Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
How to get oven door on wirlpool electric range
I can not get my oven door back on to my range
  • Whirlpool Master
  • 3,463 Answers
Try this;
In yout browser bar type in uk.youtube.com
In the search box type in Fitting oven door hinge
Then click on appropate video.
You may find this helps.
Please leave comment to let me know if you found this helpful.
Thanks.
Posted on Dec 31, 2008
The oven door lock is stuck. I can't close the door. How do I release the lock? model #FEF369CGSa
Hey Susan, thank you for your inquiry!
Based off the information you have provided the oven door on your Frigidaire range is locked and will not close. You can press and hold the cancel button down for at least 15 seconds. If that does not work, you can perform a reset on your range by disconnecting the power from it for at least ten minutes. If you continue to experience issues with the range please comment back. I would be happy to assist you further. -Matt
Dec 26, 2015 | Frigidaire 30" Self-Cleaning Freestanding...
I have a F5-E0 error and it locked the oven door, i turned the over range off and on to unlock the door and kept the range off all night, when i put it back on this morning the oven started to heat up on...
Hi
Error code F5-E0 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Whirlpool RBS275PD Electric Single Oven
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
40494 / 40495 / 40499 Electric Single Oven: have a kenmore self cleaning electric range it was...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I removed the range door to clean oven. Now I
NOTE: The door removal pins you inserted must still
be in both sides of the door.
1.
Grasp the door on the sides with your fingers on
the front of the door and your thumbs on the
inside surface.
2.
Rest the hinge hanger so that it is flat (at the
bottom of the hinge hanger on the bottom of the
front frame slot).
3.
Position the door with the hinge hanger slots
almost parallel to the front frame.
4.
Push up and in until the hinge hanger slots
become fastened to the range. Lower the door
and rotate it slightly from the front to the back
until the slots are fully fastened. The hinge
hanger will be close to the bottom of the front
frame slot.
5.
Pull door open about halfway and remove the
door removal pins. Save door removal pins for
future use.
6.
Close the door.
Dec 25, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
2 year old elect range/oven by wirlpool will not
check your input voltage your probably losing a leg and only have 120volts instead of 240 volts that would cause a reduced heat symptom
Jul 16, 2009 | Ovens
Oven door won't go back in place
open each hinge about 1/3 of the way open or until it reaches the point that it will stay open, align the door slots with the hinges and lower the door down onto the hinges. Door should operate properly now.
Feb 05, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven Door
http://www.repairclinic.com/0088_13_1.asp.... good luck
Aug 06, 2006 | Kenmore 30169 Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
61 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
