Question about Nikon N65 35mm SLR Camera
Rewind Problem The batteries died while the camera was rewinding. I put new batteries and pressed the two buttons for it to continue the rewind. It has stopped at 12. I tried pressing the two buttons again and it will respond but the roll won't continue. What's going on? Please, I can't lose this roll!!
    Problem Solver:
  • 30 Answers
But be careful not to damage the camera mechanism,if its hard to pullback (inside Darkroom)the film,dont force it,have it done by any deveping center,otherwise you will be in big trouble for the repairing cost.
Posted on Jun 25, 2007
Wait till night. Go to a room. Draw all the curtains and switch off all lights. Now you have a dark room. Make sure you can't even see your own fingers! Pop the camera film cover. Pull out the film and rewind manually.
Posted on May 03, 2007
The battery in my Minolta Maxxum 7000 died while rewinding. I replaced the battery, but nothing happens and the rewind-button/slide is stuck. How do I reset this slide, so I can rewind my film?
Sorry to hear you're having troubles with your Minolta. First thing I would do is make sure that the batteries you put in our good and that you do have power coming out of that battery box. He didn't mention whether the batteries had corroded or if there had been any corrosion previously. The rewind button on this camera will not reset until the camera again advances. In other words it is an automatic release on the camera fires the first time after a rewind. So as an beginning answer to your question I would check the batteries again make sure that all contacts are absolutely clean and as you may have noticed the battery boxes on the Minolta do pivot. The contacts under the pivot points also have to be clean. If you checked all of these issues and you're still having problems please feel free to e-mail me at, Dave@advancedcamera.com.
Thank you good luck
Aug 10, 2011 | Minolta Maxxum 7000 35mm SLR Camera
How can you rewind the film
Lift up the rewind crank. Press the film rewind button on the bottom of the camera and turn the crank clockwise. Rewind until the tension on the crank lessens, indicating that the film leader has been released from the take-up spool. Pull up on the film rewind crank and the back will open.
Dec 03, 2010 | Pentax ME Super 35mm SLR Camera
How do u get the camera 2 rewind
Usually the automatic rewind starts when the film roll has come to the end. You can rewind also before that by a rewinding button you'll find usually somewhere in the camera body.
To rewind manually, press the film release button (consult the manual if you don't find it) and use the rewinding lever to rewind the film. See this for inspiration: http://www.ehow.com/how_2028878_film-mm-manual-slr-camera.html
Jun 19, 2010 | Nikon Photography
Where is the rewind button for the N2020? How exactly do I rewind my film?
it is on the top, a lock button you press down and a slide button that engages the rewind, if the batteries are dead it will not rewind.
Apr 03, 2010 | Nikon N2020 35mm SLR Camera
I finished taking pictures but it didnt rewind. did i load the film wrong? or did the batteries die? or whats up
Have you tried taking just one more pic to see if that triggers the rewind? If that didn't work, most film cameras have a rewind button. Usually on the bottom of camera. If you still can't get your film to rewind, take camera to your nearest photo finisher. They should have a dark box; they can remove your film manually.
Feb 18, 2010 | Canon EOS Rebel K2 35mm SLR Camera
How do you change the film in a minolta x-370n?
push in the rewind button on the bottom of the camera. turn the rewind knob to the right until all the film is rewound into the film canister.
pull up on the rewind knob to open the back ( film ) door, remove canister. put new film into camera push rewind knob down and pull enough film to attach to the take up spool.
Dec 10, 2009 | Minolta X-370S 35mm SLR Camera
FILM WILL NOT REWIND
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
May 21, 2009 | Nikon N80 35mm SLR Camera
Can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
May 21, 2009 | Nikon F80 35mm SLR Camera
Film rolls back automaticaly
The camera shouldn't be doing this, assuming you're using 36 exposure (or 24 exposure) film. You may want to set a custom function to prevent automatic rewind -- you would have to rewind the film yourself by pressing the rewind button.
To do this:
1. Under the palm grip, press the 'CF' (custom function) button.
2. Use the main dial to select 'F1' in the LCD. It should show a '0' below the 'F1'.
3. Press the 'CF' button to change the '0' to a '1'.
4. Press the shutter button half way to save the change and exit the custom function setting mode.
If you want to stop the rewind with the film leader still exposed (film doesn't rewind entirely into the cannister), use the same steps but set custom function 'F2' to a value of '1'.
Mar 17, 2009 | Canon EOS-1N RS 35mm SLR Camera
Nikon N65 35mm SLR Camera Logo
73 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
TC CAMERA REPAIR.Com...
Are you a Nikon Photography Expert? Answer questions, earn points and help others
