SOURCE: 2000 Mitsubishi Eclipse will not idle, all else OK, just repl bat
I can only offer these few ideas.
SOURCE: brake light bulb Mitsubishi Eclipse Cars
look for access panels in rear hatch there will be one on each side remove those and there will be 10 ml nuts holding the light housings on remove those then you can access the lights
SOURCE: 2001 Eclipse GT Non-Functioning Sunroof
The sunroof motor is right above the open/close button inside the headliner. You are going to have to remove the headliner to replace it. Just a couple of screws and a connector from there.
SOURCE: Need to replace a serpentine belt in a 2000 mitsubishi eclipse
You should be able to see the diagram for the serpentine belt when you open the hood.
i have the same prob in my 1997 lancer *** import radio and clock wont work inter lights and air com coms on by its self any help plz
