  • Wisebean Dec 31, 2008
    Hi All- My Soundmaster tone arm will not drop down far enough to stay in the groove. When I push down on the plastic "tone arm holder," it plays and records perfectly. I need to adjust the angle of the tone arm!
  • 42 Answers
The electronics on a linear turntable are very sophisticated. A specialist repair shop is your best hope.
Posted on Jan 25, 2009
How to adjust height of tonearm
Probably the answer is in your manual. If you don't have it, pleaseprovide make an model of your turntable so wa might try to help you
May 04, 2015 | Audio Players & Recorders
Which are the best bearings for a technics mk-5, for the tone-arm
Hello Richard,
I'm sure your last name starts with a V. I doubt you will find bearing to fit this tonearm. Bearings the size of vertical or horizontal for a tonearm are going going to be long discontinued.Additional to that, you would need a bearing with a specific co-efficient of friction. As to putting them in, you would need a minipress, minivice, Panavice, or due to the size, you can probably use a drift and small hammer to set them. A pair of pliers would also probably work. Frankly, I've never seen one go bad, unless it was a Dual that someone really overtightened them. It just takes a fine touch, not a power drill. :-)
Aug 16, 2014 | Technics Audio Players & Recorders
Adjust tonearm
Hi, most auto turntables have a screw to adjust the landing position of the tonearm. It is normally at the tonearm base on the left side under a rubber grommet. Stylus city
Aug 01, 2014 | Audio Players & Recorders
Adjust tone arm
Usually there is a hole towards the back of where the tonearm is mounted that adjusts the set down area. Be aware that some have two holes one for set down and one for pick up of tonearm. These can be adjusted with a flat blade screwdriver. Check and see with a good flashlight. Adjust slowly and check to make sure you are turning it in the correct direction.
Apr 04, 2014 | RCA Audio Players & Recorders
Turn table doesn't start when tone arm is lifted
Did it used to start when you lifted the tonearm?
Many turntables start when the arm is moved over the record.
Jan 29, 2013 | Audio Players & Recorders
Technics SL-5 Turntable will not turn.
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Apr 06, 2009 | Audio Players & Recorders
Tonearm lifter in UP position - how to fix
I have also had this problem with the same model turntable. I opened mine up and the problem seems to have been that the grease on the arm lift and cueing lever was gumming up the linkage between the two. (I suspect that my turntable hadn't been used in some time.) I managed to free up the parts by manually working the the arm lift (pressing it down) several times. I'm not sure that I needed to open up the chasis for this fix but it did help me to see what was going on. Good luck with yours.
Tim Orange
Mar 20, 2009 | Technics SL-BD20D Turntable
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
Jan 01, 2009 | Kenwood KD-291RC Turntable
Technic SL1200 M3D
1) This turntable either has bad RCA cables or a faulty tonearm - in either case, none are easy fixes. FYI, If you use Ortofon Concorde series, they are notorious for causing faulty connections with your tonearm, and eventually deteriorate your tonearm over time. So you might want to think about changing them if you get a new tonearm put on. If you use the Technics headshell, you are fine. 2) This turntable definitely needs to have the tonearm replaced. Once the arm comes loose from it's bearings, it's next to impossible to get it back to factory specs, and you will have skipping issues. Both will require professional servicing. Check out if your in the NYC area.
Sep 07, 2007 | Technics SL-1200M3D Turntable
284 people viewed this question
