Question about Dell Dimension 5100 (D51L1) PC Desktop
Dell Dimension DE051:Wireless Internet Problem (Can't Load Sites)
Hello.
PC: Dell Dimension DE051
OS: Windows XP Home Edition
Wireless Adapter: Linksys Wireless-G 24 GHZ (802.11 g)
Internet Service Provider: Comcast
Summary: The problem began yesterday after I changed my home network's encryption from WPA to WEP. After I did, I could not access Internet on the PC. I found it was because the IP address was wrong. So, I manually reentered everything the Linksys required me to (IP, Gateway, DNS, etc.). I thought that would solve the problem, but it didn't.The message displayed on the Linksys was this:
"You are connected to the Access Point, but the Internet cannot be found."
And then this message was on the Network Connection menu:
"Windows did not detect problems with this connection. If you cannot connect, click Repair." I did, but there was no effect.
When I access the Internet, it attempts to load for five or so seconds and then says that the "Address Not Found".
Notes: Every computer except the Dell Dimension is listed as connected. I don't know why the Dell Dimension (named NANA_COMPUTER) is not listed as one of the computers connected (because the Linksys said it was connected to the Access Point).
I disabled all the firewalls on the Dell Dimension, but it had no effect.
Questions: Should I purchase a better Wireless Adapter? What do I need to do to fix this problem?
  • 1 more comment
  • BOO-Jelly Dec 30, 2008
    To GregL:
    I re-entered the data into the client adapter (I assume that is the
    Linksys Wireless-G 24 GHZ (802.11 g)). The data came from logging on to
    Comcast Home Networking and find the corresponding numbers and whatnot.
  • SoleAngelus May 11, 2010
    Can you not enable DHCP on the router to enable it to automaticly give the client an IP etc to rule out you may have incorrectly entered data (you would have to tell windows to auto get info)
    Also WEP keys are case sensative and have no spaces.
  • Greg Lumpkin
    Greg Lumpkin May 11, 2010
    When you wrote that you re-entered all the data, was that in the router, or the client adapter?
  • 24 Answers
Contact Comcast and have them reset your IP address. also have them ping your modem after they reset IP.
Also, see Linksys website for LELA (easylink advisor) to add devices to network. Uses a good bit of memory so don't allow to run automatically at start up.
Posted on Jan 03, 2009
Keeps dropping wireless WPA-Personal internet connection
If it is not a router problem then you could try a wireless adaptor such as the Lapton N300 USB Adapter. This adapter will connect to all OS including Linux. $20 Max. I had a problem at home where a laptop would not connect at all and this adapter did the job. Maybe worth a try
Oct 28, 2013 | Microsoft Windows XP Home Edition
Hello im troubleshooting a error on a dell dimension 2400, windows xp error when testing or querying the modem the error reads cannot connect or check to see if hardware is powered on or connected...
Wireless zero configuration is the feature of Windows XP that allows Windows to detect the available wireless networks and automatically connect to the most preferred wireless network.
It is enabled by the Wireless Zero Configuration service in Windows XP. It provides auto wireless network detection when you switch on the computer.
Follow the steps below to verify that the service is running:
1. Go to Start and right click My Computer. Select and click Manage.
2. Computer Management window will appear. Under Services and Applications, select Services.
3. Check for the service Wireless Zero Configuration. Make sure that it is started and that the startup type is set to automatic.
computer-management.jpg4. If it isn't, double-click the service. If the startup type is not set to automatic, click on the dropdown arrow and and change it to automatic. Click OK at last.
autostart-wireless-zero.jpgIf your wireless adapter driver does not support wireless auto onfiguration, you will notice the following:
- The network adapter does not appear as a wireless network adapter in Network Connections. It appears as a LAN adapter, similar to an Ethernet connection.
- The properties of the wireless connection do not have a Wireless Networks tab.
- You do not receive a Windows XP notification bar message indicating that wireless networks are available.
To get the most out of your Windows XP wireless experience, you should contact wireless adapter manufacturer to obtain the latest version of the drivers that support this XP feature.
If not, you must manually configure wireless network settings using the configuration software supplied with the wireless network adapter.
Jan 05, 2011 | Dell Dimension 4500 PC Desktop
Dell dimension 4700 NIC problem
This is very common after a fresh installation of the OS. Simply go to Windows Update and run it a couple of times. Upon reboot, the system will detect your hardware and you'll be back in business!
Dec 02, 2009 | Dell Dimension 4700 PC Desktop
Dell dimension 5150 ethernet problem reloaded windows xp home from a windows xp entertainment os. apear fine but not receiving.
Okay, so it seems you installed Microsoft Windows XP Home on a what was Media Center Edition installation, and the ethernet is no longer worker.
Please refer to dell.com's support section, enter your model, and download drivers that you need.
To find drivers you need, Go to start --> control panel and then go to (under classic view) system --> the hardware section, open up device manager, and then look for ones with a yellow big question mark, and get those drivers from dell's website. Burn these drivers to a CD on another computer, or use a USB flash drive if that does work.
Good luck.
Jul 16, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell says I could not load WinXP Pro on Dell T300. Why not?
You won't encounter any problems, but you may need a usb to ethernet adapter to get on the internet to get drivers. Also, many places no longer sell non-OEM copies of windows XP, and, will Dell sell a computer with no OS?
Mar 18, 2009 | Dell PRO/1000 PT Quad Port Server Adapter...
Lost xp home edition os disks...
You can request a copy from microsoft but they will charge you. Do you have a recovery CD came with your PC? if not the best way is to ask your friends for the CD but use your own product key, it should be on the label on the computer. Good Luck :)
Feb 20, 2009 | Microsoft Windows XP Home Edition
Dell Dimension 2350 restore cd or bootable cd.
go to pricegrabber.com to buy a new copy of XP. Save the stuff U want and install the new os. reload U'r saved data. If some of what U wnat to save are programs, U will have to reinstall those. The new XP os will self install from cd on boot up.
May 21, 2008 | Dell Dimension 2350 PC Desktop
Ethernet controller driver
i need an ethernet controller driver for my dell dimension 4600 the operating system is windows xp home edition
Sep 02, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 5100 (D51L1) PC Desktop Logo
530 people viewed this question
Alun Cox
