Question about Kitchen Ranges
Noisy fan in main oven of a britannia SI-12TP cooker (1997)
Fan in main oven is very noisy possibly needs replacing
where can I get a new fan
3 Suggested Answers
  • 8 Answers
SOURCE: need manual for Britannia ilve range cooker
You may have the cooker oven set to automatic. Phone their Service Team on 01253471111 option 3. They will help you fault find. The ID strip with all the cooker information is inside the right hand oven on th right hand side.
Posted on Jul 20, 2009
SOURCE: Model number SI 9TF GRA Britannia Range Cooker
my larger oven on my britannia range has stopped working would it be the themostat and how much would this cost and can i fit it myself? the grill is working and so is the small oven can anyone help please. ben.
Posted on Aug 07, 2010
My gourmet classic leisure cooker has a noisy fan. What can I do?
Hello CAROL ROSA,
If it is NEW... TAKE IT BACK.
ELSE... (replace the fan).
Post the actual model number to see if
we need to look for 'parts' (USA) or "spares" (rest of the world)...
Together we can get this
'FIXED' (USA) or "sorted" (rest of the world)...
http://www.harveynorman.ie/home-appliances/cooking-appliances/range-cookers/leisure-gourmet-classic-oven-grb6cvr.html
Aug 30, 2016 | Kitchen Appliances - Others
What would happen if fan is disconnected noisy and not wanted?
NO NEVER EVER DISCONNECT FANS OR ANYTHING ELSE ON YOUR COOKER.
Your cooker may have at least two fans, one for heating the oven cavity and one for cooling the electrics etc inside the oven. If the fan is noisy, check to see the fan has not come loose on the motor (maybe left had thread) if the fan is ok, then the fan motor may need replacing!
Oct 20, 2014 | Ovens
I need some instructions how to change the lower oven element in my britannia SI-12T7 cooker. the element has screws that will not unscrew from inside the oven. any ideas?
straight forward to do. undo the screws to the back panel of the oven.
once remove down at the bottom of the oven you will see where the heater element comes through . there are to main feed wires that are pushed on and one earth wire. pulls these off as they are just push fit.
the element its self is a flat plate with 2 self tapper screws undo these and the element will then come out of the front of the oven. you have to lift it on a slight angle so the feet of the element will come through . hope this helps
Jun 16, 2014 | Britannia SI10T6L Dual Fuel (Electric and...
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
Britannia si-12t76x2
If your oven has no heat you'll need a new oven element, if your oven is cooking food too quickly/burning at the back then you'll need a new fan, if the oven is burning everything you'll need a new thermostat, if the oven isn't working at all check that the clock/timer hasn't been set for auto ie make sure it is on 'manual cooking'
Jun 16, 2012 | Britannia SI10T6L Dual Fuel (Electric and...
Why is the fan so noisy?
If the fan is noisy, then it is probably due to worn bearings, or possibly worn or loose fan blade/s
In my experience it it is usually due to worn bearings.
The only guaranteed cur is to replace the fan motor.
Dec 02, 2010 | Baumatic B187 Stainless Steel Electric...
Britannia fan oven fan makes rumbling noise when operating. How do you remove fan? What is probable cause of noise? This has just started. Model is Britannia SI-9T.
*****************TURN OVEN OFF AT MAINS OR JUST TURN ALL ELECTRICS OFF ****************NOW.........hi the fan blade nut is anti clock undo... take fan off... you will see three screws undo... go to rear of oven remove panel..... the fan will come away in your hands... disconnect wires ... reverse action needed to put back together....
Dec 30, 2009 | Ovens
Brittania SI/9TB/SS fan in main ove glows red hot
There is a fault on you oven please ring Britannia for a service call on 01253471111 option 3. They can also supply a new oven seal
May 07, 2009 | Britannia SI10T6L Dual Fuel (Electric and...
Sep 01, 2008 | Britannia SI10T6L Dual Fuel (Electric and...
Noisy fan
it has to be replaced the bearings are shot on it I'm afraid well knowen problem in are trade.
Apr 12, 2008 | Belling XOU492 Electric Double Oven
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
