Question about Konica Minolta DiALTA Di200 Copier
Di520 black and white copier toner collection box
I replaced box, but a message comes up that still tells me to change toer collection box. Is there a code or something I can put in to clear this.
  • spyder58 Dec 31, 2008
    I cannot exit out of the menu that I am in to reset. My end and exit button won't work
    Problem Solver:
  • 17 Answers
Enter the tech rep mode by pushing the utility button, pulling up the counter screen, and pushing Stop-0-0-Stop-0-1.
This will pull up the tech rep mode menu. Select "Counter" and then "Consumables."
Select the toner collection count and hit "Clear." Exit the mode and you should be good to go.
Posted on Dec 31, 2008
  • 1 more comment
  • Robert Stickney Dec 31, 2008
    "I cannot exit out of the menu that I am in to reset. My end and exit button won't work"
    Try powering the unit off and on to get out of the tech rep mode.
    Unfortunately, the touchscreen on this model is prone to failure such as you are experiencing, and the only fix is to replace the entire control panel.
  • Abdullah Rajput
    Abdullah Rajput Dec 01, 2012
    the problem in my di520 is same. and i try Robert's Instruction. my copier is ok now. Thanks Robert Stickney
  • Abdullah Rajput
    Robert please tell me this type of solution: my copier di520 shows on screen preventive maintenance time m2 & m5. please tell me proper solution of this trouble, thanks
  • Konica Minolta Master
  • 1,297 Answers
M 5 - Change developer,OPC drum,drum cleaning blade.
M2 - Oil WEB roller change.Reset the consumable oilweb counter after replacing the web.
Posted on Feb 03, 2013
Just now toner refil but low toer eiiow led flasing problem
Because there is a chip on the toner cart once the orginal toner goes the chip tell the copier its gone you can refill all day but it will not change replace the image unit /toner cart.
Mar 29, 2014 | Konica Minolta 1710587001 Toner, 1500...
Waste toner box full message after changing the waste toner box
When you removed the waste toner bottle, there is a sensor inside the copier. When you remove the waste toner, look to the opening where the top of the waste bottle was, clean that area and return the bottle and turn the copier OFF then ON. Good Luck
May 04, 2013 | Canon Gpr23 Irc2880/2880i Black Copier...
Changing waste container
The is no waste container on Phaser 6500. There is a "waste collection box" in every toner cartridge and the waste toner is discarded along with the empty cartridge. The is also a waste toner reservoir on the transfer belt and this one will be replaced along with the transfer belt.
If there is an error message saying, for example, "Waste Full Cyan Cartridge", it means the waste toner counter reached the replacement value for that color and you have to replace the corresponding cartridge. But the waste collection box is not really full.
Sep 30, 2012 | Xerox 6500/N Phaser Laser Printer
How repair error sc 590 in ricoh aficio 550
SC590: Toner collection motor error
-Definition- [B]
The toner collection motor sensor output does not change for 3 seconds while
the toner collection motor is on.
- Possible causes -
· Toner collection motor defective
· Too much load on the drive mechanism
· Poor toner collection motor connector connection
· IOB defective
· Toner collection motor sensor defective
Sep 06, 2010 | Ricoh Aficio 1224C Black and White Copier
Please help we are changing the toner on our copier machine and got an ERROR MESSAGE: used toner case is full.
the waste toner box is located beneath the front cover ( the cover that has Canon and model number ).
Open toner cover and you will see one screw wich you need to remove.
Then, on left side of toner, on top of the front cover, few milimeters from edge is second screw wich you need to unscrew. Usually is covered with white/grey cork made of rubber.
then remove cover, by pulling it in left side then towards you.
Big white box is waste toner container wich you need to clean/empty it.
Hope that helped!
Jul 26, 2010 | Canon ImageRUNNER 3235 Black and White...
Error message in di620
my copier says toner colection box is full what can i do
Mar 16, 2009 | Minolta DiALTA Di620 All-In-One Laser...
Press Utility key and press in this order STOP-0-STOP-0-0-1,select COUNTER windows,select waste toner windows: for SET press C(cancel 10 keys pad) introduction 320000; for Counter press Exit too quit,back the basic menu.
Feb 27, 2009 | Minolta DiALTA Di520 Laser Printer
Toner collection bottle
Please pres UTILITY key ,after touch Neter count to touch panel display,press in that order Stop - 0 -Stop -0 - 0 - 1; select COUNTER,select Consumables,select waste toner:
SET : 320000
Counter:press C to cleared the value.
After press exit etc.
Can't find toner collection box
So which is it, a Di200 or a Di520?
A Di200 has no toner collection box - the waste toner is recycled.
The toner collection box on a Di520 is located in the rear of the machine - just remove the main rear cover and it is obvious.
Nov 18, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
143 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
