Question about Dometic NDR 1292 Refrigerator
Cold freezer warm fridge
1993 norcol fridge on propane in mexico. freezer-10 fridge 42 f
    Problem Solver:
  • 5 Answers
The only thing I can say now is to make sure that this unit is level. After that you can check to see what model refer you have and we can go from there.
Posted on Jan 29, 2009
2003 wildwood Le trailer how do we light the gas on the refridgerator??? Did not come with manual.
Your fridge should have a switch for propane/electric/automatic. This is usually located above the fridge door & just below the freezer door. When on propane the gas will feed directly to the fridge there us no need to light it! However the propane needs to feed from the large propane tank usually mounted on the tongue of the trailer to the fridge....this takes some time . We usually light our drove first then wait a few minutes & then turn on the fridge. Please know that it takes a few hours 10-12 fir the fridge to cool down to acceptable temps.
Now if u do all the above u may have a blockage (mud dauber) in the propane line - which u can usually access thru the fridge access panel on the outside of your trailer. Bees seem to be drawn to the Oder if propane. Make sure prolate tank is shut off! Take a small brush & clean the inside of the propane line & then start from the beginning.
When the switch is set to electric, you should notice the fridge getting colder in a few hours. Again 10-12 hrs before it us acceptable to place food in it.
When the switch is in the auto mode it will automatically switch from electric to propane when you lose electricity for any reason & back to electric is you run out of propane - or shut it off.
Oh one last thing you must have your battery on in order for the fridge to work!
Oct 25, 2014 | Camping, Backpacking & Hiking
We have a propane fridge which is strictly propane. When we got to our cabin in the spring it would not light. We cleaned it, turned it in it's top for 1/2 hour, and now the fridge part works but not the...
If the flame is putting out design BTU's and you've already turned it You may need to have a technician pull a vacuum on the fridge to make things right again. First things first though, ensure the propane flame is adding adequate BTU's.
Jul 18, 2014 | Refrigerators
Freezer works fine on propane but not the fridge
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
Mar 28, 2014 | Dometic RM2652 Refrigerator
Danby propane fridge model # dpr2262w-6. the freezer still works great but fridge portion does not . the fridge has a bad smell. the fridge is at a cabin and no service
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Aug 24, 2010 | Danby DPR2262 Top Freezer Refrigerator
Neither fridge cooling or freezer freezing
I have one of these, made in mexico, could be freon, mine had a wire unhooked inside, rear of freezer for the defrost. It was froze up, so i dethawed it, found the wire and hooked it up and has been good ever since.
Mar 13, 2010 | Freezers
Freezer froze,ice and frost,freezer door froze, warm in fridge
change thermostat sensors in fridge and freezer easy
Feb 04, 2010 | Refrigerators
Refrigerator doen't work on electric
check the fuse on the back of the board on the fridge itself
Sep 01, 2009 | Thetford Norcold RV Cooler/Freezer
Fridge & Freezer smell like a gas grille...
Do you mean it smells like propane? Or does it smell like propane exhaust (think taxi cab or fork lift)?
Either sounds pretty serious. I have heard of people using hydrocarbons to recharge refrigeration systems, though it is not the recommended method.
Do you own your residence or do you rent? Either way, call a repair man or the management of your rental right away and insist to have it inspected.
Fridges might smell like plastic or stale air if not used in awhile, but not propane/exhaust that I have ever heard of.
Jul 30, 2009 | GE GSH22SGRSS Side by Side Refrigerator
Dometic NDR 1292 Refrigerator Logo
182 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
