Question about Dynex 19 in. LCD Flat-Panel HDTV
32" LCD Dynex tv goes black and white radomly
When we turn the tv on the screen will go black and white randomly. Called Best Buy because we purchased the service plan. The will not honor the plan they stated that if the tv is doing this radomly there is no way to fix it. So guess what we have to put up with the tv. Anyone else having this problem?????
  • Anonymous Jan 04, 2009
    you got rick roll'd
  • wyw0516 Jan 12, 2009
    I have the same problem when I try to watch dvd'S on the TV. All DVD movies are in black and white. Is there a solution?
SOURCE: Program a universal remote for the Dynex 32" 720p Flat Panel
Try using the codes listed for Orion products. Worked for me.
Posted on Feb 17, 2009
  • 16 Answers
SOURCE: 5/6 of screen going out
check the panel cables
Posted on Mar 30, 2009
rulds2008
  • 3866 Answers
SOURCE: Broke a brand new TV screen dynex dx lcd32 09 Does anyone know how to buy a replacement screen
Try ebay look up the model number on there useing advanced search you just might find one.. Good luck.
Posted on Apr 22, 2009
vortash
  • 431 Answers
SOURCE: Fuzzy pic on Dynex 32 LCD TV
I am sumising that you have checked the menu controls on your tv and are recieving your signal from the cable box , so therefore if it is not comong from the Aerial and direct from the cable company then the picture should be clear .. However sometimes people dont check to see if the signal is RGB or composite from the box RGB is usually best if you have a scart socket connection or SVHS if your set has that capability .. sometimes people have an old VHs recorder and the sinal is coming from that to the set through the Aerail fly lead if it is you will probably find they are conflicting giving you a poor picture retune your Video to another channel instructions should be in its manuel if not come back to me ... reagrds Vortash
Posted on May 01, 2009
aparsons89
  • 40 Answers
SOURCE: No picture on new Dynex 42" lcd hdtv
Do you have cable or DVD player connected yet? If not, connect your cable to the back of the LCD via Coaxial cable. Next turn channel to 3 or 4 whatever channel you use for cable. Then use auto programming to find all of your cable channels. If no cable connect the DVD outputs to one of the AV 1 or Av2 inputs on the back of your LCD. Power on the DVD player and change your input to which ever AV you connected it to. You should see a blue screen and your DVD Player Icon.
Posted on May 13, 2009
My Dynex 32" LCD tv seems to turn on and off
The blue light merely indicates that power is getting to your TV. It has internal power supply problems.
Nov 30, 2013 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32 in only shows black and white now
Black and White on a new setup would indicate you've plugged in AV or Component cables incorrectly. Match the colors up, be aware some Dynex models have AV connections on the SIDE of the TV. Don't just plug colors into random places. Failing that, check to see if your still inside 1 year manufacturer warranty or a best buy product protection plan. If not, seek out repair locally.
May 15, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex L26 10A purchased little less than year ago has audio, but black screen. When first turned on screen will display: "Please Wait", then screen goes black, but audio can be heard. Tried uplugging from...
Call for warrenty serviced,u still have warrenty inforced until a year.Ur tv have intermittently signal shutdown before it come throught the Tuner board not,carrying to the LCD Screen to produced a picture.
Jul 03, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Dynex 32" LCD - bottom 2/3 of screen is black w/ colored lines
My screen looks EXACTLY like that! I called Dynex and they told me my warranty is out and they cant fix it. I have only had this TV a bit over a year. Did you get a resolution??
Jun 02, 2010 | Dynex DX-LCD32-09 LCD TV
Dynex 32" tv picture goes black
If there is still about ? 24. Volts coming from the Power Board when it goes dark, it will be the Inverter board that needs replacing. If not, it is the Power Board that needs replacing. The Voltages should be written next to the sockets & plugs on the Power Board.
Jun 02, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
TV worked fine one night, next day screen is white.
The LCD Panel failed. There is no easy fix but try to get the T-Con board to fix the issue. However, this part is usually only available with the whole LCD Panel. This is usually the most expensive part in the TV and the whole TV needs to be taken apart to replace the panel.
Might be economically viable if you can find a place that carrys the T-con but Dynex parts are usually hard to find. The LCD Panel part alone will exceed the cost of the TV.
Oct 07, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex TV white screen of death..Getting thrown around by BB
If under the manufacturers warranty, contact the manufacturer.
Jun 13, 2017 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 32" LCD White Screen Problem.
Hi, My Name is Jorge K. My family owns Dynex T.V. 32 LCD, we bought the tv at BEST BUY=BBY and we did not buy any warranty from BBY all we had was the fatory warraty that last a year. we had the same problem after five months the screen of that tv stop working and all we watch was a WHITE SCREEN.
Solving the Problem:
If you the orginal owner and bought the tv from BBY, you should call Dynex " the phone number will be on your owner manual tv.and it should be free if you live in the USA" and explain the situation about your TV. It might be a white screen or different problems. You should have your BBY receipt from that tv. because they will ask you for information that the receipt has. After you finish complaning with Dynex, Dynex will transfter you to BBYbecause Dynex branch is relate to BBY as the manual explain us. You will be talking to BBY Geek department. Geek department will send a Technician to fix the T.V. The Technian WILL NOT BE ABLE TO FIX THE TV THE SAME DAY BECAUSE HE/SHE WOULD NEED TO ORDER A REPLACEMENT PART TO FIX THE TV. Generally the tech will need to order a NEW SCREEN TO REPLACE AND FIX THE PROBLEM, but pay me no mind. Haha I am not a t.v. Tech. haha.
Because the Tech will not able to fix the problem the same day, he will give you a phone number and you will have to call BBY and ask if your replacement screen arrive. If they are unable to get your new screen, Dynex will give an order to change the T.V. for a new one. and they will give you a change number that you must write. Then you can go to the BBY where you bought the TV or any BBY and get you new Dynex TV. BBY will try to charce extra money because my, your or our Dynex tv model might be old and had a lower price than they new Dynex tv that BBY has right now. I think you will have to convince the manager from BBY home teather department not to charge you extra money. My father was able to convince the manager and we paid nothing for the new tv.
Solution if you Dynex TV is not from best buy or has more than a year:
haha YOU OUT OF LUCK, You can try call Dynex first and deal will the problem. You can also try to replace the screen but it might not fix the tv and replacing a screen could be costly, haha I just prefer to buy a new TV and no invest in something that might be trash if that solution doesn't work out. Risky, Please play save with your money and don't gamble. HAHA.
If i hurt any feeling, i bet for forgiveness and I wish that everything goes alright with your tv and your life.
GOD BLESS AMERICA and the people from earth.
Jan 18, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Straight out of the box had 3 pixels out, Now 2 days later a Black Circle.
The white spots are called 'dead pixels' and depending on the manufacturer, they may allow a certain number of them but normally not in the primary viewing area.
The other anomaly shouldn't be there and LCD displays are not affected by magnetic fields as are CRTs.
Return it quickly and I would be reluctant to accept a simple exchange.
Do some checking on the Dynex brand before you take it back though to see if this kind of quality is common to the make.
You might start here:
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rls=GGLG,GGLG:2005-37,GGLG:en&q=dynex+lcd+problems
Jul 06, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex 19 in. LCD Flat-Panel HDTV Logo
422 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
