Sony KP-65XBR10W 65 in. Rear Projection Television
Problem for Sony KP-65XBR10W 65 in. Rear Projection Television
Sony projection Tv KP-65XBR10W has no picture or sound
By jennielagrac on Dec 30, 2008
I have a Sony projection Tv KP-65XBR10W and it will not turn on The red light on the front pannel blinks non-stop. Please help we are haveing a new years eve party and have no tv
Solution #1
posted on Aug 18, 2009
Somewhat Helpful)
greenspan
Rank: Wiz
Rating: 82%, 626 votes
Looks to me as an serious (but not uncommon) PSP board problem with Panasonic plasmas. Contact a Panasonic service center.
What problems have people had with quality control on these displays? Are they covered under warranty?
  1. Certain displays emitted an extremely loud buzz. This was covered by warranty repair.
  2. Certain displays had a problem with the Y/C delay on their S-video input. This was also correctable.
  3. One person reported red vertical lines on his display.Was this covered by warranty? Was it an input problem or a pixelproblem?
  4. Afew bad pixels here and there are not covered underwarranty. Largeclusters are generally covered. It's up to Panasonic'sdiscretion. Onthe plus side, however, bad pixels are becomingincreasingly rare. Mostpeople are reporting no bad pixels at all!
CALIBRATINGWhat needs to be calibrated on a plasma?
You needto calibrate most of the same things that need to be calibratedonother displays. About the only things that don't need to be doneareconvergence and geometry. You can usually tinker with picture sizeandposition, but there's no need to deal with keystone orpincushionadjustments, etc.What is white level? What is black level?How are they adjusted?
Theadjustment for white level is usuallylabeled "Picture" (as onPanasonics) or "Contrast". "Brightness", on theother hand, refers tothe black level. Yes, this is apallinglycounterintuitive. This FAQuses the terms "white level" and "blacklevel", since they betterdescribe what you're actually adjusting, andthey're the terms used byAvia and Video Essentials.
How do I adjust hue and saturation?
In anothermysterious choice of terms, hue is controlled by the "Tint"setting,and saturation is controlled by the "Color" setting. This FAQuses theterms "hue" and "saturation", since they're the terms used byAvia andVideo Essentials.
How do I set the white level on a plasma?
Youset the white level by adjusting the "Picture" setting. You willneedto use a different test pattern than you would for a CRT. Forbothplasma displays and LCD displays, you should use the 10 IREgrayscalestep pattern. There are two criteria you want to match on yourplasma.
First,you need to make sure the white level is low enoughthat your displayisn't thresholding (or clamping) bright levels. Youshould set thewhite level low enough that you can see each of the 10IRE stepsdistinctly. The Panasonics seem not to exhibit clamping (in mylimitedexperience), even at factory defaults, so this criterion may notbeterribly useful.
Second, for the health of your display (e.g.to avoid burn-in), you should turn down the white level. Just becauseyour display can display blindingly bright pictures doesn't mean that it should.Plasma displays should be set between 21 fl and 25 fl light output; thePanasonics comeout of the factory at about 30 fl. On one ISF-calibratedPanasonic, 23fl was roughly equivalent to a Picture setting of -20 (inthe usermenu, not the service menu). To set this precisely you'll needto bringin a calibration specialist, but you can do a lot of good byjustdialing down the white level a lot. After seeing the display at 30fl,23 fl will see very dim. But after a while, you'll find that 23 flisplenty bright.
How do I set the black level on a plasma?
Youset the black level by adjusting the "Brightness" setting. You canusethe same test pattern you would use for any other display.
How do I calibrate grayscale (calibrate the color temperature)?
Unfortunately,this is one you can't do yourself. You need specialequipment tomeasure the color. In fact, most ISF technicians lack theequipmentspecific to plasma calibration (a $15K gadget known asaspectroradiometer). But even the standard color measurementequipment(which calibrationists do have) will do a great job.
Thatsaid, one person who had his Panasonic display calibrated by anISFspecialist said that the Cinema / Warm setting was reasonably closeto6500K out of the box. Using that setting is probably the best you'lldoon your own.
If you're really determined to screw up yourdisplay,the RGB drive and cutoff settings in the service menu are usedto adjustthe color temperature.
How do I adjust the color decoder?
Thereareseveral issues here. Generally speaking, the Panasonic decoder seemstopush blue a bit. The R-Y Axis Angle and B-Y Axis Gain in theservicemenu are used to correct this behavior.
There used to beaproblem on some Panasonics with the Y/C delay on the S-video input.Seethe Quality Control section for more information.
How do I adjust the gamma?
On the industrialmodel, there is a set of Advanced picture settings. Goto the Picturemenu, turn Advanced on, and then hit the down-arrow. Inthe subsequentmenu you can adjust quite a few parameters, includingselect from a fewgamma settings.
This advanced menu appears to be missing from the consumer model.
How do I calibrate my consumer model given these missing menus?
Thereis apparently a way to activate these menus. Perhaps you can findacalibrationist or Panasonic technician would can turn them onlongenough to do the calibration.
What's the overall calibration procedure?
In general, the order Avia sets out is the correct one. A more complete list is:
  1. White level (picture)
  2. Black level (brightness)
  3. Repeat (1) and (2) until you have a good balance.
  4. Grayscale (requires special hardware and mucking about in the service menu)
  5. Sharpness
  6. Hue and Saturation (tint and color)
  7. Color decoder (requires use of the service menu)
  8. Repeat (6) and (7) for red and green until you have a good balance.
SERVICE MENUHow do I access the service menu?
In a word, don't. See the service menu warningabove.If you're bound and determined to make use of the service menu,buy theservice manual. It contains more than enough information foryou to ruinyour display and/or kill yourself.
Was this helpful?
Yes
No
Solution #2
posted on Jan 17, 2009
Somewhat Helpful)
sandman0058
Rank: Apprentice
Rating: 75%, 1 votes
I had a Sony recommended serviceman come in to analyze te same problem for me. Turned out to be a major part called the 'D' board. Cost for part around $400 if it could still be gotten and at least $300 in labor. Goodbye TV! My money will be better spent on a replacement LCD/Plasma TV since prices are dropping and picture quality will be dramatically better than the old beast.
Was this helpful?
Yes
No
Popular Solutions for Sony KP-65XBR10W 65 in. Rear
Questions and Unsolved Problems for Sony KP-65XBR10W 65 in. Rear
Do you recommend Sony KP-65XBR10W 65 in. Rear Projection Television?
Answer
Answer
My Sony KP-34T75 Projection TV flashes green lines and makes a clicking sound every once in a while.... (More)
Answer
i have an rca universal remote control and i need to tv code for my sonykp43t75
Answer
Perfect picture and color alway blinking off and on sony kp 65xbr10w
Answer
I have a Sony KP-65XBR10W that had a blinking light on the front, either blnking 9 times or... (More)
Answer
tv will normally come on when cold. Once warm, the video on the tv will disappear and you will get 5... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
