Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Temperature not high enought
When the machine is rinsing, the wate temperature is giung only to 120 degrees. How do i change it upward. It is a Hobart
  • jlmartin654 Jan 01, 2009
    the hobart washer is giving a code of J2 . What does thie mean/ the temp of the water in the sink is 180. Why the low heat on the rinse cycle?
  • Anonymous Feb 24, 2009
    Our Hobart Dishwasher is only heating to 93 degrees, instead of the 163 degrees recommended.
  • 640 Answers
Are you sure the code isnt p2?This is the rinse thermistor that is in the top right corner in the back,it screws into the vac breaker assy.Part number 328994 from hobart about 60 bucks.Let me know.
Posted on Jan 08, 2009
Check the temp. of the water in your kitchen sink. If this doesn't get over 120 either the issue is with your waterheater not the dishwasher. You should be able to up the temperature on the water heater.
Posted on Dec 30, 2008
Hobart Dishawashwer led displays error Spanner EE.
Possible:
1. Dirty line strainer, causing low water pressure/flow. Turn off the water supply to the dishwaher, open the strainer cap, and clean the screen.
2. Low water pressure
3. Excessive Lime or mineral deposits in the wash/rinse system. You may need to delime the system.
4. Water temperature is below 110 degrees.
5. If equipped with a booster (heater), and more than 8 minutes pass with the water temp still below 110 degrees. Heater may be bad.
Mar 18, 2016 | Hobart Dishwashers
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
I have a LXiC Hobart dishmachine I do not want to use Sanitizer because my hot water is very hot. How do you disable the sanitizer pump and alarm? H.
Do you realize that to sanitize with hot water alone requires 180 degree F water? I am a hobart technician and I've never seen any business or residence with hot water anywhere near that. Residential hot water is generally approx. 120, Commercial locations generally use approx. 140, but never near 180 (tap water that hot would be a severe safety problem). Hobart LXIH machines use a built in booster heater to boost the temperature of the incoming hot water up to the required 180 deg.
Jul 01, 2011 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Where is the high temperature rinse thermostat located
you need 180 degree water to the unit from the water heater unless it has its own heater.
Jan 12, 2011 | Hobart AM14-253 Free-standing Dishwasher
Good morning, I have 01 Hobart dishwasher AM14, i need to be replace rinse sensor probe and temperature sensor for booster heater.But I can't to find Hobart part number Please help me.Thank you.
294692 for the rinse probe.
"temperature sensor for booster heater"? Do you mean the thermostat? If so, part number is 274161.
Parts breakdowns and part numbers are available at www.hobartservice.com. Click "Parts" on the left, then click "Hobart SmartParts System" on the next page. You'll be asked a series of questions to identify your piece of equipment, and then you'll get a parts list and have links to parts breakdowns for various sections of the machine.
Nov 20, 2010 | Hobart AM14C-155 Dishwasher
Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
After pressing On - the dishwasher just sits are about 80 degrees and doesn't get any hotter when normally it goes up to about 118. Can we still use it to wash or is something wrong?
A hobart LXIH-3 uses a chemical to sanitize however a 120 degree wash temp is required as well.
Turn up your hot water tank that supplies the dishmachine, make sure your sanitizer is pumping into the rinse cycle using micro-clorine test papers and all is well.
Dec 22, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Temp. too hot
First off, the temp adjustment can only be made by a trained service tech, since the dishwasher will need to be reprogrammed to allow for a lower temperature in the rinse cycle but still have the higher temp needed in the wash cycle. Also, since any change in the water temp settings will require a longer wash and rinse cycle to be programmed into the unit.
Of course, you could simply lower the water temp on the water heater that supplies water to this unit, but you'd have lower temp water elsewhere and likely get cited at the next heatlh department inspection on that issue.
Since this is a commercial dishwasher, you might want to reconsider lowering the temp, since health codes and standards for commercial establishments require a MINIMUM water temperarture of 185 degrees F (85 degrees C) for proper operation and to get all the crud off the dishes, etc.
Note, the manufacturer sets these units to the higher temp, 203 degree F (95 degree C) knowing that the water will cool down quickly once the wash cycle starts and the water contacts the dishes, etc. That is also why these units have a added heater element, to help keep the water at the correct temperature needed to both clean AND sanitize the dishes, according to established health standards.
If you really want to change the water temp settings, contact your Hobart service rep and explain the reason you want it lower and see what they say.
Hope you found this very helpful and best regards!
Aug 19, 2009 | Hobart SR24-H Built-in Dishwasher
Hobart lx 18 warewasher what hatco booster heater product compatable with it
The answer to this question will be based on the incoming water temperature that is supplied to the booster heater. The standard sizing for a booster heater is based off of a 40 degree F rise (140 degree F incoming water temperature) or a 70 degree F rise (110 degree F incoming water temperature). For a 40 degree F rise, a Hatco model C-5, S-5, or PMG-60 will supply the needed amount of rinse water for the LX-18 Hobart dishwasher. A 70 degree F rise would require a Hatco model C-9, S-9, or PMG-60 to supply the same Hobart model number.
Oct 11, 2008 | Dishwashers
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
266 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
