Question about Olympus Stylus 770 SW Digital Camera
Olympus 770 SW wont turn on
Have checked that the battery is charged and we using it correctly, ie inserted correctly both in charger and in camera. Have used the camera successfully anumber of times and recharged and re-used etc. However overnight it suddenly wouldnt turn on after we charged the battery. Is it possible to lock the camera perhaps? has anyone had this problem?
  • 5 more comments
  • Anonymous Jan 21, 2009
    I have the same problem...i can turn mine on to see the pictures i have already taken but will not stay on to take a picture. i have no clue what is wrong.
  • Anonymous Jan 24, 2009
    same problem. I can turn the camera on and look at old pictures but the lens cover won't open to take new pictures. I messed with it a little bit and it did come back on and work once, but not anymore
  • timmylong Jan 24, 2009
    I have the same problem. My camera will come on so that you can look at old pictures but the lens wont open so you can take new pictures
  • Anonymous Apr 04, 2009
    Same Problem, red light flickers but screen is dark. When plugged into computer, screen comes on and all appears normal.
  • Anonymous Apr 15, 2009
    New battery, but my C-770 Olympus will not turn on. Once it would not close, but eventually I got it to close. Now with new battery it will not turn on.
    Please help.
    Gary
  • Anonymous May 18, 2009
    My lens cover is open and wont close. I can view the pictures that I have already taken though. When I try to power up, there is like a quiet click click noise. I dont know what the problem is....HELP!!
  • grapes4u May 20, 2009
    The lens cover is stuck open and the camera will not power on. I have put in two different fully charged batteries and the camera will not work with either one. It was working fine and then all of a sudden went into this dead state and will not come out of it.
Coldcut
  • 1554 Answers
SOURCE: REpair
Folk here only suggest ways for you to fix it.
you start by getting a very small phillips screwdriver
or a tech .
Posted on Mar 08, 2008
SOURCE: olympus 770 sw display info
i am not sure if you can do this. I just press the middle ok button to get rid of the information.
Posted on Mar 23, 2008
  • 919 Answers
SOURCE: cannot print pictures with dates
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
Posted on Dec 22, 2008
  • 11 Answers
SOURCE: Dropped my Olympus Stylus 1050 SW... now it wont turn on!
make sure the battery is charged and if it is and u r still having this problem try pluging it in a pc to see if your camera still works if it is maybe the lenz is messed up and if thats the case i cant help u with that
Posted on Sep 21, 2009
BillB-SA
  • 2761 Answers
SOURCE: olympus 770 sw lens cover not closing
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Posted on Sep 27, 2009
Why does my olympus li-42b battery charger flash red?
this is either bad battery or bad connection with the charger. reverse polarity on the plug in, clean the contacts or purchase new battery.
Jun 05, 2011 | Olympus Stylus 770 SW Digital Camera
Olympus u770 sw 7.1 No power, battery fully charged, lens cover is open. No lights no screen nothing. Camera has been perfect for almost 4 years just shut down whilst being used hence lens cover open. Any...
Hi
Sorry to hear about your issue with the Olympus mju 770 SW. There's a couple of things you can check and try, before thinking about a repair or binning the camera and getting a new model.
1. Check the contacts on the battery are clean?
2. Clean the contacts inside the cameras battery compartment are clean?
3. Is the charger actually charging the battery? Try another battery or see if you can test the existing battery with a multi-meter to check there is some power in it.
It is fairly common for chargers to fail, so it's worth checking out but don't go spending money on a new charger unless you know it will fix your problem.
Hope this helps
David
Jan 13, 2011 | Olympus Stylus 770 SW Digital Camera
I went snorkeling with my olympus 780sw camera last weekend and was taking photos just fine. It was nearing the end of the battery life I believe and when i went to try to turn it on, nothing happened so I...
I have the same problem with my 770 SW. The funny thing is, some outlets in my house will allow it to charge, some will just make the light flash. I found your question looking for a better solution. Try all the outlets in your house with the charger, I know it sounds silly, but it works for me.
Mar 05, 2010 | Olympus Stylus 790SW Digital Camera
Won't turn on
sent it to the manufacturer for repair
Feb 17, 2009 | Olympus Stylus 770 SW Digital Camera
I have the stylus770 camera. It doesn't turn on when connected to the computer to charge it. please help
In order to charge the battery for the camera you need to use the supplied charger that came with the camera. The camera is not going to charge when connected to the USB port of the computer. Camera was not designed to be charged that way.
Dec 19, 2008 | Olympus Stylus 770 SW Digital Camera
Stylus 770 SW Camera - causes Power Surge on USB port
Blown USB ports can happen. Most of the time, they still move power...like you can still charge devices through them, but the device won't be recognized. See if a hub will work.
Rob
Nov 18, 2008 | Olympus Stylus 770 SW Digital Camera
Olympus Stylus 770SW Battery Problem
It may be the battery - try using one of your spare batteries, see if that makes a difference.
Jul 10, 2017 | Olympus Cameras
Olympus Stylus 770 SW Digital Camera Logo
111 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
