Internal fuse blows after its used 3-4 times. Checked door switches and monitor and they ohm out good.
Any Ideas what to check next?
Model # 66561622100 about 7 yrs old, no other problems with it.
Thanks for any help you can provide
You either have a dead short or a ground on the 120 volt line going either to the unit or to the light.
Is the fuse holder tight?
You shouldn't be able to easily rotate the fuse with a thumb and finger while it's in the holder.
If it's loose, that can cause a fuse to overheat and melt inside.
Is the internal cooling fan running?
When I say internal
cooling fan, I do not mean the hood vent exhaust fan which you can turn
on and off manually.
I'm instead talking
about the internal fan which comes on automatically whenever you
microwave.
The high voltage transformer may be failing.
This is usually accompanied by an electrical smell, but it may be slight enough that the cooling fan disperses it.
You can temporarily disconnect the fan and run it for about a minute (no longer - the magnetron will overheat) and then see if you can detect smoke or smell.
Be sure the loose connector is taped off so it doesn't contact any connections or get hit by a fan, etc.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
You can find
exploded views and order parts by entering your model number at the Sears
parts site.
But Sears parts can usually be obtained for far less here by entering either the part or model number.
Here are some links you
or someone you know can use (in order given) for test help, but read
the safety warnings first:
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/mag_test.html
(continuity can be good even
though it is bad!)
Let us know how it goes.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
Thanks for clearing up the situation. Now I understand what's happening.
If
it goes dead or blows the breaker (or GFI) when you plug it in or open
or close
the door, then there's a problem with a door switch or door switch
mount.
A helpful link:
http://www.microwavedisplay.com/doorsw.t...
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
We're
The fuse blew yesterday and three days ago without the microwave being used. Yesterday I opened the door to put something in it and saw the light go out, I checked and the fuse was blown. So to answer your question- No the room lights do not dim, and I dont think the amperage draw is an issue since it wasnt running.
Thanks for your reply.
Goldstar mod mv1502 has blown fuse 3 times and now has a continuous msg of "hit start" but never nukes anything. Fuse is not blown this time, must be magnetron.
The main tube is now drawing to much amperage/voltage?Check it with an amp meter whicl running.DoO the room lights dim while in use? Replace it.
