Question about Lexmark X1150 All-In-One InkJet Printer
No Ink dectect on papers
I have big issue with my printer, no ink into the paper, and i remove the plastic from the catradige. And my software detects the catratge color and black, but no ink to the paper. The printer is old but the catrage is all new.
  • hurth Jan 05, 2009
    I have the same problem I do not getting any ink to paper even though the ink is new. Tried 2 different ink cartridges but not the cartridge Any help out there.,
  • Edgardo Burgos Rodriguez
    It then help...is the printer
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
Hi i m using Epson LQ1150 printer there is a problem when i give a continue print commant the printer skip one paper after one paper print pls suggest me wht should i do pls give solution on my mail id ...
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Jul 29, 2011 | Epson Office Equipment & Supplies
Shows 'out of paper' when it is not
Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge and the paper detect sensors, if faulty this must be replaced.
Jul 21, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
My canon MP145 feed more than 1 paper at one time
Somettimes it is due to the paper tray being out of aligment or if the paper is of a different grade. Please check this out and see the position of the paper feed.Also in some cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Apr 28, 2011 | Canon PIXMA MP160 All-In-One InkJet...
My brother DCP-165C has full ink which shows in the status monitor. in the test print only the colored ones in visible in the paper. but in the normal setting when i print nothing is there in the paper. ...
Apr 27, 2011 | Brother DCP 165C Compact Color Inkjet...
Blink off ink and paper light not scanning nor coping
Apr 21, 2011 | Office Equipment & Supplies
My printer no pm235 problamas errar &inkpads rare
It ispossible that the printer has errors as there is a software error. Hence to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Apr 05, 2011 | Epson Printer
E2 is showing have taken paper out put back in tried cleaning the heads dont know what se to do have plenty of paper also
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts.
Can be also possible errors in the mother board, remove an fix back all the connections. If not can be a failure of the board.
Nov 02, 2010 | Canon PIXMA MP190 All-In-One InkJet...
HP1215 All-in-One After switched on, the carriage move left - right (start-up procedure) and then go sits in the corner on its base, with the check paper and check print cartridge lights both flashing....
Oct 29, 2010 | HP PSC 1215 All-In-One InkJet Printer
My Canon MF4010 printer shows "paper jam" even i have already removed paper
the paper jam could have caused errors so remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Sep 28, 2010 | Office Equipment & Supplies
It doesn't print It says size paper error
This problem occur when ink head is dirty and also the head cleaning plastic mechanical cleaner is full of jammed color. 3210 model can be opened and the ink head plastic cleaner can be changed. The ink head is the moving part on the metal axel.
Isopropanol is good for cleaning.
Oct 06, 2009 | HP Photosmart 3310 Printer
Lexmark X1150 All-In-One InkJet Printer Logo
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
