Question about Belkin (F5D7230-4) Router (587009)
Firmware update for belkin f5d7230-4 6000uk
I can only find the u.s version of this firmware is it the same as the u.k 1 or do i need the u.k version, if i only need the u.k version can u please tell me where to get it from. Thank you in antisipation.
  • 104 Answers
Hi...the UK firmware for the F5D7230uk4 is on this page if this is correct for your model. There is also a guide to firmware upgrades here - the usual advice is to use a wired connection, backup current config if you can, make absolutely sure you have the right version etc...
Good luck with this
Posted on Dec 31, 2008
Cannot connect to the firmware information server, please double check wan connection
You will have to update the firmware manually
Goto the website www.belkin.com/support
Click Routers
Under No 1 : Select N / G / B.... As given in the router
Under No 2 : Select the Model Number of the router
Under No 3 : Select the Version Number
Click next
Click on the link For firmware update ..... Download the appropriate version as your router
Save the file
on the address bar of internet explorer type http://192.168.2.1 and hit enter
On the left under utilities click firmware update
Leave the password blank and click submit
Click browse ,,, Locate the file you had downloaded and click update
Click OK For confirmation
Jul 28, 2010 | Belkin (F5D8231-4) Wireless Router...
Tip
To get rid of multiple issues with belkin routers
To resolve the issue with Belkin routers:The routers that are released recently by Belkin Inc., are Basic / Connect N150, Surf / Surf N300, Share / Share N300, Share Max / Share N Max300, Play / Play N600, Play Max / Play N600 HD
  • These routers comes with a software CD.
  • Belkin router monitor is the software that gets installed in the computer when you run the setup CD in your computer.
  • This software is really an unwanted one that takes around 30 minutes to get installed in your computer.
  • In addition to that, this software displays unwanted popup messages.
  • 90% users are not aware that they can use the routers without installing any software in their computers.
Inorder to make your router properly, these steps has to be followed...
  • The belkin router monitor software has to be uninstalled from your computer.
  • Firmware of the router has to be updated to the latest version available from the belkin support site.
  • Self healing feature of the router has to be disabled.
  • Wifi protected setup (WPS) has to be disabled.
To uninstall the belkin software:
  • For Xp computers, Goto control panel > Add or remove programs > select belkin setup and router monitor and remove it.
  • For vista & win7, Goto control panel > Uninstall a program > select belkin setup and router monitor and remove it.
To update the firmware for your router:Goto http://www.belkin.com/support/
  • Select your router and download the firmware for your router. The file with a .bin extension will be downloaded to your computer.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using an Ethernet cable.
  • Open internet explorer / Firefox or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router http://192.168.2.1
  • Belkin router setup utility will be displayed.
  • Login to the page. (password: leave it blank and click submit)
You will have the status screen.
In the status screen, you will have the very first box in the centre of the screen says "version info", under that you will have firmware version.
Just note down the firmware version there. If the firmware version in router is lesser than the one downloaded from support site, then the firmware has to be updated.
On the far left side below the Utilities you will have "firmware update", you need to click that.
Now on the right hand side you will have "browse".
Click on browse and locate the downloaded .bin file from your computer and click update.
Click ok for all the warnings.
You may see a count down now.
Once its done you will be brought back to the status screen.
Login to the router again with a blank password and click on restore factory defaults below the utilities and click ok for all the warnings.
Now the firmware of your router must have updated with the latest version.
To disable Selfheal:
On the far left side below the Utilities you will have "self heal", you need to click that.disable the self heal and apply changes.
To disable WPS:On the far left side below the Wireless you will have "wifi protected setup", you need to click that.wifi protected setup will be enabled by default, disable it and apply changes.
Click here to learn more about wps...
on Dec 20, 2010 | Belkin Basic Wireless Router
Firmware
Hello jagancs1,
The Belkin Router's software (firmware) can be occasionally updated. To check for new updates, go to the Belkin Router Setup page http://192.168.2.1/ . The following choices will appear to update firmware and save current settings:
•Select Firmware Update (Near the bottom of the left-hand panel)
From time to time, Belkin may release new versions of the Router's firmware. Firmware updates contain improvements and fixes to problems that may have existed. Click the link below to see if there is a new firmware update available for this Router.
•Firmware update Options:
Firmware Version > #.##.##
Check for New Firmware Version > [Check Firmware]
Update Firmware > [Enter file name/Browse]
[Update]
•NOTE: Please backup your current settings before updating to a new version of firmware. Click Here -> http://192.168.2.1/system_c.stm to go to the Save/Backup current settings page.
•Save/Backup Settings
You can save your current configuration by using this feature. Saving your configuration will allow you to restore it later if your settings are lost or changed. It is recommended that you backup your current configuration before performing a firmware update.
*Saved File name is user.conf*
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Jul 04, 2010 | Belkin (F5D7230-4) Router (587009)
Why haven't you found solutions for the posts above???
Hello joe_east,
[Update]
Have a great day,
martyshaw152
I need to update the Belkin Router for Wildblue.net
Contact Belkin Tech Support At Toll Free Number- 1-800-585-2494
Apr 22, 2010 | Belkin F5D8236-4 Router
Need repair download for my belkin/n/# f5d8233-4 router
you can download the latest firmware from the link below
http://en-us-support.belkin.com/app/answers/detail/a_id/521/kw/f5d8233/r_id/166
download and save it in a folder...open internet explorer and type 192.168.2.1 in address bar...you ll login to the router setup page...
click on firmware update on the left hand bottom side....locate the firmware file saved on your computer....click update...you are done with that...make sure you download and update the firmware that is the appropriate version of your router... you can find the version number if you flip the router...
its stats wit "v" or "ver"....
Mar 09, 2010 | Belkin Computers & Internet
Wireless internet connection drops off even with an excellent signal belkin F5D7234-4 v4
1. all u need to do is download the firmware for ur router
2. most of the belkin products if u update the firmware it will work great
3. go to belkin.com/support and download the firmware. jus click on this site it will lead u to download ur version
http://en-us-support.belkin.com/app/answers/detail/a_id/301/p/386
4. u need to save it in the desktop screen
5. open the belkin router setup page by 192.168.2.1 in the ie or firefox
6. in the left side click on firmware update then leave the password blank and click submit
7. then click on the browse choose the file which u downloaded from the site
8. click on the update and after the reboot of the router ur good to go.
Feb 07, 2010 | Belkin F5D7234-4 Router
Belkin (F5D7231-4) Wireless Router can't update
From http://www.belkin.com/support/, type the Belkin part number “F5D7231-4” in the “Search” field. Click “Search”
From the results page, click “F5D7231-4”.
Scroll down to the Software & Updates section. Click on "F5D7231-4 Firmware Update".
Locate the firmware that corresponds to you routers version number. To download the new version of firmware, click the download logo.
A window will open that allows you to select the location where you want to save the firmware file. Select a location. You can name the file anything you want, or use the default name. Be sure to save the file in a place where you can locate it later.
Note: We suggest saving this to your desktop to make it easy to locate the file. When you have selected the location, click “Save”.
The download of the firmware is complete. To update the firmware,
follow the next steps in “Updating the Router’s Firmware”.
Make sure that you have the router Wired to your computer before you continue with the firmware update instructions.
Feb 23, 2009 | Belkin (F5D7231-4) Wireless Router
Need drivers for the belkin
have you checked the manufacture website
Jan 14, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Nintendo wii
Follow this link, pick your router from the list and it will walk you through the needed steps. http://www.nintendo.com/consumer/routers/en_na/Belkin/index.jsp This section is just for Belkin routers. You may need to get the latest firmware for router if you don't already have it. To check your version open your router's interface page with your browser. Type 192.168.2.1 When it opens check your version. Then go here. This is for your router for updating the firmware. http://www.belkin.com/support/article/?lid=en&pid=F5D7230-4&aid=5947&scid=222 Update the firmware first if you don't have the latest version and then proceed to the other link .
Mar 12, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D7230-4) Router (587009) Logo
1,267 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
