Question about Kenmore 43142 Front Load Washer
My Kenmore Frontload Washing machine (about 5 years old) is not going through the spin cycle. It fills with water and drains but does not spin.
  • 91 Answers
Pump is probably clogged
Posted on Jan 04, 2009
Kenmore elite 90 series 11028902790 fills w/ water & agitates. On drain cycle it won't drain unless you put drain hose to floor drain position. Drains water but will not start the spin cycle. Help
It is either a bad pump or a bad control. Call Sears. Hard for the homeowner to fix. If not in warranty, ask them how much to fix and then decide if the old one is worth the money. If the machine is 10 years old, go for a new one.
Jun 01, 2015 | Kenmore Washing Machines
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
Water spills over tank onto floor
check for object in the drain hose going to the water pump or the pump going bad also check drain hose make sure is not blocked
Jul 30, 2009 | Amana Washing Machines
Washing machine will not drain
May 29, 2009 | Indesit W 123 Front Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Spin cycles not spinning, does drain water before spin
check the is the part near the cam bar.has 2 coils on it. also check the yellow wire going to the solenoid it may look ok but could be broke internally.
Nov 04, 2008 | Washing Machines
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 43142 Front Load Washer Logo
150 people viewed this question
Sal De
 Brian Main
Brian Main
