to add the network printer it does not detect the DI-524 in anyway. It only has my 'computer name' then my USB printer which was previously installed onto the computer (\\computername\printer\). this is quite frustrating because i cannot seem to get either of the them to connect to each other. any ideas??
    President:
  • 2,961 Answers
Have you gone into the printers and faxes folder and on the brother printer properties(right click) make sure that sharing is enabled. Also look tto see that it is online.
Posted on May 03, 2007
SOURCE:
Where is IP address for the MFC-7220 printer
Network printers do not have a set IP address, you need to configure the printer with an IP address that uses the same range of IP addresses as your network.
The IP configuration is normally done through the printer's Menu on the printer's buttons.
If your are using a network IP range 192.168.0.*** that your wireless router issues automatically then select a fixed IP address on your printer above the number of computers that is installed on your network. (ie if you have 10 computers the make the printer's fixed IP address say 192.168.0.30) so the wireless router cannot issue a conflicting IP address.
When you install the printer driver on each computer then go to the Printer Properties - Port tab - click Add Port - IP port and enter the printer's fixed IP address and printer name.
Do a test print to check if your computer connects to the network printer.
Oct 18, 2012 | Brother MFC-7220 All-In-One Laser Printer
I just purchased a Brother 7220. I ould like to know how to set it up so that faxes are received through the computer so i can decide which to print and which to delete
hi
use the USB cable to connect to the computer, go to the fax set up and it will b self explanatoryu as to how to set up fax you receive. it is strongly suggested you read the manual to understand the unitas a whole
Aug 10, 2011 | Brother MFC-7220 All-In-One Laser Printer
What cable do I need to hook up my MFC-7220 fax machine so I am able to scan with it?
USB Printer cable is supplied along with printer.
If the original cable lost then you can buy a cable from any computer shop
Alexander
Apr 14, 2011 | Brother MFC-7220 All-In-One Laser Printer
Hello their am trying to install a new all in one mfc-7220 but the installation has failed to complete displaying that the device is not connected yet the USB cable is in. plz help umar
have you selected the correct port? some device managers select a serial port by default when installing a printer. Make sure when installing that you select the USB. check this and if have selected the wrong port uninstall and reinstall. Let me know if this fixes the problem.
Dec 23, 2009 | Brother MFC-7220 All-In-One Laser Printer
How to reset brother printer MFC-7220
You should not just reset yr MFC-7220. Give yr specific problem.
Nov 16, 2009 | Brother MFC-7220 All-In-One Laser Printer
Brother MFC 7220 prints vertical line from top to
The photosensitive drum needs to be cleaned or replaced. If after cleaning it the vertical line continues, the printer may need maintenance.
Sep 17, 2009 | Brother MFC-7220 All-In-One Laser Printer
Usb has malfunctioned windowes does not recongize
hi
first you must check the usb driver installed in your system and for this you have to go to device manager.
Jul 01, 2009 | Brother MFC-7220 All-In-One Laser Printer
Can't find usb plug-in
USB Port is located inside next left of the cartridges.
LD
Nov 09, 2008 | Brother MFC-3240C All-In-One InkJet...
Brother mfc-7220
there a various drivers from brother, download the full software and driver package, it is executable, the others are designed to be used when windows searchs for a driver and you tell it that you "have disc" and point to location of download files.
Before installing it is best to delete previous installs unplu usb, download full package then run it, plug in usb when system promps. use brothers web for driver download.
Jan 14, 2008 | Brother MFC-7220 All-In-One Laser Printer
D-Link AirPlus DI-524 Wireless Router Logo
172 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
